Question about Bulova Marine Star Steel 98A000 Watch
Como puedo " " Configurar la Alarma del Bulova Marina estrellas
Where i can buy a new strap for my nautica watch or where is the service center here in the philippines more better f you have service center in iloilo city??tnx
You might be able to buy the watch line at this website
Nautica watchstraps
In Philippines you can also contact distributor for Nautica watches
Distributor
TIME DEPOT
380 Del Monte Ave.
DSL Bldg.
Quezon City, Phillippines
Phone: 632 743-5219 EXT: 26
Fax: 632 731-7753
Email: inquiry@timedepot.com.ph
Or Nautica support at
TIME DEPOT
UNIT 306 LEVEL R3 POWERPLANT MALL ROCKWELL CENTER
AMAPOLA COR. ESTRELLA STREET
MAKATI CITY
Phone: +632.659.6723
Fax: +632 7317753
Jul 31, 2014 | Watches
Como cambiar fecha en casio g shock gw3000b
Hola,
Aqui puede encontrar la ficha completa del reloj:
http://www.tictacarea.com/es/relojes-casio/4557-reloj-casio-g-shock-gw-3000b-1aer.html
En este enlace puede descargar el manual :
http://www.tictacarea.com/es/index.php?controller=attachment&id_attachment=5
Si tiene cualquier duda puede consultarnos,
Distribuidores oficiales de Relojes Casio
TictacArea.com
Jun 08, 2014 | Casio G-Shock GW300CA-1V Wrist Watch
Eve mon crois watch 9441-FS instruktionbook
Watch controls (eve mon crois) TL= top left button TR= top right button BL= bottom left button BR= bottom right button TL= toggle light TR= view date BR= view alarm time BL= toggle options 1 press --> stopwatch 2 press --> change alarm time 3 press --> change digital time 4 press --> return to regular view (When on option) Stopwatch: TR= stop/start stopwatch BR= reset stopwatch time BL= next option Change alarm time: TR= +1 to selected (flashing) unit BR= change selected (flashing) unit BL= next option Change digital time: TR= +1 to selected (flashing) unit BR= change selected (flashing) unit BL= next option Normal view: (controls shown at top) In normal view when: TR is held down --> BR= toggle alarm on/off TL is held down --> BL= toggle through days BR is held down --> TR= toggle alarm on/off (for accurate digital time go to the option of change digital time and set it to the next minute from when you are make sure that the the counting seconds are flashing. When the next minute comes press TR this will reset the seconds to '00' without changing the minute and you will now be accurate to the clock you used by less than a second) I got this info through a long time of just experimenting with the buttons, still working on finding a way of changing the date but for now this should be enough to get you by with the watch. Hope this helps somebody :)
Jan 30, 2014 | Watches
How to change a timex wr50m from military time to regular time
in the setting after you have set the date, you have to choose whether 12 or 24. choose 12.
Jul 14, 2011 | Watches
Hi i have an aviator watch avw7770G59 and i can't change the date ?? please help me by which button should i press
disculpe queria saber a que precio tiene el reloj aviator reloj_ caballero clave a v w 7 7 7 o g 5 9 y keria aber si me podrian vender el puro cascaron la caja eske ya teno la caja y la tapa
Jul 01, 2011 | Bulova Watch
Como porfabor puedo descargar o obtener el manual de instrursiones de mi relo Citizen eco driver e310 pero no se cual es el modelo aqui le dejo porfavor alguno de los datos que tiene en la tapa y en la...
HOLA YASSERDIDIE !!!!!!!
ENCONTRE UNA PAGINA DONDE VIENE UN MANUAL PARA EL RELOJ CITIZEN E310, ES UN ARCHIVO EN PDF Y VIENE EN ESPA?OL
EL LINK ES: http://sumanual.com/instrucciones-guia-manual/CITIZEN%20WATCH/E310-_S
ESPERO SEA EL MISMO MODELO QUE TU RELOJ Y QUE MI INFORMACION TE SIRVA PARA RESOLVER TU PROBLEMA. :)
Apr 29, 2011 | Citizen EcoDrive Calibre 3100 BT000007E...
What are the functions of buttons on 98B106
I was unable to find the model 96B106 in their range but I did find 98B106. I this is the watch you have, then go to http://www.bulova.com/watches/bulova/marine-star/98b106/ and download the usermanual.
Apr 07, 2011 | Bulova Chronograph Marine Star #96B99...
How do i set the time on a dunlop sports watch?
Ma montre , spur DUNLOP dun 103 g10 , est pourvue d'une feuille explicative concernant un mod?le diff?rant !
2 personnes ont pass? des heures ? essayer de la r?gler sans succ?s
comment ? puis-je la rendre fonctionnelle ?
Merci de votre r?ponse
Meilleures salutations
Gerry GRAEF
50, rue du Premier-Mars
CH-2206 Les Geneveys-sur-Coffrane
Sep 23, 2010 | Bulova Watch
Bulova Marine Star Steel 98A000 Watch Logo
60 people viewed this question
Top Bulova Watches Experts
Geoff
Jimmy Accardi
Are you a Bulova Watch Expert? Answer questions, earn points and help others
