Question about Microwave Ovens
I need to change the blade in my Braun blender, model 4 184. And I cannot loosen the old blade. I see no way to unscrew it. Please help
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 7 Answers
Just a suggestion: look underneath - there may be 2 prongs that you have to press together to push out, rather than having to unscrew it.
Posted on Sep 12, 2010
Is the blades supposed to come off when I take the container off of the blender.. My blender is brand new sat for 3 or 4 years after I bought it. . The first time I used it , it was extremely hard to get...
You did not specify a brand or model number of your blender; however, most blender jars will lift off their power base without turning or with only very little turning motion to release them from the base. The blade assembly should NOT come off as you remove the blender jar from the power base.
Were you successful in removing the bottom ring which normally screws on to the bottom of the blender jar from the powerbase?
You should make sure you have properly attached the blade assembly for your brand/model.
The blender blade assembly should be held on to the bottom of the blender jar by the bottom ring which screws on clockwise; most will have a sealing gasket that fits between the blade assembly and the sealing surface of the blender jar to prevent any leakage while in use. It will take much more turning to unscrew the bottom ring to release the blade assembly than it should to release the bottom ring from the powerbase.
Assemble your blender jar and blade assembly and try a dry run by placing on the powerbase, giving a couple of bursts of power, and then seeing if you are able to remove without the blender ring unscrewing.
Make sure you are comfortable with the action required to remove the blender jar from the powerbase before you put in to use.
Jul 31, 2011 | Microwave Ovens
I need the instruction booklet for the Braun MX250 blender.
http://www.service.braun.com/home.asp?rg=NA&c=US&l=GB&typ=ui&s=&seite=&sString=
hope this link helps. it's the braun website. you will probably need the model number.
thanks,
mike
Jul 08, 2011 | Microwave Ovens
I need a gasket for my sunbeam blender/coffee mill model 2774 .
Hi and welcome to FixYa, I am Kelly:
Here are the parts that are available for your unit:
http://www.ereplacementparts.com/sunbeam-2774-blender-parts-c-116440_116442_116457.html?osCsid=rr7g7e3p7s5jfnk4rmdsk8cve2
I am assuming you need the gasket that is part of item 2 and comes with the blade assembly.
Note that it is back ordered and not available until 3/23/2011.
The part number is: 123250-000-000 Do a net search using the part number (images) and you will find other sources.
Thanks for choosing FixYa,
Kelly
Mar 12, 2011 | Microwave Ovens
Braun immersion blender model 4172HB how to clean
I would be inclined to switch it on in warm washing up water. That will clean the blades.
Hope that helps.
Feb 28, 2011 | Microwave Ovens
My blender won't power on, the lights don't turn on. I've had the blender for 1 year and have never had any problems with it. In the past month it would only work intermittently, and now it doesn't work...
sometimes something (food etc) gets "stuck" in the lock mechanism, preventing it from turning. unplug the blender and give the locking mechanism a cleaning with a bottle brush or rinsing it under very hot water. also the lock could be broken/chipped, also preventing it from turning.
i must admit that I broke my locking mechanism 5 years ago by not "seating" it correctly and forcing it. my hubby somehow removed! the locking mechanism but now it goes on - turns - as soon as I plug my blender in (because the stop/lock doesn't exist anymore). so I must be very careful to always have the lid on before I plug it in. but it's a braun blender and I love it. so i've kept it all this time.
Oct 06, 2010 | Microwave Ovens
Could you please explain how I can remove the motor from the casing of my Delonghi coffee grinder model DCG-2. As far as I can see I need to remove the s/s cutting blade....is this a press fit or...
Is your unit still under Warranty? If so, your warranty will be void if you do any kind of maintanence before contacting the Customer Service Department first. What area do you live in?
Jun 02, 2010 | Microwave Ovens
How do you replace the ligth bulb in the GE Microwave Oven JE1590sh01
On this model, you need to remove the outside cover, then you'll see the bulb on the right side, mounted in an air duct.
Please unplug it before taking it apart.
If your model has anti-tamper screws, you can remove them using using a T20H Torx type or GTXH20-100 screwdriver. If the correct tool is not available, there are several ways to remove the screws:
- Use a hammer and a small punch or similar tool to knock out the middle post of the screw, then use a standard T20 Torx bit to remove the screws. (Use safety glasses).
- Insert a small flat-bladed screwdriver (such as a jeweler’s type) into the slot between the post and the edge, tap the screwdriver firmly with a hammer to loosen the screw, grip the screwdriver with pliers, and remove the screw.
- Use a hacksaw or Dremel tool to cut a slot in the head of the screw, then use a flat-bladed screwdriver to remove the screws. (Use safety glasses).
This is a bulb assembly with the socket included. It does not unscrew.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 03, 2008 | Microwave Ovens
Microwave Ovens Logo
60 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
