Question about Rosewill R900J 19" Flat Panel LCD Monitor
After using my home computer for an hour or so and then leaving, but it is still on and when I return in 2 hours the screen is black and will not return to home page when mouse is touched. I have to turn everything off and then it will come back on. thanks
    President:
  • 2,571 Answers
OK you need to change your power settings. This decides what your computer will do when left for a period of time, it may be best to change everything to always on if you cant wake it up from hybernation, check here Control Panel\All Control Panel Items\Power Options
Posted on Sep 12, 2010
Why the black screen on my pc?
It really could be a lot of things. The four that immediately spring to mind are
1. Your screen is broken
2. Your computer is slow and is going through a cascade of data which may take a long time. Leave it alone and come back to it in an hour. Or even 2 hours.
3. Your Video driver may be corrupt or missing. If this is the case, a new driver needs to be installed. This is difficult when one cannot see the screen to do it.
4. The Function key for sending the feed from your laptop to a third party device, like a projector, is enabled. Your computer thinks you want to use it to send the picture to another device. You should hold in the Fn key, down near the bottom left CTRL key. and while holding in that Fn key, press the Function key (F key) across the top of the keyboard that shows a little picture of a television screen. Press it once and wait to see if your screen returns. If not, press it a second time... If not, then this is not the problem.
May 22, 2014 | Toshiba Computers & Internet
Polaris won't stop spinning/display screen black
TRY TO USE DIFFERENT PROGRAMM, BECAUSE SOMETIMES THE PROGRAMM GET STUCK ON ONE.
Jan 20, 2014 | Miele Washing Machines
I have two issues with the pb8220 1. How do you reset the bulb hrs when a new bulb is installed? 2. Projects for about 10 seconds then goes black. The red bulb light comes on when the screen goes...
Reset the lamp hours as follows.
Press the Exit button on the projector for 3 seconds to display the total used lamp time. Press the MENU button on the projector during the lamp hour message. An adjustment message will appear. Press left or right arrow to reset lamp hours or press EXIT to leave.
sonsunny
Jul 09, 2011 | BenQ PE5120 Multimedia Projector
I have a hp smart tuch,, the light are on but the screen is black,, if i tuch on the screen i can hear a nois but nothing happens
Hello
Remove the computer from external power source and then remove the battery and leave the battery out for at least half an hour,this discharges all sorts of residual voltage in the system's capacitors
leave it out for one hour and replace the battery. After replacing the battery the computer should start without a problem. I hope this helps.
Apr 12, 2011 | Computers & Internet
My iphone screen went black/blank...tried a double button restore but no luck
Try restoring your phone in itunes. Try the home button on off while connected to computer, then try restarting the computer. Did the battery go dead? Leave iphone Connected to computer for awhile. Mine came back after 6 hours connected.
Feb 21, 2010 | Apple iPhone 3G
LG VRIZON WIRELESS LED SCREEN IS BROKEN IDROPPED MY PHONE IN SOME WATER IN NOW MY SCREEN IS BLACK
When the battery got wet, it short circuited. So what you need to do is take the battery out and put the battery and the phone in a bowl of rice overnight or for 7-8 hours. If it doesn't work after that, try leaving the phone (opened up) and the battery next to a running hair-drier for a few hours. But do not leave the hair-drier on when you're not home. Hope this helps!
May 13, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Diablo 2 not starting
Re: "my screen goes black for about 2 seconds, and then I return to my desktop and the game ins't running"
Test the graphic setting.
Go to Run box under start button and type in DxDiag to test your graphic card and video software acceleration.
If Direct X do not work on some format, reinstall direct x (put update direct x in google).
If the problem is the video card , reinstall video card drivers.
If it is none of the above, then there may be an issue between Diablo 2 and you graphic card.
Apr 13, 2009 | Blizzard Entertainment Diablo 2 for...
PS2 Call of Duty Finest Hour loses video and screen goes black.
I am having the same problem please email dav236@yahoo.com if you have found solution. Thank you
Dec 26, 2008 | Activision Call of Duty: Finest Hour
Screen blacks out
Check your set for coolant leakage. It is very prevalent on Mits HDreadys.
If your 4 layer Signal board - beneath the blue gun - has coolant on it, you'll have problems finding a replacement. If it's the boards under the other 2 guns, they can always be repaired as they are single layer.
A drip shed should be installed to keep the coolant off your boards.
Mr Bob
Feb 02, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Wavy screen
Try using a different refresh rate. I've found that when you change it down to 60 hertz that the issue usually goes away.
Jan 07, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Rosewill R900J 19" Flat Panel LCD Monitor Logo
29 people viewed this question
Top Rosewill Computers & Internet Experts
Jim Thurston
JustBeatOnIt
Level 1 Expert
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
