Question about Victor Welding Tools
I have a victor firepower acetylene regulator that no longer works as it shows pressure on cylinder side but will not pass acetylene. regulator is SA568 and model 150-15. Can I purchase a repair kit?
3 Suggested Answers
  • 384 Answers
SOURCE: I have a Firepower oxygen regulator Model #
Yes, use an "O" ring.
Posted on Aug 06, 2009
  • 13 Answers
SOURCE: the oxygen regulator will slowly climb and not
bad o2 reg.
Posted on Mar 06, 2010
Where is the inlet regulator on my karcher 3300 high pressure washer
no inlet pressure regulator as they work of mains pressure
the only pressure regulator ther eis works off the wand trigger
when the trigger is pulled the pressure in the line drops off and the regulator switches on the motor to produce high pressure
when the trigger is let off the regulator reads the pressure and shuts off the pump;or allows the pressure to by pass back to the inlet side of the pump
Oct 30, 2016 | Karcher Garden
Who fixes Victor acetylene valves
welding gas regulators and torches and valves can be sent to:
Matheson Tri gas
251 Scott Ave
Farmington, New Mexico 87401
They will be repaired and returned to owner
Aug 25, 2014 | Welding Tools
Who fixes Victor acetylene valves?
Contact a local welding supply vendor, they should be able to direct you to someone qualified to do the job.
Aug 25, 2014 | Thermadyne Industries 0781-3909 Victor...
Hi there, despite brand new torch, brand new regulators and gas tanks, I cannot get a decent hot flame on my oxyacetylene torch, and what flame I can get, goes out within seconds of heating a...
Hi:
If your flame goes out check the following:a) check your acetylene and oxygen pressure, for this kind of job acetylene should be at 4 psi and oxygen at 10.b) Check you're using the right type of nozzle for the job and this nozzle is clean.
Apr 04, 2011 | Smith 23-1001C OXY/ACETYLENE LITTLE TORCH...
What do i have to do to convert a n acetylene torch to use propane?
usually I have just changed to the appropriate brand of propane tip for that style torch IE: if you use a victor torch take out the acetylene tip and replace it with a propane one making certaing the seats are correct.
Mar 27, 2011 | Victor ® 000TE Replaceable Tip End ®...
Torch will only light when oxygen tank is off. Gas is coming out with either valve open. When oxygen tank is on, flame goes out. Thank you for any assistance, knowledge you may provide. Tim O'Brien
Is the flame you are getting a carbonising flame? ie. is there a lot of soot in the flame? It sounds like your oxygen regulator is faulty and not regulating, blowing out your flame as soon as you open the oxygen bottle. The acetylene side seems to be ok but have the oxygen regulator overhauled.
Mar 08, 2011 | Firepower FPW03842600 Cutskill Heavy Duty...
Victor cga 540 oxy reg. hi side 2000. lo side climbs to max and pop off releases. can adj for short then climbs and releases at pop off
take it to the nearest weld shop, its defective, gages, do one thing, keep pressure where you put it, there is a spring inside and it can get weak by leaving it turned in,
please, take it to a shop, before it fails.
Mar 03, 2011 | Victor CSR350D Oxygen Regulator
Can't control pressure on victor oxygen regulator
One gage is fixed for tank volume the other is variable for you to set for process. if the variable gage dose not work you may have a bad diofram. You could purchase replacement repair parts at your welding supply store.
Mar 02, 2009 | Victor CSR350D Oxygen Regulator
Welding Tools Logo
181 people viewed this question
Top Victor Welding Tools Experts
Bill Boyd
Are you a Victor Welding Tool Expert? Answer questions, earn points and help others
