Question about HP LaserJet 4100tn Printer
I have both green light next to the rj45 on my jet direct 610n, but my jet direct doe not show when I print the configuration page, I tried cold reset didn't help. Any idea howni might be able to communicate with the jet direct card Thanks
  • 1,110 Answers
If your JetDirect Ethernet card does not show up on the configuration page then the JetDirest is bad. This is somewhat common with the 610N cards. You will need a new card. They are cheap to buy just about anywhere including Ebay. I have replaced dozens of them over the years.
Posted on Sep 12, 2010
The jet direct card is not showing up on the configuration page
Two possible problems:
1. Bad formatter, not liklely if you have used this printer with this jet direct card for a while and have not removed the card from the printer.
2. More likely either bad or in need of reset jet direct card. I am going out on a limb and guessing that you have a Jet Direct 615 card. There is a small chance that the card just needs to be reset. To do this you must perform a cold reset of the printer. Any custom tray settings that you have made will be lost during this process as will any network settings. To cold reset, turn printer off and unplug the network cable. Hold the "checkmark" key and power on the printer. Keep holding the key until all three leds turn on solid. Release the checkmark key and use the arrow keys until "COLD RESET" shows in the display. Press the checkmark key and until will perform a cold reset and restart. Plug your network cable back in and print a configuration page. If card is working again great, if not, it is likely that the card is dead and will require replacement.
If card does work, you will want to ensure that the Jet Direct card has current firmware on it. Use the HP Download Manager to update the firmware on your Jet Direct card.
Good Luck.
Apr 18, 2011 | HP LaserJet 4200 Printer
Tip
How to clear Laserjet 2100M service error
<p><span><b>Firstly Remove the Jet direct card, and any memory card on the printer.</b></span><br /> <p><b>Perform a Cold reset by turning printer off, then press and hold the job cancel button. </b><br /> <p><b>Turn the printer on and after all light come on release the cancel button.</b><br /> <p><b>79 error is usually a firmware failure error on this model which needs the formatter board to be replaced.</b><br /> <p><b><br /></b><br /> <p><b>To clairfy turi's instructions, do not put the card back in the printer. First see after the cold reset if it comes to ready and prints a test page. If it does you can then put the jetdirect card back in the printer with the power off and see if it works. If it does not then remove the card with the power off and do a search on this site for baking the card which works about 95% of the time.</b><br /> <p><b><br /></b><br /> <p> <p><b>Here some information that anyone can try. There was an issue with the 610N cards where the main chip on it developed cold solder joints. Same with the 615N however, it develops quite a few. There is a method which can be used to try to bring the card back to life. You need to remove the back plastic plate and then use 4 screws to prop the card up and place in a baking pan chips facing up. Preheat a good oven to 350F (177C). When ready put the pan with the card in the oven for 8 minutes. Remove and let it cool at room temperature for 30 minutes reattach the plastic plate and see what happens. </b><br /> <p><b><br /></b><br /> <p><b>Only if the printer works without the network card. You then bake the network card.</b><br /><br />
on Jan 03, 2011 | Office Equipment & Supplies
We believe the problem with our LaserJet 5000 GN is the JetDirect 610N network connection on the back. It prints its own internal documents just fine, so we know it's not that. And the network itself seems...
New Part Number is J7934A it is newer version and costs about $75.00 . To test the jet direct, press menu and then information, print the configuration page, if more then 1 sheet comes out 1 will be for the jet direct if this prints there is nothing wrong with the Jet Direct. however if you are printing through the network and you are getting any type of special characters like $%^ it is most likely a driver issue, uninstall the printer and reinstall using PCL 6. You can go to HP's wesite for driver support. Hope this helps.
Jan 03, 2011 | HP JetDirect 610N Print Server
Error 79.00FE
In order to fix the 79.00FE printer error, first you have to print a configuration page. Then remove the jet direct and power on while holding the go button down on the printer. After display reads offline, the reset process is complete. After the cold reset, remove the jet direct card and see if the 79.00FE error goes away. If the 79.00FE error appears before a job is sent then it may be the DIMMS, try removing them to see if the error persists.
Dec 08, 2010 | HP LaserJet 5100dtn Printer
How do you do a print test showing number of pages printed on an HP LaserJet 1022 printer?
Press the Go button until the green light starts flashing and the motor starts. The configuration page prints.
Go button is next to the Cancel Button ( X )
Oct 15, 2010 | HP LaserJet 1022 Printer
HP4550 - 49.00FF service error
Turn off the RAM disk on the printer.
