Question about GE Caf? 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice and Water - Stainless-Steel
I have a GSL25JFTA BS with a MWF water filtration system filter. The water mechanism in the door stopped working. The ice - crushed and cubed - and the light work fine. I changed the water filter, but still no water. Any ideas?
fridgetech
  • 473 Answers
SOURCE: crushed ice only
Behind the ice bucket is a metal housing that holds the auger motor and solenoid.  The solenoid is bad.  When you go for cubed ice that solenoid should pull up the metal rod on the ice bucket so full cubes will come out.  First check to make sure the metal rod on the ice bucket isn't somehow caught under the solenoid and not letting if move up and down.  You can take out the ice bucket and press for cubed ice.  You should hear a loud clunk noise.  If not then you know the solenoid is not working.
Posted on Oct 11, 2007
Krazytech
  • 725 Answers
SOURCE: Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Posted on Apr 05, 2008
  • 184 Answers
SOURCE: Ice dispenser only dispenses crushed ice
THE WAY A DISPENSER CHANGES FROM CUBES TO CRUSHED ICE IS BY RAISING AN ARM THAT RUNS ALONG THE BOTTOM OF THE ICE BIN. IF IT SETS FOR A LONG TIME, IT CAN GET A BUILUP OF FROST OR ICE THAT KEEPS IT FROM MOVING. PULL THE ICE BIN OUT AND TRY TWISTING THE END OF THE ARM MANUALLY. IT SHOULD OPEN A DOOR AT THE FRONT OF THE BIN THAT WOULD ALLOW THE ICE TO BYPASS THE CUTTER ASSEMBLY.
ALSO,WITH THE ICE BIN REMOVED, PUSH THE DOOR SWITCH BUTTON CLOSED BUT KEEP THE FREEZER DOOR OPEN. WHERE THAT ARM GOES IN THROUGH THE BACK WALL, CHECK FOR MOVEMENT OF A ROD UPWARD WHEN YOU CALL FOR CUBED ICE. IF YOU HEAR A LOUD HUM BUT THE ROD DOESN'T MOVE, YOU MAY NEED TO REPLACE THE SOLENOID ASSEMBLY IN THAT MODULE.
Posted on Apr 10, 2008
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
SOURCE: My fridedaire side-by-side only gives crushed ice even when cube ice button is chosen
take the ice bucket out of the freezer
from the back of the ice bucket, there is a little metal bar that stickes out (back left bottom)
that little metal bar inserts into a hole with a spring loaded 'up/down' mechanism...this is stuck UP, and needs to be jiggled with your finger to spring down.
Once that mechanism inside the hole springs down, the ice maker will go back to producing whole ice cubes.
Posted on Nov 19, 2008
My side b side fridgidaire will only make cube ice now not crushed
fridgidaire makes cubed ice but crushes ice. could be push button on door, mechanism that crushes ice, if not mechanically inclined please call refrigeration tech to check out.
Apr 10, 2015 | Frigidaire FRS3R5EMB Side by Side...
LG ice maker will not dispense cubes without crushing them
Check the evaporator system, that release the cubes, when that does not work the cubes stay stuck inside.
Oct 31, 2008 | Refrigerators
GE ice maker crushed ice selector does not work. It does work for cubes and water. Pushing the door button when cubes are selected causes the assembly in the back of freezer that moves a rod to open the...
Crushed ice makers have a tendency to freeze up the mechanism. So you might want to deinstall your ice maker and let it defrost for a day or two.
That would be where I started, but if that didn't fix the problem I would move on to the electronics/
May 06, 2012 | Refrigerators
My samsung rfg297aa dispenses crushed ice whether its set on crushed or cubed. why will it no longer dispense cubes?
This answer probably comes too late for you (you posted the question 9 months ago), but I want to record it here for posterity, since I had the same problem, and searching on Google for it brought up your question.
Anyway, I managed to fix this very problem by removing an ice cube that was wedged in the ice dispensing mechanism. The way this unit works is that it pushes the ice cubes through the mechanism, which always rotates the "crushing blades". When you select "cubed" ice, a lever opens up the exit chute wider, which causes the blades to simply push out the ice cubes as they pass through. When you select "crushed" ice, the lever closes the "exit" for the ice cubes to be narrower, so that the ice cubes can't be pushed through by the blades, and instead get crushed by them. I had an ice cube wedged in there that had the same effect of closing the exit to be narrower. Removing it fixed the problem.
You might want to collect all the ice cubes that have accumulated in the ice bucket in a container, empty the ice bucket, clean out the mechanism from any obstructions, and then put the ice cubes back into the ice bucket.
Feb 16, 2011 | Samsung RFG297AA (285 cu ft) Bottom...
Our GSL25JFPD BS unit was installed 7/5/04 and in early 2009, we experienced water dispenser failure due to water line freeze-up, according to service technician. The freeze-ups resumed in February, 2010...
I found that when I used the crushed ice option, the lines would freeze up. Cubes were ok. Take everything out, including the ice, and turn it off for about 12 hours. Then check to see if it works again. If not, wait a little longer to let it fully defrost. If it still does not work after 24 hours, then you might need service.
Don't use crushed ice function.
Feb 26, 2010 | GE Refrigerators
Cubed Ice selected, crushed ice comes out
ice maker works. water thru the door works. lock works. light works, alarm works.
when i try to get crushed, ice cubes or quick ice.
nothing happens
Aug 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Caf? 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice and Water - Stainless-Steel Logo
219 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
