Question about Garden
Where can I purchase a patrs list for a Stihl 041 Farm Boss chainsaw ?
  • rtesh3 Sep 12, 2010
    what Iactually need is the dwawing of the saw , with the parts numbered and listed to match the
    drawing. I ran over my saw with a trailer, and cracked several of the outer parts . The diagrahm is
    the most important part.
    Thanks
    David Tesh
  • 10,515 Answers
MANUFACTURED BY: STIHL ANDREAS MASCHINENFABRIK
STUTTGART, GERMANY
SERIES OR ASSEMBLY NUMBER: 1110
YEAR INTRODUCED: 1967
YEAR DISCONTINUED: 1977
ENGINE DISPLACEMENT: 61 ccm (3.72 cu. in.)
NUMBER OF CYLINDERS: 1
CYLINDER BORE: 44mm (1.72 in.)
PISTON STROKE: 40mm (1.57 in.)
CYLINDER TYPE: Aluminum with chrome plated bore
INTAKE METHOD: Piston ported
MANUFACTURER ADVERTISED H.P.: 3.7 (5.5 HP @ 7,000 R.P.M. DIN)
WEIGHT : 6.2 kg
OPERATOR CONFIGURATION: One Man operation
HANDLEBAR SYSTEM: Rigid
CHAIN BRAKE: none
CLUTCH: Centrifugal
DRIVE TYPE: Direct
CONSTRUCTION: Die cast magnesium
MAGNETO TYPE: Bosch
CARBURETOR: Tillotson HS 29A, B, C, D,
HS-77A, B, C, HS-87A, HS-100A, HS-138A, HS-208A
MAJOR REPAIR KIT: RK-21HS for HS-87A, HS-100A
RK-23HS for all HS-29A, all HS-77, HS-138, HS-208A
MINOR REPAIR KIT: DG-3HS for HS-87A, HS-100A
DG-5HS/T for all HS-29, all HS-77, HS-138A, HS-208A
AIR FILTER SYSTEM: Nylon mesh element
STARTER TYPE: Automatic rewind (Fairbanks Morse type)
OIL PUMP: Automatic
OPERATING RPM: 6,500 to 7,000
IGNITION TIMING: 2.5mm (0.1 in.) before TDC
BREAKER POINT SETTING: 0.4mm (0.016 in.)
FLYWHEEL/COIL AIR GAP:
SPARK PLUG TYPE: Bosch WKA175T6
SPARK PLUG GAP: 0.51mm (0.020 in.)
CRANKSHAFT MAIN BEARINGS: Ball
FUEL TANK CAPACITY: 560ml
FUEL OIL RATIO: 20:1 after break in.
RECOMMENDED FUEL OCTANE: Regular
MIX OIL SPECIFICATION: Castrol 2-stroke SAE40
CHAIN PITCH: 3/8 in., optional .404 in.
CHAIN TYPE: Oregon
BAR MOUNT PATTERN:
SHORTEST GUIDE BAR SUPPLIED: 35cm (14 in.)
LONGEST GUIDE BAR SUPPLIED: 63cm (25 in.)
COLOUR SCHEME: Grey with Red top cover
PAINT CODES:
ILLUSTRATED PARTS LIST:
SERVICE MANUAL:
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 12, 2010
  • taran_2005
    taran_2005 Sep 12, 2010
    Thanks for your response!!
    You could buy it from :-
    http://cgi.ebay.com/041-Farm-Boss-Chains...
    Hope i helped you.
Farm boss starts runs great until hot then stops dead let it cool and it runs what do I try?
Most likely needs to be torn apart, the cooling fins on the engine need to be cleaned regularly, also you have carbon build up inside muffler, there is a screen inside muffler, if not clean, you will eventually get a scored piston and cylinder wall, then you will need much more to fix the issue, also make sure you are using the correct ngk plug
Sep 27, 2017 | Stihl Farm Boss Chainsaw 18"
How do I find a parts manual for a Stihl MS290 ?
You Google pretty much exactly what you wrote and you get this
[PDF]STIHL Chainsaw Illustrated Parts Lists n Workshop Service Manuals thebakeliteradio.com/sawspares.com/Stihl%20MS310%20Service%20Manual.pdf
  1. Cached
  2. Similar
MS 290, MS 310, MS 390. This service manual contains detailed descriptions of all the typical repair and servicing procedures for this power tool. As the design ...
[PDF]STIHL MS 290, 310, 390
en.stihl.ca/p/media/download/en-ca/MS_290.pdf
  1. Similar
Apr 19, 2006 - MS 290, MS 310, MS 390. English. BA_. SE .... Manual. !Warning! Because a chainsaw is a high-speed .... and the function of the parts of your.
