Question about Husqvarna Scandinavia 100 Sewing Machine
When I use the zigzag option the machine sews backwards. Is this normal? How can I make it go forwards?
  • 161 Answers
This is not normal but perhaps you are set for button holing?
Posted on Sep 13, 2010
  • hbv269 Sep 13, 2010
    Possibly: the manual was not clear at all about how to do zigzag. Do you know which number I need?
  • marianne bags Sep 13, 2010
    from the image i could get off google, it looks like there is a knob for zig zag. try setting that to zero. The button hole stitch will have a symbol like a rectangle. I can't see it from the google picture, but its probably an option that you select
Does my Brother SQ9185 sew backwards other than the push button backstitch?
Use the reverse button. That's what it is for. Sew forward and then push the button and sew in reverse.
Machine Darning Jeans Shirt
If you have a darning foot, you can use it (drop the feed dogs) and then you manually move the fabric around while stitching.
Learn How To Mend Clothes with Machine Darning
Oct 01, 2016 | Brother Sewing Machines
My machine will not sew in the forward position...It keeps sewing backwards like it is in reverse.....Need help ASAP
All sewing machines have a gear lever. This is so you can sew a seam forwards and backwards. Consult your manual.
May 03, 2016 | Sewing Machines
While stitching the cloth goes backwards instead of moving forwards.the backwards stitching switch is constantly on. What should I do
check to see if your machine is in buttonhole mode, one of the legs of the buttonholer will always be a reverse zigzag.
Sep 19, 2014 | Sewing Machines
Sewing backwards
try adjusting the top thread tension for the loops
try changing the needle
and see if that help any if not then take the machine back and
tell them what the machine is doing
if the machine was adjusted, then they should have checked the
stitches to make sure that the stitches were normal both forward
and backwards.
Jan 05, 2013 | Janome 1600P-DB Mechanical Sewing Machine
Elna SU purchased in 1977 jammed; rotating wheel is unable to move forward
it sounds like the machine needs to be serviced at a sewing machine
shop
May 05, 2012 | Elna Sewing Machines
I have a singer protege that won't zig zag
it's possible that the zigzag gear may have worn out or broke.
you might think about having the machine checked to see why it won' t
zigzag.
Apr 30, 2012 | Singer Sewing Machines
Janome 2030 QDC How to predict whether the buttonhole (24) will start forward or backward? I power off the machine and reselect stitch 24 and move the buttonhole presser foot to the start position every...
does it sew buttonholes both ways?
My Janome 6500 always buttonholes away from me, so when it starts, it sews the near bartack, then stitches backwards down the right hand side of the buttonhole. It then comes back with little straight stiches on other side and sews the zigzag backwards on the left side, then the far bar tack. I would have thought your Janome would do the same stitch sequence.
Jul 16, 2011 | Sewing Machines
Necchi automatic BU supernova sewing machine
Hello! Hello!
Your machine is probably not 50 years old. I have one just like it that we purchased about 5 years ago. Necchi makes a very sturdy reliable machine. There are a couple of tricks, though. First, your bobbin thread has to turn clockwise. If it doesn't, it will either not sew, the stitch will look horrible or the thread will break. Second, threading it is pretty easy; however, I can't explain some of the parts. I would be happy to scan the diagram and e-mail it to you. E-mail: daridoll@yahoo.com. The tension should be set at 3 unless you are doing a ruffle or close zigzagging (machine applique). For applique, I find that I have to move it to 2. For ruffles or gathering, set it at 0 and your stitch width to 4. Another trick is to hold the top thread for the first 2 stitches. This alleviates a bobbin catch at the beginning. Other things you will want to know are in regard to the two knobs. One is pretty simple. It has a line that gradually increases in a zigzag. This knob basically adjusts the width of the zig zag. Obviously, for straight stitching, you would make sure the straight line is towards the top. The other knob determines the type of stitch you want to do. The red stitch options on top of the machine can be done with #1, 2, 3, 4 or 5 at the top; however, I usually use #1. The blue stitches are really fun! Simply decide which stich you want and make sure the corresponding number on the dial is turned towards the top. Also, it is very important that you adjust the other knob to the largest zigzag possible AND change the stitch length to 4. Don't pull on the fabric from behind the machine as you are sewing, because the machine will go forward and backwards while making many of these stitches. The green A, B, C on the dial are used for the automatic buttonhole feature. In order to use this, make sure you have the button hole foot. It looks like a long rectangular piece of plastic with measurements on it and hollow in the center. Not sure if that description makes sense. Anyway, the first step is "C." Make sure you begin with the button hole pressure foot measuring "0". Also, change your zigzag width to the desired width AND change the stitch length to less than 1. (You will notice that this area has a green line on it.) Begin stitching. You should be moving forward. When you have reached the desired length, make sure the needle is up, then turn the knob to "B" (sometimes I make my zigzag wider for this part), begin sewing. You should not go forward or backward. This step makes the bottom of the button hole. I only make 3 or 4 "B" stitches. When done, make sure the needle is up, adjust your zigzag back again if you changed it for B, and set it on "A". This will take you backwards. If you started your button hole with the foot on 0, it will automatically stop moving backwards when you reach 0 again. At this point make sure your needle is up again, then set the knob on "B" once more. If you adjusted B before, do it again. There you are! You can use twin needles on this machine. It also works well with a walking foot for quilting. Oh! To wind your bobbin (starting from the thread spool) you need to slide the thread under the little metal knob sticking out on top of the metal "?" right above the tension and then insert it into the hole in the bobbin spool. Push the bobbin to the right. This locks it into place. Next, hold the outer part of the flywheel (round wheel on right side of machine) while turning the inner wheel towards you. This will disengage the needle and allow the bobbin to wind. Now you can press on the "gas" and wa-laah. It will slow down and almost stop when it is completed. Cut your thread, slide the bobbin to the left to unlock, tighten the wheel and you're done. If you have any more questions, let me know. Hope this helps!
Jul 27, 2008 | Necchi 3537 Mechanical Sewing Machine
Husqvarna Scandinavia 100 Sewing Machine Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
