Question about West Bend 55108 Espresso/coffee Maker
Its giving me shocks. i stopd using it. - West Bend 55108 Espresso/coffee Maker
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 7 Answers
It's your electrifying personality! :o) Just a suggestion: Check the earth cable. The screw must be tight, not wobbly.
Posted on Sep 12, 2010
568 jones gives elect shock put bear feet feet on pedals no elect
Rehman, are you wearing wool socks and getting static shocks, ensure your cable(wire) is in good undamaged condition or replace.
press the helpful button and follow me for more tips
Feb 10, 2016 | Sewing Machines
Need a walkthrough to R & R the rear shocks on a 94 olds cutlass supreme my book is a little vague
you need to jack up car until both rear tires clear ground.use two jack standsand place them on the subframe. on most gm (olds) i jack the car up right in the middle of rear crossmember. set jack stands ,when letting down car MARE SURE CARS WIEGHT IS BEING SUPORTED 95% ON STANDS.let jack down.make surecar is stable i give it a shake. don't remove jack.you need to jack up rear crossmember 3 to 4 in. it takes the wieght off old shocks.Therev are two diff.style shocks gm used #1 shock had holes in both ends of it.#2hole in bottom and threaded shank on top. its pretty strait forward with #1 style shock make sure you use all new hardware that came with shock. #2 style can be tough somtimes, i let tension ( some )off jack be cause i use a air impack to remove upper nut on shock but if you don't have air tools, at tip of shock you will notice a 2 flat sided tip use a 1/4 in wrench to hold top from turning while using 1/2 in wrench for nut removal also on this style shock tighten down just till rubber squeezes 1/8 in past washer. if tou over tighten on upper style #2 shock it will split new rubber washers.#1 style can be tighten till stops. hope this info is what you needed. B. HARRIS A.S.E. Cirtified
Apr 20, 2011 | 1994 Oldsmobile Cutlass Supreme
I get shocks when vacuuming the carpet.
No that should not be happening...there is a major problem inside your vacuum!! you need to stop using it and get it repaired. There is probably a wire rubbed through somewhere...this could give you a very bad shock if the right things happen together....
Or just get a new vacuum...
Do not use that vacuum!!
heatman101
Apr 24, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Power to the tv just stopd and it is not the cored the red light to sho the power is on is not on
This unit has had a component failure.The unit should be sent or taken in to a service center for testing and service. The Polaroid customer support telephone numbers are 1-866-925-7278 and 1-866-289-5168. Give them the model number of you television and the problem you are having with it. They will be able to help you with your problem.The Polaroid customer support website is: http://www.polaroid.com/CES/support.jsp Give them the same information and they also should be able to direct you to a service center, that will help you with your problem. I hope this information help you with your problem.
May 28, 2009 | Polaroid FLM-3732 Television
The following link posted by stiv0 gives detailed instructions on how to replace the two capacitors that commonly go bad on this TV. When these capacitors go bad they prevent the TV from turning on. However, you still get a red light when you plug it in. Since your not getting a red light I'm not sure this fix will work for you. I'd open up the TV and see if the capacitors are bulged out as described in stiv0 post. If they are I'd go ahead and replace them and give the TV another try. This fix is fairly easy to do and very inexpensive so you don’t have much to lose.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
May 20, 2009 | Polaroid FLM-3732 Television
D70s problem
Check the exposure compensation setting to ensure it's set for +/-0. To do this, set the camera for Program mode. Locate the exposure compensation mode button - it's the button with a +/- on it immediately behind the on/off switch. With the camera on, hold down this button. If it shows anything other than "0", use the main command dial (the wheel on the back) to change to setting to 0.
The reason the camera works in the Auto mode is because the exposure compensation settings are not available in auto mode, but are available in Program (P), Aperature (A) and Shutter (S) modes.
Sep 30, 2008 | Nikon D70s Digital Camera
X2gen 19 inch wont turn on.
my Acer Orbicam that takes picters and vidios stopd working just like that and i dident do enithing rong it just stopd working please can someone help me
May 30, 2008 | X2Gen MG19MY 19" LCD Monitor
Rear shocks whirlpool duet GHW9200LQ front loading washer
ok its hard to remove the shocks without breaking the little tabs. You can tell which way they rotate out right?? There is a stop tab that stops the shock when its locked in. Rotate the other way, I use pump pliers (crescent wrench) and gently apply pressure until the tabs give. The new shock has new tabs and all..
Nov 24, 2007 | Whirlpool GHW9200L Front Load Washer
West Bend 55108 Espresso/coffee Maker Logo
20 people viewed this question
Top West Bend Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Paul Bade
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
