Question about Refrigerators
I have a kenmore elite model 70203990 with a top freezer. Noticed this morning most items in the freezer are thawed and the setting is on high. I can hear it running but the air coming out is not ice cold. The refrigerator is also running on high and it appears to be warm also. Both sides of the unit near the front are very hot! Any idea what the problem could be.
Sea Breeze
  • 4654 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
SOURCE: Ice maker not working. Kenmore Elite with bottom
Ice maker making continuous clicking sounds after several day power outage.
Posted on Mar 03, 2010
rickead1
  • 1998 Answers
SOURCE: Kenmore SbS refrigerator, water dispenser not working
lol ok the big black cauldron thing is your compressor there are two fans one near the compressor and one inside the freezer which ever one is not working replace and if its the one near the compressor unplug the machine till you do
Posted on Apr 30, 2010
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
I had the same problem with our Whirlpool Gold. Which by the way was just out of warranty. The guy who repaired the problem told us that since there were so many replacement dispenser motors at different supply locations that there must be a problem. I think that the root cause is the arm in the ice holder is hard to move, and it burns the dispenser ( #2252130) motor out. Whirlpool should get to the bottom of this and offer free or reduced repairs. Motor # 2252130
Posted on Jul 29, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Refrigerator Trio display panel read
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
Kenmore Model 10654613300 Freezer over freezing
In the freezer side there is a panel in the back. behind the panel are the evaporators. over the evaporators are heaters you will find one of then broken from water dropping on it the bottom one was broken on mine. put a fan to the freezer and thaw it out. get the model and serial numbers and look on ebay.com. or there is a place called http://www.repairclinic.com/
These are not hard to change but above all UNPLUG THE FRIG OR THEY MAY PUT YOU IN ONE.
Hope this helps.
Sep 21, 2014 | Kenmore Elite Side By Side Refrigerator -...
Motor runs for 5 seconds then clicks off
We had our system Kenmore Elite not keeping the freezer cool or the refrigerator. I pulled out the unit and cleaned the condenser coils. This solved our issues, hope this helps.
Jan 05, 2014 | Kenmore 74252 / 74254 / 74259 Top Freezer...
Maytag refrigerator / freezer compressor fan not running and some items in freezer appear to be thawing
Check to see if the fan mount bent somehow. The fan blade just might be jammed. If not see if the fan is getting power. The unit will not cool properly if the compressor and condenser are not being cooled down by that fan.
Dec 31, 2012 | Maytag Refrigerators
My kenmore elite side by side refrigerator isn't cooling properly
I need your model number I cannot pull up views without the model number. The number most times looks like 321.654987 Thank You, Sea Breeze
12_9_2012_3_01_59_pm.jpgKenmore
Dec 08, 2012 | Kenmore Elite Side By Side Refrigerator -...
The freezer half stopped working Sunday morning, and the items on the top were thawed more then items on the bottom. We left it a couple hours and it started working again.
Sounds like your defrost thermostat is not working.
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
Oct 11, 2010 | Kenmore 57029 Side by Side Refrigerator
I smelled an electrical burning smell and noticed that my freezer items were thawing. Is it the motor?
If your refer is over four years old and a Kenmore good odds are higher than not that the compressor has failed.
Nov 22, 2009 | Kenmore Refrigerators
Kenmore elite side-by-side ice maker creaking!
Look behind the freezer rear trim panel for frosted/iced evap. coils and thaw if necessary.
Oct 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a 19-year-old Kenmore top freezer refrigerator (model #1069610513). The freezer seems fine, but the fridge is warm. It was fine last night but when I opened it this morning the milk felt like room...
You might be developing an ice dam in the bottom tray of thr freezer that is obstucting the flow of cold air to the refigerater part of the unit. remove frozen items so you can see the bottom tray and see if you notice an exccesive amount of frosting on said floor tray, if so you are probably experiancing a defrosting problem.Check to see if you can feel cold air coming in from the top back section of the refrigerator. There is a fan that blows across the coils in the freezer section under the floor tray, if you cant feel the air either your fan has quit or you are froze shut.You can try a temp fix by removing food items to a cooler with ice or another unit and unplugging this one and letting it thaw out, be sure and put down a towl or two on the floor the tawing ice will go to the evaporater tray underneath and overflow once its thawed plug it back in and let it cool down. Check again to see if you can feel air in the frig. if you cant your fan has quit, you need to seek local appliance tech help they should be able to get you going for a fairly inexpencive amount.
Jul 12, 2009 | Kenmore Refrigerators
The Freezer and Refrigerator has stopped working completely
first check to see if the compressor and fan on the lower back of frig is working,if it is then check the freezer to see if the freezer fan is working,if it is then find the defrost timer(most of the time behind the front grill or inside frig. or on lower back)turn it til it clicks,wait 30 minutes and see if it comes out of defrost(you k=will know this if the freezer fan comes back on,let me know what you find-mike
Apr 16, 2009 | Refrigerators
Refrigerators Logo
105 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
