Question about OKI MICROLINE 320 Turbo Matrix Printer
MY PRINTERS KEEPS PRINTING OVER TOP OF ITS SELF
I HAVE A OKIDATA PRINTER WHEN IT PRINTS IT KEEPS PRINTING OVER THE SAME LINE ITS LIKE THE ROLLERS ARE NOT MOVING
  • Anonymous Mar 19, 2014
    Ever since I moved the printer and turn it on it just keeps printing letters and numbers???
    President:
  • 2,351 Answers
Hi amyellis, please click on this link below which will take you to okidata ML320Turbo's page. http://my.okidata.com/PP-ML320Turbo.nsf?
Download the pdf manual for you're ML320Turbo.
For English click here: http://my.okidata.com/mandown.nsf/1fe7d58578ca7f99852569af0042834b/e08d475cb4b6bf4a852569590039ffc6/$FILE/ae320tug_07.pdf
Once opened click the + sign next to Index. Than click the + sign next to Paper. Than click the + sign next to Paper jams. Follow the instructions to clean out paper build up within the printer. This is the most likely reason the paper is not moving.
Within the pdf file in the upper left hand corner is a small icon that looks like a gray floppy diskette. Click it & save the manual to you'r PC drive. You may need it from time to time.
Good Luck!
Have more questions? Please feel free to ask.
Mike
Posted on May 15, 2008
Okidata all in one 942 only prints half a page
Hello.
Which specific brand and model ? Don't think Okidata makes an AIO model 942.
Does the printer stop after printing half a page or it the print on just half a page ?
Still under warranty ?
Jul 04, 2011 | Office Equipment & Supplies
D7160 error messages showing put the papers facing down , its correct selection from our side but keeps showing the messges
Print a self-test report. See the section on how to use these solutions at the beginning of this document.
  • If the self-test report prints , try printing the original document again. If the issue is resolved, there is no need to continue troubleshooting.
  • If the self-test report prints, but the original document does not , continue to the next solution in this document.
  • If the self-test report does not print , try printing the report again. Listen for the rubber paper-pick rollers; you should be able to hear them rotating. Then, try slowly pushing the paper farther in until the roller engages to pick up the paper. Be careful not to push the paper in too far, which can cause paper jams.
    • If the self-test report does not print when slowly pushing the paper farther in , repeat the previous steps to clean the rollers again. If the issue continues after repeated cleaning, skip the next solution in this document, and then service the product.
    • If the self-test report prints when slowly pushing the paper farther in , try printing the original document again. The paper might not have been loaded far enough into the product. If the issue is resolved, there is no need to continue troubleshooting.
    • If the paper only feeds through the product when you slowly push it farther in , repeat the previous steps to clean the rollers again. If the issue continues after repeated cleaning, skip the next solution in this document, and then service the product.
Nov 18, 2010 | HP Photosmart D7160 InkJet Printer
OKIDATA 490 printers started printing the following and there were no changes made to any software/network/hardware. The emulation is and has always been Epson LQ - ''12345X@PJL @PJL INFO PAGECOUNT...
We had this same problem and discovered that some vendor installed a program called "Print Track" which discovered every printer on the network using port 9100 and sent a query for how many pages were printed. Removing this software from the offending PC resolved this issue. We used the "job log" from one of the Okidata printers to find the IP address of the PC that was causing this.
Jul 07, 2009 | Computers & Internet
When copying or printing a fax, a vertical black line 2-3 mm line
try cleaning the rollers with water in the feeder at the top check the glass too too see if it's dirty
Jun 27, 2009 | HP Officejet 6310 All-In-One InkJet...
Trying to print 81/2 x 61/2 paper on my okidata microline 420
You need to reset page dimensions from the page options in the printer drivers.If you want any further support, a technician from techbuddies can help you for free.For this log on to www.techbuddies.org
Jun 18, 2009 | Okidata 420 Printer - Factory
Printing Problem in Windows XP
Does it seem to print the Windows test page faster than the self test print? If so it is probably printing the self test in a higher resolution than the Win test print (Win test prints are usually printed in low res)
Try printing a simple graphic or document from a piece of software. First in DRAFT mode and then in the HIGHEST Quality setting. See if you notice the "jerky" sensation in the DRAFT mode.
It could be normal for you printer.
Oct 14, 2008 | Epson TM T88 Thermal Printer
Okidata Microline 420
This would be the print head pins not moving forward or the ribbon bunched up at the top.
Sep 23, 2008 | OKI MicroLine 420 Matrix Printer
Prints one line and stops
hello,
Every printer has inside Rollers that help the transportation of the paper during printing.
When the Rollers are faulty then the paper finds it difficult to move successfully during printing.
Also there is a motor that spins to rotate the Rollers.so i think any of these may be faulty.
Try and get a printer specialist to check it for you or you can come live chat with me and i will direct you..
Good luck
Jan 22, 2008 | Epson LQ-590 Matrix Printer
Okidata ml390/391 Turbo
you have to set this on your computer. when the print box comes up you need to choose the label catagory to make your printer print labels just right
Aug 06, 2007 | OKI MICROLINE® ML390 Matrix Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
179 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
