Question about Kodak EASYSHARE Plus Series 3 Thermal Photo Printer
Kodak easyshare plus series 3
My printer will not feed the paper. I have cleaned the roller and it still does not work. What should I do?
    Problem Solver:
  • 16 Answers
There is dust, dirt, or debris on the feed roller, and it is slipping.
clean the roller with witch hazel or a solution of isopropal rubbing alcohol and water shaken to dilute the alcohol. Make sure clean and dry, if able soak with baby oil and let set over night and repeat step one.
Posted on Jul 07, 2008
  • onlyintheate Jul 07, 2008
    Also check to see if the handler is lifting the paper
    keep cleaning!!
    For every 20 pics you've processed you have added a thousanth of an inch of dirt
My pictures are coming out with pink or purple streaks. Every time I print a picture, the streaks are in different places, all going from bottom left to top right . I have changed the ink roll and the...
Try cleaning the paint roller.
6 Care and maintenance
Cleaning the paper feed roller To prevent misfeeds and to make sure your pictures look their best, we recommend that you keep the paper feed roller clean. Inspect the roller weekly for debris particles, and clean if necessary.
IMPORTANT: Unplug the power before cleaning the paper feed roller.
spacer.gif spacer.gif spacer.gif spacer.gif 1.Unplug the AC power cord from the power outlet.
2.Remove the paper tray from the photo printer, and leave the paper tray door open.
3.Lightly moisten a lint-free cloth with water.
IMPORTANT: Do not use cotton or cotton swabs to clean the paper feed roller.
autourg00462006id1604162.jpg 4.Use the moistened cloth to gently wipe clean the surface of the paper feed roller. Advance the feed roller with your thumb as necessary, and continue cleaning.
5.Allow the paper feed roller to fully dry before reconnecting the power.
Click below for the complete manual:
Kodak EasyShare Photo Printer 500 Manual
Hope this helps.
Zeppelinx12
Mar 11, 2011 | Kodak EasyShare Photo Printer 500
Only prints half way and doesn't grab paper right away
Here are the steps:
1.Remove the power cable from the printer.
2.Remove the paper tray from the printer and leave the
of the roller.
5.Let the feed roller dry before plugging back the AC
power cord
6. Fan the paper to keep the sheets from sticking
together.
7.Place 15 - 20 sheets of paper into the paper tray
8.Insert the paper tray into the printer.
9. Make a print.
If issue persists, call 1.800.235.6325 for repair.
Sep 24, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Paper will not feed into the EasyShare printer Dock series 3.
The paper sensor in the printer might be disturbed please check that one.
Jul 02, 2009 | Kodak EasyShare Printer Dock Series 3
I have an Easy Share printer dock series 3 that has paper loaded
To prevent misfeeds and to make sure your pictures look their best, we recommend that you keep the feed roller clean. IMPORTANT: Unplug the power before cleaning the feed rollers.
  1. Unplug the AC power cord from the power outlet.
  2. Remove the paper tray from the printer, and leave the paper tray door open. IMPORTANT: Do not use cotton or cotton swabs to clean the feed roller.
  3. Lightly moisten a lint-free cloth with water.
  4. Use the moistened cloth to gently wipe clean the surface of the feed roller. Advance the feed roller with your thumb as necessary, and continue cleaning.
  5. Let the feed roller dry fully before plugging the AC power cord back into the power outlet.
  6. Insert the paper tray into the printer, then press the Print button to resume printing.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
5300 won't load 8 1/2x 11 photo-weight paper.
''grabber'' roller out of work sometimes, you may try
1) there is a input paper sensor around roller, the roller out of runing if the sensor is not senitive enough or sensor switch dirty,
clean the sensor as you can find it,
2) Lighter-weight paper feeds and prints fine, which means this paper input sensor works ok, but you need to make sure they are same paper input sensor,.
3) the paper surface bright and the roller worn could be cause paper feed fail, you need clean the roller anyway. still not fixed, you need to adjust the roller pressure by increase the spring force.`
Feb 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Dirty rollers? I had the same problem and think the rollers are no longer sticky enough to pick up the paper due to a coating of dust... maybe cleaning the rollers would work?
Jan 28, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Paper won't feed, HP printer dock series 3
I had this problem (among many others with my printer). I found that just cleaning the front roller with a damp paper towel fixed it. Wipe it carefully and let it dry before reloading the paper. The rubber on the roller seems to lose it's ability to pick up the paper if it sits unused for any length of time, so wiping it with warm water and drying it works. Good luck. Lynette
Aug 28, 2008 | Kodak EASYSHARE Plus Series 3 Thermal...
Kodak series 3 printer dock
The roller is dirty, clean first with rubbing alcohol or witch hazel with a cotton swab, try that
Feb 26, 2008 | Kodak EASYSHARE Plus Series 3 Thermal...
Paper won't load into the printer
clean the pick up roller with witch hazel and a cotton swap repaet a couple of times, may be very dirty
Feb 24, 2008 | Kodak EASYSHARE Plus Series 3 Thermal...
Easy share printer series 3 won't pull the paper through.
Nov 04, 2007 | Kodak EASYSHARE Plus Series 3 Thermal...
Kodak EASYSHARE Plus Series 3 Thermal Photo Printer Logo
54 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
