Question about Hotpoint Kitchen Ranges
Large burner has gone wacky
I have a hotpoint electric range and for some reason the larger burner only heats up when one of the other small burners is turned on. This hasn't always been the case the range is about 15 years old but works perfectly except for this new really weird problem. Any advice or clue as to what the heck is going on?
    Problem Solver:
  • 16 Answers
You have a bad infinite switch. most likely the large burner that is giving you a problem... alway disconnect power before any repair.. you should be able to order this part online or at your local parts house.
Posted on May 15, 2008
Frigidaire stove front large/small burner combination. Large burner works but the small burner in the centre of the large burner does not come on at all with any heat. ??
This is a inner/outer burner type assembly? Sounds like a glass top.
Either way, your switch for that burner or the burner needs to be replaced.
If you are able and it is possible, inter change switches to see if it makes a difference. Interchange Large with large, small with small.
If yous switches are connected as one unit, you will not be able to do this. Sorry, I have not looked up your wiring diagram.
Oct 23, 2013 | Frigidaire Gallery GLEFM397DS Electric...
One burner on Kera205pbt won't heat
Just to be clear, the burner does not heat at all? Is this the small or large burner? Swap the burner with another one to see if it is the burner itself or the infinite switch. Post back your results.
Feb 08, 2013 | KitchenAid KERA205P Electric Kitchen Range
Viking model vdsc4874gss small oven works fine large oven element on bottom only gets hot in cleaniong mode, fan comes on when dial is turned to convection but no heat power is on light works
One thing that you can check is make sure that you have 220 volts at the plug. Leave the unit unplugged and check continuity on the burners. You should have continuity on the burners.
Oct 18, 2010 | Viking 48" 6 Burner, Grill Professional...
Burner on stovetop is out
good day,
hope this link below will solve your problem.
kitchen appliances
Sep 28, 2009 | GE Spectra JBP78 Electric Kitchen Range
JBP78W electric smoothtop small burner in dual burner not working
you call a repairman, Like I did , expect to pay 150.00 or more as the small burner and large one are in the same ceramic holder
Oct 17, 2017 | GE Spectra JBP78 Electric Kitchen Range
Front Right Large Burner Wouldn't Boil, Now won't heat at all
The burner has a short now. The burner is a resistor and when it is shorted the burner will not heat to its full capability. You should be able to replace the burner element. Home Depot or Lowes may have the part you need or you can most likely get them from Amazon. They have everything.
Cheers
Nov 26, 2017 | General Electric Stove/Oven/Range Chrome...
Serial Number:
Ok remove the burners first,then with a thin 25b4c19.jpgscrewdriver or even a butter knife push it between the front cabinet and the top to release the clips (2) that are holding this top down.see pix.
Jun 10, 2008 | Hotpoint RA620F Electric Kitchen Range
Kitchen Ranges Logo
74 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Justin Duby
Justin Duby
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
