Question about Hayward SAND FILTER, PRO SERIES
The head of the filter is cracked and leaking
    Novelist:
  • 116 Answers
What do you mean by head? The black multiport valve? Where exactly is it leaking? You may be able to fix with new o-ring or seal. Otherwise you'll have to replace the top half or possible the whole valve
Posted on Sep 18, 2010
Changed filter still leaking
filter head may be damaged check its flat where o-ring seals against and check for any cracks in filter head
Jul 01, 2013 | Mercedes-Benz ML320 Cars & Trucks
Mazda bh famillia water leaking at back of engine near oil filter, do you know what this could be?
You need to locate the leak. It could be a simple hose or as bad as a cracked head/head gasket.
Jan 31, 2013 | 1994 Mazda 323
Frigidaier Side by side Fridge FRS23R4A water leaking from filter casing and no water to water dispensor
Cracked filter head our water line. Best bet is to pull filter head down and inspect water lines and head. Replace if needed
Aug 17, 2012 | Refrigerators
Oil is milky.
Coolant is mixing with the oil, so it is turning milky.The most possible problem is an cracked cylinder head or head gasket.Check them and get it replaced before it damages the engine worsly.. Dain the oil and have it refilled after replacing then broken part.
Feb 14, 2011 | 1992 GMC Sierra K1500
I have a problem with my jeep. I found some milky oil in the dipstick and hose to air filter. What causes it?
sounds if you are getting coolent or water into the oil. you should have it taking to a shop for repair.
Jan 10, 2011 | Jeep Cherokee Cars & Trucks
Hi my hyundai leaks a wee bit of oil into air filter and i have lost a cyclinder, could this be due to spark plug leads?
theres no possilble way oil can leak into the air filter as it is usually above the engine and it sucks in air not spit it out and oil doesnt go anywhere close to that, but that cylinder you lost is due to a cracked head gasket which is also why u would be leaking oil no idea how it got in your air filter tho usually the crack in the gasket will leak water into your oil so if you drain your sump there should be water in it unless its a minor crack if so you will be able to repair it with as little as spending 20 bucks
Oct 13, 2009 | 2001 Hyundai Elantra
Filter is leaking out of the head backwash port when in the
Either the gasket 'groove' had debris in it and needs to be cleaned, the gasket rolled out again, or there is a crack in the area the gasket sits allowing the bypass.
Jun 13, 2009 | Hayward SAND FILTER, PRO SERIES
Cracked head unit
Yes warranty will cover manufacturer defect.
Sometimes even if it is out of warranty it is worth it to call the company because of a possible design flaw.
hope this helps
Mar 25, 2009 | Home
How do i fix water mixed with my oil
This sounds like a blown cylinder had gasket. Although on some engines you will find core plugs below the rocker coverin the head.
Dec 02, 2008 | 1997 Chevrolet Lumina
Hayward SAND FILTER, PRO SERIES Logo
133 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
