Question about Logitech Cordless Mouse
Key prints more than once
When I type a "y" it often doesn't print or prints more tha once. I used a cleaning duster but that didn't help much. What other suggestion do you have?
  • quintina May 14, 2008
    I never eat at my computer and since the cleaning duster didn't help too much can I remove the key easily and clean it again?
  • 66 Answers
Try removing this key, gently pop it off with a small flat head screwdriver and see if there is anything to clean underneath. If not, there may be some corrosion on the board itself. Cleaning this would require you to open the case of the keyboard, and locate the terminals that are for that key, and use a pencil eraser to clean these contacts.
Posted on May 15, 2008
Prints only last page
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Dec 31, 2011 | Lexmark X4270 All-In-One InkJet Printer
An error on my printer canon mp610
Your problem is with the "print head" not the ink cartridge. Try this:
http://uk.answers.yahoo.com/question/index?qid=20090219090632AAXVQPZ
Dec 02, 2011 | Canon PIXMA MP610 InkJet Printer
Local Print Spooler Service is not runing.
This means tha Print Spooler service is disabled. Click COMPUTER or MY COMPUTER icon, then click Manage. Expand the Services and Applications, then click Services. Scroll down to look for the Print Spooler service, double-click it, change its STARTUP type to automatic and then click the option to start the service. Once done, try printing again. Good luck.
Sep 08, 2011 | Office Equipment & Supplies
Hello, My HP deskjet 1120c printer doesn't print any colours any more. Only black and light blue. I bought already 2 new cartridges (colour) and it didn't work. Help me please to tell me what to...
in control panel go to printer and faxes. there you will get your printer in printer tab. right click on your printer model, go to property, to printing preference. there in maintenance tab go to head cleaning. run the head cleaning programme once or twice. your problem will solved. thank you
Aug 30, 2011 | HP Deskjet 1120c InkJet Printer
Epson stylus photo r300 removed print head, flushed out all nozzels with water, dried everything, reasembled everything, including the flat ribbons, two different times. After dozens of times trying to...
If an inkjet printer has not been used for some time and several print head cleaning has been done and it still does not print properly then the nozzles in the print head are blocked.
Inkjet printers need to be used frequently to prevent nozzles blocking with dried ink.
You need to replace the print head to get the printer functioning again.
But these print heads are expensive to replace, it may be better to buy a better and a later model printer for not much more costs.
Feb 24, 2011 | Epson Stylus Photo R300 InkJet Printer
Unable to print BLACK
The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will display the date and time. Print the Print Quality Check Sheet and see if all colors are present:
    1. Press the Ink Management key.
    2. Use the up or down navigation key to select TEST PRINT.
    3. Press Set to confirm your choice.
    4. Use the up or down navigation key to select PRINT QUALITY.
    5. Press Set to confirm your choice. Press the Color(Colour) Start key to print the Test Sheet.
If one or more of the colors is still missing from the printed page, cleaning the print head may resolve this problem. When cleaning the print head, you are given the option to clean BLACK ONLY, three colors at a time (CYAN, YELLOW, and MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then select ALL. Follow the steps listed below to clean the print head:
Cleaning the Print Head
  2. Use the up or down navigation key to select CLEANING.
  4. Use the up or down navigation key to select the color that is not printing
    -OR-
    Select ALL if more than one color is not printing.
  5. Press Set to confirm you choice.
  6. The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will display the date and time.
  7. Test by printing the "Print Quality Check Sheet":
If one or more of the ink colors is still missing from the printed page, repeat the print head cleaning steps listed above up to 4 more times. After each cleaning, print the Print Quality Check Sheet to see if there is any improvement.
I hope it helps!!!
Dec 09, 2008 | Brother DCP 115C All-In-One InkJet Printer
Printer DeskJet 820Cse didn`t work
test page printing but doc files not printing....
HP DeskJet 6940
Sep 26, 2008 | HP Deskjet 6940 InkJet Printer
Canon MP390 Printing no magenta & now nothing!
Hey Everyone!
I have an MP390 that had a similar problem over a year ago. There is a very simple fix that worked for me, and I'm pretty sure that it will work for you too. :^)
Outline:
Open the printer as though you were going to replace the ink tanks. Once opened, with the print head centered, open the latch and remove all of the ink tanks. Gently remove the print head (it should come right out, even easier than the ink cartridges). Take a paper towel, wet it with warm water, and then gently clean the bottom part of the print head. The bottom part is the part that will have an orange ribbon running to four metal openings that look like tiny nozzles. After wiping away all of the built-up gunk (on mine there was a thick sludge), grab a new and wet paper towel, and lightly press it against the nozzles. This should start sucking ink through the print head, and you will begin to see four distinct colors (CMYK) bleeding into the towel. Once done, lightly dry the print head off (make sure that there are no loose water droplets) and then reassemble everything. Print a test page and everything should work. If it doesn't change the ink tanks just to be sure.
Fortunately for you, Canon has made the print head on the MP390 very easy to service/remove, so cleaning is a snap.
Steps:
  1. Turn Printer On
  2. Open Printer As If To Change Ink Tanks
  3. Release Ink Tank Latch
  4. Remove Ink Tanks
  5. Remove Print Head (Black Plastic Assembly In Which Ink Tanks Rest)
  6. Use Wet Paper Towel (With Warm Water) To Clean Tank/Nozzle
  7. Dry Excess Water
  8. Reassemble
  9. Close Printer
  10. Print Test Page
Good luck!!!
Jul 28, 2008 | Canon SmartBase MP390 All-In-One InkJet...
Printing lighter on left side
Try cleaning the corona wire/ charge roller if this doesn't work replace the image drum
May 16, 2008 | Samsung CLP 300 Laser Printer
Logitech Cordless Mouse Logo
29 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
