Question about Bissell 6596 Bagless Upright Vacuum
Is there a way to isolate the vacuum force to just the hose?
    President:
  • 1,514 Answers
I'm afraid the answer is no. The vacuum force cannot be isolated to just the hose.
Posted on Sep 12, 2010
I have a Electrolux Vacuum that is around 25 years old. It works good, except the hose is stopped up. I would like to know how to go about unstopping the hose.
What may work is to hook another vacuum like a shop vacuum to the hose backward to try to suck whatever is in the hose out.
Another thing to try is completely disconnect the hose and try running water through it backward. (less messy to do this outside.)
Or just get a straight stick long enough and work it to loosen whatever is clogging the hose. Don't force it though.
Nov 12, 2016 | Electrolux Vacuums
No suction on my dyson dc27
Most common cause of loss of suction are objects being lodged. You can isolate the area pretty simply. Put your hand to the tube on the detatchable handle. If there is suction there the obstruction is at the base. To clear this turn the vacuum over and lay it down. There is a suction hose that attaches just behind rotating sweeper. Disconect it, and check for debris. Also look in the sweeper compartment for hair, and other clogs. Re-Attach, to see if this remedied the problem.
If the loss of suction is somewhere in the detachable handle. What i have done is disconnect it from the unit... Take a wire hanger or similar and carefully run it through the hose. Be careful not to puncture the hose.
Jul 19, 2014 | Dyson DC27 Bagless Upright Vacuum
Question re hose and head
Hi There,
Ok so the hose definitely cannot be interchanged, all the dysons have a different (slightly) fitting where the hose clips to the vacuum. The head I think can be fitted from a DC19. To be sure I would buy the correct one for your model. Dyson have a bad habit of using different fittings for different models to force you into buying the proper dyson one. With the DC05 and earlier you could adapt heads from normal vacuums but they stopped it from dc08 on.
May 22, 2012 | Dyson DC08 Hepa Allergy Bagless Canister...
Small potato (yes) stuck in hose, dont know how to reverse. tyvm
Possibly, find the location in the vacuum hose, where the potato is stuck, squeeze the hose there to force the potato to break up into smaller pieces that can be sucked through. If it is stuck in the "wand" the solid part, a straightened out wire coat hanger, may suit, instead, but be extremely careful with that, as the wire may pierce the hose. Alternatively, you can reverse, by plugging the hose into the "exhaust" .
Apr 24, 2012 | Electrolux Epic 6500 Vacuum
The Expandable Tube has come out of its plastic holding leaving the plastic holding still in the wand arm how do I release this Plastic hose clip so I can replace the flexible hose
If you force anything on these plastic vacuums you will break something and be worse off. I recommend taking it to your local used Vacuum store as they can give you the best advice by seeing the pieces. Thanks hope this helped
Oct 07, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
My hose will not come out and extend. If I can
Hi its Darran at Dyson.
If you are able to remove the hose and wand assembly, its worth checking for a blockage as this can cause the wand/hose to be difficult to remove and put back in place.
If you need further assistance, please call our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Apr 13, 2010 | Dyson DC15 All Floors - The Ball Bagless...
My Dyson DC20 motorhead vacuum has a blocked hose - how can I unclog this? I think there is a sock caught up by the handle. The hose has electrical wires running through it so I cannot cut the hose.
Usually a plugged hose can be cleared using a broom handle, if you can force the blockage through, if not as previously suggested a coat hanger attached to the broom handle (duck tape will do) straighten out hanger so it can be used like a cork screw to screw into the blockage and pull it out, socks,underwear and pantyhose are the usual suspects!
Nov 06, 2009 | Dyson DC05 Cylinder Bagless Canister...
Beater attachment has no suction.
Your hose issue is isolated from the garage. You have a switch problem in the handle of the hose.
If the hose has a swivel handle your problem will lie in the switch itself or the contact rings within the lower portion of the handle itself. If this is a light gray hose with swivel handle several years old switches were an issue from time to time . The problem can normally be fixed by replacing the internal wiring harness in the hose.
Oct 03, 2009 | Easy Flo EF1600 Central System Vacuum
Telescope wont retract into hose
get a replacement hose witch is fairly hard to fit
Aug 23, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Bissell 6596 Bagless Upright Vacuum Logo
19 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
