Question about Amana NAV5800A Top Load Washer
Washer belt The belt broke on my washer and i need to know how to install new one. Amana model NAV5800AWW
  • 246 Answers
To replace the belt on your Amana washer, pull the unit forward then tilt the top of it back to about a 45 degree angle. Once you get the right angle, the unit will rest against the wall behind it instead of falling forward. Take your new belt (availble through local appliance parts stores or on line from the manufactures web site) and first put it in the track around the large pulley, then the track on the smaller pulley on the right. Lastly, the pulley on your left should be moveable. Move the final pulley so that you can get the belt over it. It will then move back to a tensioning position.
Posted on Jun 17, 2008
The motor sounds like it is overloading and kicking out. Most likely cause: binding brake pads.
Sep 13, 2013 | Amana NAV5800A Top Load Washer
Hello! The belt broke on our Amana Mod.# DLW330RAW . Could you explain how to install the new belt? Thanks Ron
Remove the bottom kick plate.
Remove 4 big bolts and unplug the motor. Move the motor assembly to a work bench. You need a T-20 torx driver to remove the pump screws and remember the rear pump leg goes between the belt. I have your Amana washer repair manual HERE
Mar 17, 2010 | Amana DLW330RA Top Load Washer
I need to replace the belt on my Amana ALW480DAW. The other one burnt up and broke. I have the new one. Do you have a diagram I could view to help me install the new one?
I used the following links:
Oct 21, 2009 | Amana ALW480DA Top Load Washer
Replacing belt
Put The Belt On The Motor First Then Put What You Can Get Of The Belt On The Other Pulley And Turn It. It Will Give You The Anchorage Needed To Put The Belt Back In Position. If This Doesn't Help Let Me Know And I Will Further Assist You.
Michael Scott
Feb 10, 2009 | Amana 3.2 cu. ft. Top-Load Washer
You are missing the coupling that holds the agitator to the shaft.
Aug 24, 2008 | Amana NAV5800A Top Load Washer
Changing belt on washing machine, that broke
to change the belt you need to remove the pump attatched to the motor. the pump is held on by either spring clamps or in older models, torx (star) screws. I believe the size for the torx screws is #20. slip the belt over the motor pulley and around the tension pulley and finally around the transmission. reinstall the pump and you're good to go.
Aug 18, 2007 | Amana ALW540RA Top Load Washer
Amana NAV5800A Top Load Washer Logo
490 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
