Question about Makita 12 Volt Cordless Drill/Driver Kit
I can't get the drill bit out of My Makita 6333D cordless hand drill. I usually have no problem. I did tighten the chuck pretty tight, but now can't loosen it. Help.
    Problem Solver:
  • 11 Answers
Put the drill in a vise and using a pair of channel lock pliers grip the chuck and it should come loose will a little tug on the pliers
Posted on Sep 13, 2010
How do I remove the drill bit from a Makita6223D?
If your drill has the original keyless chuck on it, there are two plastic rings on the chuck. The outer ring should tighten and loosen by hand enough to hold the bit(s). The inner ring is to hold on to if the chuck gets overtightened. Chucks do wear and get corroded over time and can get locked in position. If you can't get it loose by hand, channel lock pliers can help. If the chuck is that bad you may need to replace it.
Mar 03, 2013 | Makita 9.6v Cordless Impact Driver 6903VD
How to change bits
The drill uses a cordless chuck (part bits go into) you will need to hold the outside ring of the chuck and spin it to loosen the jaws on the bit. Then spin the chuck the opposite way to tighten
Sep 26, 2012 | Makita BDF452HW Factory Reconditioned 18V...
I have just purchased a Makita 8391DWPETK 18V Cordless Combi Drill - how do i actually put a drill bit in? Do I need to take off the plastic ring?
The large black part of the chuck should turn left and right to extend (close) and retract (open) the three chuck teeth that hold the bit in place. Turn the chuck to open it far enough to get your bit fully in the chuck then turn it closed to hold the bit in. When the teeth make contact turn the chuck a bit further to get it tight enough that the bit won't slip. When you get used to it, sometimes it's easier to hold the chuck lightly and turn it by lightly squeezing the trigger to turn the chuck with the drill motor.
Feb 25, 2012 | Makita Drills
How to fix the bit
If your Makita matches the one on the picture, you will need a chuck key to attach a drill bit or tool to the machine's chuck. The chuck key inserts to any of the small holes in the front part of the chuck and at the same time its teeth interlocks with the teeth of the chuck. When turning the chuck key you will widen or loosen the grip of the three jaw pieces, that clamps to your tool or bit. Tighten the chuck key by hand until the chuck grips the bit securely. For safety, unplug the power cord whenever operating the chuck key on the chuck.
Jan 09, 2011 | Makita & 1/2 Inch Drill
How do I change the bit in the Makita 6222D 9.6V cordless drill?
put the drill in reverse hold the chuck housing ( the black plastic piece around the bit) and squeeze the trigger. Hold it tight and it will pop loose, pull out the bit reinsert new one. Put the drill in forward squeeze the housing tigh and pull the trigger it will tighten right up.
Feb 26, 2010 | Saws
Remove keyless chuck on a 12 volt makita drill
There should be a Screw in side the end of the chuck were u put the drill bit in u will have to undo it back wards its got a left hand thread
Oct 23, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
How do I change the bit on makita 6095d The drill bit is on right now and I simply want to change it to the phillips screwdriver bit. Thanks
have you opened up the chuck to remove the drill ? If not then you need to by holding the chuck tightly with your hand and then run the drill in reverse. hope this helps you
Oct 05, 2009 | Makita Drills
My chuck is broke , on my 18v makita cordless drill , how do i fix it
Put the chuck key on and strike it with a hammer counter clockwise. the chuck key must be properly seated in the hole. Once the chuck is brokrn free, you can unscrew it my hand. Buy a new chuck an screw it in olace and againm strike the key but no as hard clockwise. It will self tighten more as it is used, Good Luck-Ned-
Sep 17, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita 6405 3/8
according to my breakdown its a drill. do you checked if there is a screw inside the chuck. if there is one remove it by turning clockwise.open the chuck fully & insert allen key 5/16 or 3/8 short side to the chuck.tighten the chuck & wak the allen key with a hammer counter clockwise. do it again if required.putting back together the other way.
Jun 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 12 Volt Cordless Drill/Driver Kit Logo
377 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
