Question about Brother CS-6000
My sewing machine is not automatically feeding?
The mechanism inside the machine will not turn over / around. The balance wheel turns but nothing moves inside. The belt is perfect. Took lid off and looked inside, machine cleaned and oiled, lights work. This happened after I tried to sew some heavy fabric. Desperate!!!
Posted on Sep 13, 2010
    Genius:
  • 1,788 Answers
Do you have a stitch pattern chosen? Is it set for winding the bobbin? Check your manual, if you cannot find it download one for free, at brother-usa.com
Posted on Sep 12, 2010
3 Suggested Answers
WonderTech
  • 268 Answers
SOURCE: Machine does not feed properly. It sewed fine for
Here are a few solutions to check.
* Check your fabric to make sure it isn't caught on something.
* Check your pressure foot to make sure it's screwed tightly in place.
* Adjust the pressure of your pressure foot as it may be too light or too heavy for your fabric.
* Check your feed dogs for lint. If your feed dogs are clogged with lint, they're not gripping your fabric properly. Remove your pressure foot and clean out any lint with an old toothbrush.
* Raise your feed dogs if your machine has this function. They may have been inadvertently lowered.
* Check your stitch length regulator, If its set at “0” or a very small number, try switching to a longer stitch length.
* Change your needle, it may be damaged.
* Check your needle plate and make sure it's securely in place.
* Use a “Jean-a-ma-jig” or a “Hump-jumper”. If you've been trying to sew over a bump of fabric, such as a thick jean hem, try using this tool (your local fabric store should carry it). It keeps your pressure foot level as you sew over the bump and gives your feed dogs something to grip.
I hope this helps
Posted on Mar 23, 2010
  • 17 Answers
SOURCE: My sewing machine does not feed material through
your feeddogs are down or the pressure has been released on the foot. either problem sould be explained in the owners manual on how to reset either one.
Posted on Nov 06, 2010
Does it feed.the.material by itself.automatically or do you have to do it
machines feed automatically
the bottom feed is by a set of jaws that rise up and move back then down and repeat the process back or forward according too the sewing direction required
mostly if it is not progressing the stitch it is because the feed direction is close to neutral position or in the middle of forward /back
Oct 10, 2016 | Sewing Machines
Do feed dogs drop automatically on SE-400 when embroidery unit is attached?
Yes they should unless the tab on the middle of the embroidery unit is broken.
Jul 31, 2014 | Brother SE-400 Sewing & Embroidery Machine
Automatic thread cutter.bobbin thread does not feed to the top.
when you stop sewing where is the arm located ,up or down ..that will make a world of difference
Jan 06, 2014 | Elna 7200 Computerized Sewing Machine
Why do my feed dogs grap my material at the beginning of a stitch
some sewing machines have what is called a buttonhole lever that
is to the left of the needle that has to be pulled down before the
machine will make a buttonhole,here is a link for a free manual
if you dont' have one
http://www.singerco.com/uploads/download/430_8280_es.pdf
Mar 18, 2013 | Singer 8280 Mechanical Sewing Machine
Every time I hit the start button to perform embroidery, the screen tells me to lower the feed dog - even though it's already down. Is there a way around this?
the sensor must not be working. I thought the 9000 lowered feed dogs automatically when embroidery option is choosen anyway. There is a manual as well as on screen drop feed dogs method for this machine
Jan 13, 2010 | Janome Memory Craft 9000 Computerized...
Can't get the material to feed automatically
The teeth on your feed may be clogged with lint... follow instructions in the manual to remove the cover and clean out the lint...has the machine been oiled??
Aug 04, 2009 | Simplicity Serge Pro SW432 Mechanical...
Are feed dogs supposed to be up or down w/ embriodery unit?
The embroidery carriage automatically lowers the feed dogs when put in place
Dec 01, 2008 | Brother SE-270D Computerized Sewing...
I have a Brother 98-Stitch Computerized Sewing & Embroidery Machine, SE270D. I dropped the feed dogs and now it wont come back up.
I dropped my feed dogs and when I pushed the button to bring them back up, it wouldn't work. I did discover that when you put the button back to the up position and start sewing, the dogs come back up automatically.
Aug 05, 2008 | Brother SE-270D Computerized Sewing...
Janome memory craft 7500
The feed dog will rise as soon as you turn the handwheel one time. Just put the fabric in it and sew. It will come up automatically as long as you have moved the lever to the correct position.
sewman7
May 15, 2008 | Janome Memory Craft 9000 Computerized...
Brother CS-6000 Logo
61 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
