Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
My leaf blower had been working fine until the other day. I went to start it and it would not start. I changed the plug, cleaned the carburetor, A friend checked it and said it was not getting fire. any suggestions?
    Problem Solver:
  • 11 Answers
If its not getting any fire then check the coil it may be bad
Posted on Sep 13, 2010
My Dyson leaf blower will not start
replace the spark plug would be the first thing. if still no start the carburetor is probably dirty or clogged. it will need to be cleaned or rebuilt. try a squirt if carburetor cleaner in the opening of the carburetor if it starts for a few seconds and dies. it is the carburetor.
Sep 18, 2016 | Garden
Craftsman 32cc/170 mph leaf blower. Why does it die after a few minutes running?
Is this a consistent situation? Starts, runs then dies after a little while?
If so, sounds like carburetor/fuel pump (which is a one way diagraphm) issue.
Take carburetor apart, and also obtain a rebuild kit for it. Clean it well, compressed air through all the jets, replace the parts from the kit and reassemble. Re-install back onto unit.
Also... Replace Spark Plug, fuel filter and clean the spark Arrestor screen at muffler.
May 26, 2015 | Craftsman Garden
I have a ryobi leaf blower that is leaking gas. It seems to be coming from the carb. The leak started when I changed the fuel lines. I then cleaned out the carburetor. It ran fine for one day and now the...
It sounds like maybe you tore the gasket that attaches the carb to the block. Check that, Also make sure your screws holding the carb. in place are tightened.
Mar 10, 2015 | Ryobi Garden
My craftsman 25cc leaf blower wont start
pull the plug, plug into wire, touch head of plug to metal on engine. hold by rubber boot while touching pull starter, see if you get a spark across the plug gap, its small but you can see it. if no spark check switch. if plenty of spark clean fuel system and check primer
Nov 04, 2014 | Garden
Carburetor
either carburetor needs cleaning or check the Flame Arrestor on the muffler...they clog and engine can't Rev high
Sep 08, 2013 | Husqvarna 130BT 29.5CC Gas Leaf Blower...
I have a Echo leaf blower and I can get it running but then it's cuts off after just a few seconds. It has new plug, air filter and fuel filter. What else could it be?
The carburetor could be dirty and need a good cleaning and you could first remove the fuel pump cover (cover without the vent hole) to the carburetor and look for the small, round, fine-mesh screen. Sometimes it gets covered with dirt and debris and has to be cleaned as it allows the fuel to flow into the metering side of the carburetor.
Dec 04, 2010 | ECHO, Inc. PB-251C Handheld Blower
The leaf blower won't start and I did change the spark plug and last time it run for like 30 sec. before it shut down again.
Main cause of small gasoline engine failure is carburetor clogged. Try spraying carburetor cleaner into carburetor and intake. Check if unit has air cleaner. If engine starts briefly with cleaner then carburetor needs manual cleaning. Carburetor removal and overhaul.
Jul 10, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Homelite yard blower won't start
1st how old is the gas and 2nd how long did it sit for since you last used it? If there was any old fuel left in before now (more than 14 days) than it is possible your carb needs cleaning. If it's less than 14 days then you might want to check the compression. IF you have good compression, then you might want to take it to a service center to have it diagnosed.
Dec 27, 2008 | Homelite 'Yard Broom' Leaf Blower
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
179 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
