Question about Singer 1507
I cannot get the bobbin thread to come up through the top and I have followed the instructions on the Singer site. I cannot find my manual.
    Genius:
  • 1,788 Answers
Download your manual at singerco.com, it is free. Make sure your needle is inserted with the flat side facing a way from you and that the bobbin thread is threaded the right way.
Posted on Sep 12, 2010
  • vdeath Aug 17, 2011
    I am looking for the singer 1507 manual and i cannot find it online
How to thread the bobbin of a singer 90s
First make sure that the needle is fully up (use the hand-wheel). Move the bobbin cover release button to the right and lift the bobbin cover out of the way. Remove the current bobbin, if needed. Hold the new, full bobbin so that the thread comes off the bobbin counter-clockwise when you pull the thread. Place the bobbin into the bobbin case. Pull the thread through the slot near the bottom of the case and to the left. Place a finger on top of the bobbin. Next bring the thread left further towards the back of the bobbin case until it stops in the second slot (near the 8 o'clock position if you compare the position to a 12-hour analog clock). Pull the thread back through the groove in the cover plate until it is cut by the thread cutter at the top left of the cover plate. (The thread will turn a "corner" to the cutter.) Replace the bobbin cover.
Singer has the manual for most of their sewing machines here: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the 90S is http://www.singerco.com/uploads/download/26e7243ab52aaed42904377fea7b090541eb0c9b.pdf . See pages 16-17 (page 18 in the PDF for the English description) and pictures that may be better than the verbal description.
I hope this helps.
Dec 23, 2016 | Singer Sewing Machines
I am having trouble getting the bobbin to function properly during sewing.
It could be the top thread is the problem. Might try removing all the thread. Consult the owner's manual for threading instructions. RAISE the presser foot BEFORE threading the upper thread so the thread will seat properly in the tension disk. Re-thread from the beginning carefully following the instructions--do not miss any spots or thread guides.
If top thread is still creating a mess of loops under the fabric, try tightening the upper tension. The tension is ideal when both upper and bobbin threads meet in the middle of the fabric.
Dec 10, 2015 | Singer 5160 Mechanical Sewing Machine
How to thread HD110 heavy duty singer
Here's a link to the manual for the machine. You should find your answer there.
Singer Sewing Machine User Manual ManualsOnline com
Apr 04, 2015 | Singer Sewing Machines
My Singer 648 is having a problem with the bobbin thread getting caught up in the bobbin case and jamming the thread inside the case breaking the thread. Is there a solution to this problem? Thanks
try changing the needle
make sure the top thread has not come off the thread take up lever
try another bobbin
make sure the bobbin is turned the right way in the bobbin case
try rethread the machine top and bobbin
clean under needle plate and in the bobbin area for lint or threads
Jan 06, 2013 | Sewing Machines
How to thread a bobbin on singer 4411 sewing machine
If you've threaded the bobbin per instructions... then make sure your needle isn't damaged, bent, or dull. Also make sure the needle is seated fully and correctly oriented into the needle bar.
Aug 24, 2012 | Singer Sewing Machines
Hi I am having problems with the top tension on my Singer 2662. I am following the instruction manual but nothing I seem to try works. Or it works for a while and then the next time I sew I have problems...
I would suggest that you revisit the threading up in your manual and double check that the top thread is under tension.
However, if the stitiching on top of the fabric is wonky, this is your bottom tension too loose, and if stitching on the the underside of the fabric is loose, its the top tension causing it.
Quite often bobbin winding can be the cause of bad stitching so pull out the manual and wind a bobbin carefully following the instructions, making sure that the thread is under gentle tension as it winds. What you don't want is for the thread spool to bounce around as it unwinds onto the bobbin as this gives uneven tension of the thread and when you then stitch a seam, the thread relaxes in different amounts causing puckering.
So wind at 3/4 speed, and gently guide the thread onto the bobbin so it fills evenly across the whole core. And ensure there is tension on via a tension guide if your machine has one. If not, then place the curved handle of your scissors onto the top of the thread spool and hold it there as you wind, which holds the spool down and keeps the thread coming off it smoothly.
Always raise the pressure foot when you thread the machine so the top thread goes into tension fully. And new needle for each new sewing job is really important, make sure it is the right size and type of needle for the fabric you are sewing. if you aren't sure what size is right www.sewing.about.com has great tips and general machine info, plus needle guides.
Jun 11, 2011 | Singer 2662
Seat the bobbin & adjust tension on Singer 9018
basic tension instructions apply...bottom tension should be moderate, thread should pass when holding thread and dangle the case. Top tension should pull bottom thread JUST to the top side of fabric. thread bobbin case counter clockwise.
May 31, 2010 | Singer 3116 Simple
I purchased singer bobbins to use in my singer 5050. I thread the machine and bobbin per manual instructions, but when sewing, the thread severely bunchens and knots up on the bottom side of the item I'm...
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Sep 30, 2009 | Singer 5050 Mechanical Sewing Machine
Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Aug 16, 2009 | Singer Quantum XL-5000 Computerized Sewing...
Singer CG-590
You can find a Users Manual plus a workbook that you can get in PDF and print. Users Manual is 44 pages and workbook is 58 pages. Go to www.mannualowl.com and search for Singer CG 590n manual. It's all free.
Apr 19, 2008 | Brother CS-8072 Computerized Sewing...
Singer 1507 Logo
258 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
