Question about Dell DimensionTM XPS 710 PC Desktop
I have a flashing amber light and checked voltage selection switch and all cables and components are installed and secured. So does any one know where the cause of the problem might be?
  • 3,940 Answers
Flashing AMBER power LED indicates a failed power supply
Posted on Sep 12, 2010
Helloi am having problem with dell t5400 presionwhen i start my pc and show my desktop few minutesautomatically turn off and orange light blinking do you tell me what the problem with My t5400 precisi
The only blinking orange light is located on the Network RJ45 connection
If you're talking about the Power light on the Front panel:
If the Power light is blinking green the computer is in a sleep state: The computer is in standby mode. Press a key on the keyboard, move the mouse, or press the power button to resume normal operation.
If the Power light is blinking amber indicates that an internal power problem might exist; The computer is receiving electrical
power, but an internal power problem may exist.
Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
Ensure that all components and cables are properly installed and securely connected to the system board.
You can find the User Manual here Product Support Dell US
May 06, 2014 | Dell Computers & Internet
Amber light is flashing on my computer and it won't turn on at all. Help!
The Dell Dimension 300 gets the amber blinking light when there is power to the computer (the power supply) but the motherboard isn't getting the correct power. Sometimes it can indicate a motherboard fault or that the power supply is not set to the correct incoming voltage.
Check the back of the computer. If the power supply has a switch for incoming voltage, make sure that it matches your incoming voltage. Next check that the main power cable (20 or 24 pins depending on the computer) is fully seated on the motherboard. (It can only be connected one way and should lock onto the connector on the motherboard.)
Next check that the power supply is providing the correct power. You can simply install another power supply (known to work on another computer). Make sure that the PSU is correctly sized for the computer components. Alternatively use a multimeter or a dedicated power supply tester or put it in a different machine.
If the problem is not cured with a new PSU, the motherboard has a failure. Unfortunately, it's difficult to identify the exact bad component. (If a major component other than the CPU on the motherboard had failed, the diagnostic lights or beep codes could help identify the issue.)
I hope this helps.
Jun 10, 2012 | Dell Dimension 3000 PC Desktop
My power switch keep giving me a blinking amber light what can i do
Do you have a battery backup/surge protector?? Take it out of the loop and plug directly into the wall.
From DELL
If the power light is blinking amber - The computer is receiving electrical power, but an internal power problem might exist.
Ensure that the processor power cable is securely connected to the system board
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 28, 2011 | Dell Dimension E520 PC Desktop
Dell xps 420 computer will no start blinking amber light no diagnostics lights working
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Ensure that the voltage selection switch is set to match the AC power at your location, if applicable.
Ensure that the processor power cable is securely connected to the system board.
This can be caused bya defective power supply or a defective motherboard. Just to make sure thatnothing else is causing the problem, remove any PCI cards like modem, videocard, sound card, etc... Remove the memory modules and disconnect cables toCD/DVD drives. Look at the USB ports to see if any are damaged.
Jul 25, 2011 | Dell XPS 420 PC Desktop
I went on vacation and completely unplugged my E520 prior to leaving, upon my return my PC will not even boot. There is now a flashing amber light (no lights on 1,2,3,4 front panel) and the fan will not...
PLEASE READ ENTIRE ANSWER BEFORE BEGINNING:
Sounds to me like your power supply went bad. This is easy to replace however with Dell computers you have to order the power supply unit (PSU) directly from Dell or a Dell store (if those exist?). Unfortunately, they are pretty much the only company that has their own proprietary PSU so you can't just go pick one up from the store (like best buy or the like). It is easy to replace but DO NOT ATTEMPT TO FIX IT!!! Power supplies can KILL YOU. They're cheap and easy to replace. Simply unhook all the power connections and unscrew the screws from the back of your case and it should slide out. I shouldn't have to mention that of course it should be unplugged... Why did this happen? Who knows, sometimes psu's just go bad even though you did the right thing and unplugged the machine before going on vacation. Please be sure to note the wattage as you will need to replace the psu with an equal (or I suggest a little extra from the factory installed) amount of wattage. I hope this helps and thank you.
Jan 18, 2011 | Dell Dimension E520 PC Desktop
When turn on light turns yellow and would not boot
If the power light is steady amber- The computer is receiving electrical power, but an internal power problem might exist.
  • Ensure that the power cable is firmly inserted into both the power connector on the back of the computer and the electrical outlet.
  • Ensure that the voltage-selection switch is set to match the AC power at your location.
  • Ensure that the microprocessor power cable is securely connected to the system board.
  • Ensure that the power supply cables are securely connected to the system board
If the power light is blinking amber- A device might be malfunctioning or might be incorrectly installed.
  • Remove and then reinstall the memory modules (see "Memory" for module installation procedures).
  • Remove and then reinstall any cards (for installation procedures, see "Adding and Removing Parts" for your computer type).
  • Remove and then reinstall the video card, if applicable
Jan 18, 2011 | Dell OptiPlex GX260 PC Desktop
My Dell Optiplex 330 does not turn on,there is a yellow led light blinking
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might occur.
You an use the following link to know how to open the computer tower
User manual
Thanks for using Fixya
Proton
Oct 13, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
My xps710 was flashing amber tech said motherboard or power supply problem replaced both with 720 motherboard new power supply upgraded system with windows 7 additioal harddrives and bluray. same problem...
Click on the link below for a diagram of your system motherboard:
http://support.dell.com/support/edocs/systems/xps710/en/SM_EN/techov1.htm#wp1063887
Have you added any new hardware?
If you have replaced the Motherboard a common error is that one of the power connections to the motherboard is not connected, double check all connections.
Apr 13, 2010 | Dell XPS 720 (dxcwuh4_2) Intel Core2 Duo...
Power light is solid amber.
If the power light is amber and green or steady amber — A device might be malfunctioning or incorrectly installed.
If the power light is blinking amber —
  • Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
  • Ensure that the processor power cable is securely connected to the system board.
Nov 26, 2009 | Dell OptiPlex GX280 PC Desktop
GX620 Powre Buttion Flashing Yellow
the amber light flashing is a power issue, this is from the Dell Manual :
Ensure that the processor power cable is securely connected to the system board (see page 73).
I suggest you unplug the machine completely from the powersupply wait a few seconds and plug it back in, sometimes this will help with power issues.
Jan 15, 2009 | Dell OptiPlex GX620 PC Desktop
Dell DimensionTM XPS 710 PC Desktop Logo
297 people viewed this question
Alun Cox
