Question about Sylvania G-Netbook
How do I set up netbook to wifi - Sylvania G-Netbook
How to connect sylvania netbook to wifi
If windows is up and running make sure your wifi card is enabled (there's usually either a switch or one of the function keys will turn it on or off). From there in the bottom right corner look for your wifi icon or go to the control panel and find your wifi connection settings. From there just follow the directions on your screen to connect it to your wifi hotspot.
Dec 26, 2011 | Sylvania G-Netbook
I am trying to connect my netbook to the internet and it won't connect because it can't find an ip address i have looked and tried everything what do i need to do?
The first way, and one I use a lot, is just plug your netbook into your router at home, using the netbook's Ethernet port and the cable supplied with your router.
This way works every time, gives a fast and secure connection, but means that you need to use your netbook within cable distance of your router. Any internet usage will be part of your normal broadband usage with your home ISP, but isn't the point of netbooks that you can be mobile with them? Who wants to have nice new netbooks tied up by a cable?
netbook router ethernet or wireless
2 - Wireless netbook connection using your home ISP
Another way to get online with netbooks if you're at home is to connect wirelessly to your home router.
It's a very easy process - just turn the netbook on and it will seek out your router. You get a fast connection, good security (if you tell your router to use WPA encryption) and it will usually work anywhere in your house or garden. Several netbooks, laptops or other computers can use your internet connection this way from the same router, so your family and friends can use their netbooks at the same time.
3 - Wifi netbook connection out and about
A really cheap way to get online when you're out and about is Wifi. Many busy locations - pubs, hotels, shopping malls - have "wifi hotspots" which are simply powerful wireless routers that you can use to connect your netbooks wirelessly to the net.
Some are free and can be used by any computers that are nearby. Others are owned by telecomms operators like BT Openzone or mycloud and you need to pay to use them. Monthly subscriptions or pay as you go are available. So are these free and cheap choices ideal for using with cheap netboks?
For anything other than general browsing on netbooks, beware of wifi. The free ones have no security at all, and the others have password protection, but the data you send and receive is not encrypted. This means anyone in the vicinity could snoop and listen in on what you were doing. I don't bother with wifi for this reason.
If you have a wireless router you must know the password you made when you set the router up.
Try also to look in your controlpanel network and shareringcenter.
Hope this was helpfull.
Mar 10, 2011 | Computers & Internet
The wifi is turned on but there is no wifi icon at the bottom panel of my netbook. i cannot locate the connection management settings.
in control panel go to network settings you will find it in there right click on the wifi connection and go to properties, click the check for show when connected in taskbar then that icon will be on your taskbar at the bottom
Jan 11, 2011 | Acer Aspire One Netbook 8.9" Notebook
Netbook connected to my WiFi, but Explorer won't go online.
Make sure you are entering the correct WEP key or password for your network. It might show you are connected to the WIFI but will not let you go online. Also, make sure the settings in internet explorer are set to "Automatically retrieve settings"
Jan 02, 2011 | Sylvania G-Netbook
I cannot get any wifi connection. I purchased a Sylvania Netbook. I have followed the quick start directions. The wifi icon will not set up it shows off. I tried to set it up in two different wifi...
Please check whether you have the External Wifi Switch Turned ON. If it is Turned. Now go to Windows Mobility Center and check whether the Wifi feature is enabled.
If the Option is grayed out check whether the Driver is Installed and Enabled.
if the issue still persist, Please check whether the Wireless LAN Zero Confirguration Service is Started and set to Automatic/
Nov 17, 2010 | Sylvania G-Netbook
I just purchased a Sylvania Netbook. Following the Quick Start Guide included in the package, I went to set up a WIFI connection. The first step is to "click the WIFI icon on the lower right side of the...
should work. make sure the radio is on from either the desktop (not the task bar) or the f9 key. You might need to select the router connection and enter the pass key if locked.
Sep 08, 2010 | Sylvania G-Netbook
I cant connect on wifi..since this bldg is a wifi zone but still can't access..i need to see the manual to know how to operate this netbook since im new on this gadget..thanks
every unit if the configuration is right not possible to connect on wifi around you..check the configuration/access control...( username/password/ of setting of you pc.. you need to check it all
Jun 25, 2010 | Everex CloudBook CE1201V Netbook
Sylvania G-Netbook Logo
462 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