Stihl MS 290 STIHL FARM BOSS ' Parts List - ManualOwl.com
https://www.manualowl.com/m/Stihl/MS-290-STIHL-FARM-BOSS/Manual/401004
  1. Cached
  2. Similar
Stihl MS 290 STIHL FARM BOSS ' Parts List - Page 1. STIHL MS 290, 310, 390 A Zylinder MS 290 Cylinder MS 290 Cylindre MS 290 Zylinder MS 310 Cylinder ...
Stihl MS290 Parts List and Diagram : eReplacementParts.com
www.ereplacementparts.com/stihl-ms290-chainsaw-parts-c-162329_162330_182548....
  1. Cached
  2. Similar
Need to fix your MS290 Chainsaw? We have parts, diagrams, accessories and repair advice to make your tool repairs easy.
Stihl MS290 Parts
www.barrettsmallengine.com/stihl/ms290.html
  1. Cached
  2. Similar
Find parts in the Stihl MS290 chainsaw parts list below and find where to purchase them online.
Stihl MS290 Repair manual ' Arboristsite.com
www.arboristsite.com > Forums > Equipment Forums > Chainsaw
  1. Cached
  2. Similar
Nov 4, 2008 - 20 posts - ‎18 authors Hi, I am new to this site and was looking for some help on rebuilding an MS290. I have the replacement cylinder and piston but need tips on ...
parts manual for Stihl MS290 Google Search
Dec 18, 2016 | Stihl Garden
Where to get points for 016 stihl chainsaw?
Stihl Chainsaw Parts ' Chainsaw Parts ' Discount Online Parts
https://www.discountonlineparts.com/chainsaws/?b=stihl
  1. Cached
  2. Similar
Quality Stihl replacement parts, cheap and quality available online.Handlebars and Housings · ‎Bar/Chain Combos · ‎Stihl 041 Cylinder Assembly ...
Stihl Chainsaw Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a30b354/Stihl-Chainsaw-Parts
  1. Cached
Stihl Chainsaw Parts - Shop online or call 800-269-2609. Fast shipping. Open 7 days a week. 365 day return policy.
Chainsaws ' Parts, Accessories, Reviews & Pricing ' STIHL USA
https://www.stihlusa.com/products/chain-saws/
  1. Cached
Choose from the wide selection of reliable, dependable and high performing STIHL chainsaws with low-emission technologies and quieter, more fuel-efficient ...Homeowner Saws · ‎Professional Saws · ‎Farm & Ranch Saws · ‎In-Tree Saws
Stihl Chainsaw Parts ' eBay
www.ebay.com/bhp/stihl-chainsaw-parts
  1. Cached
  2. Similar
Find great deals on eBay for Stihl Chainsaw Parts in Garden Chainsaws. Shop with confidence.
Home ' STIHL
en.stihl.ca/index.aspx
  1. Cached
  2. Similar
STIHL - Information about the STIHL Group and our extensive range of chain saws and ... About us More than the world's most successful chain saw brand. stihl chainsaw Google Search
Nov 23, 2016 | Stihl Garden
Any complaints of saw catching fire?
Not really, but if you've had the issue, maybe the vent tube is allowing gas to be dripped into the carbuetor compartment behind the filter. Sometimes, when held horizontally, they will leak a bit out and older saws sometimes have the vent line to deteriorate from the alcohol in todays fuels causing a few drops of gas to escape. I've worn out two 041 Farm Boss saws and never a problem other than normal maintenance.
Mar 15, 2015 | Stihl 041 Av, Farm Boss Chainsaw Intake...
How do i clean oiler for chain on stihl farm boss?
The filter could be stuffed with sawdust, but depending on the model of saw, the problem could also be the oil pump drive system.
First of all though, empty out the chain oil and then part fill the chain oil tank with petrol, replace the cap and with the saw switched off, shake the saw violently for 10 secs. Remove the cap and empty out the tank and then refill with chain oil and try out the saw, revving it and check if any oil is flowing onto the chain.
If that has not solved the problem, let me know what the model of the saw is, Farm Boss is not enough, it could be an 038 an 041 and a few more as the farm boss name is used as well as the number.
We can then check a few other points which could be causing the problem.
Sep 16, 2014 | Stihl Farm Boss Chainsaw 16"
How do I find Stihl 041 s/n with silver sticker gone?
you cant. that is the only serial number on the machine
Apr 16, 2010 | Garden
Garden Logo
82 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