Follow these steps:
Troubleshooting steps
1.
Verify that the formatter light is blinking or steady. If the formatter is blinking, it is functioning properly and probably does not need to be replaced. If the formatter light is not blinking, proceed to Step 2.
2.
Turn off the printer and unplug the power cord.
3.
Remove the HP Jetdirect card, third-party device, hard disk, parallel cable, or IFR cable from the formatter if one is installed.
4.
If the error continues with accessories removed from the formatter, perform a cold reset on the printer. Ensure the HP Jetdirect card is not in the printer during a cold reset or the card settings will be changed back to default settings. To perform a cold reset, do the following:
1.
Turn on the printer.
2.
Watch the control panel.
3.
When the memory starts counting, press and hold the green (Select ) button.
4.
Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
5.
Release the check button when the Ready, Data, and Attention light are on steady.
The control panel will display SELECT LANGUAGE .
6.
Press (Down Arrow ) button once. The control panel will display COLD RESET
7.
Press (Select ). The printer will perform a cold reset and then continue its power-on sequence.
5.
If the printer comes up to ready, print a Configuration page. If a 49 error occurs from printing internal pages, continue on to the next step.
6.
Turn the printer off and unplug the power cord.
7.
Remove the eight screws around the formatter.
8.
Remove the formatter. See Figure 1.
9.
Reseat the firmware and memory modules on the formatter. Check for any DIMMs that are non-HP and remove them. Non-HP DIMMs are not supported by HP and may cause this error. Replace with HP DIMMs, if necessary.
10.
Reseat the daughter (interconnect) board. The daughter board is connected to the formatter behind EIO slot #1. To release the daughter board, push in the black retaining tab underneath the formatter then lift up the one side of the daughter board.
11.
Reseat the daughter board.
12.
Install the formatter.
13.
Turn the printer on again.
14.
If it comes up to READY , print a configuration page. If a 49 error does not appear from printing internal pages, or at power up, continue to the next step.
15
Install the HP Jetdirect card and hard disk before installing the formatter. Verify that each device is properly seated.
16
Test any EIO devices, by turning off the printer, installing each device separately, and printing a Configuration page. Repeat for each EIO device.
17
If the 49 error occurs with any EIO device installed, replace that EIO device.
Oct 05, 2010 | Computers & Internet
How to get printer ip
You can press the MENU button on the Laserjet, on the right hand side of the button to keep to pressing the right side of the button until the Print Menu Map then press the Select button. THIS PRINTOUT SHOWS SHOWS YOU HOW TO NAVIGATE TO THE VARIOUS OPTIONS.
You can select the Print Configuration then press the Select button for a printout of the printer's configuration.
Alternately you can navigate to the JetDirect Menu to view or change the IP address settings.
Jan 17, 2010 | HP LaserJet P2015dn Printer
How do i set ip address for new jet direct card on hp 4600 dn
Go here for the manual cause it's a bit hard to walkthrough. When the printer is on and ready, you want to click the menu button and scroll though to the configuration menu -> i/o menu. You can print a configuration age to see what the current address of the jetdirect card is. If you're comfortable with command line, you cna use telnet to connect to the jetdirect card and configure it that way.
Oct 05, 2009 | Office Equipment & Supplies
The printer is not reading any informaiton from computer
When printer is showing green light solid at that time press and hold the horse shoe button for six to seven seconds(Not more than 7 seconds) and release the button if the printer printer prints the self test configuration page than try another cable or reinstall the printer.
If printer is not respoding on pressing the green button than printer control panel is frozen and formatter board is faulty need to be replaced.
Mar 20, 2009 | HP LaserJet P2015dn Printer
Not able to take print on both side in hp 9000 normal series
You can't print on both sides you miss • Automatic duplex unit for two-sided printing" you're model doesn't have it.
Read below:
Shown at left:
HP LaserJet 9000 series, base unit—
LaserJet 9000
base unit =
• 50 ppm print speed
• first page out in less than 8 seconds
• built-in RIP-once technology
• 300,000 pages-per-month duty cycle
• 64 MB memory
• EIO expansion slots
LaserJet 9000n = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TX
• 100-sheet multipurpose tray
LaserJet 9000dn = base unit +
LaserJet 9000hns = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TXlj9000hns.jpg
• 2000-sheet input tray
• 3000-sheet stapler/stacker
Oct 25, 2008 | HP Compaq dc5700 Microtower - Free Flat...
HP LaserJet 4100tn Printer Logo
182 people viewed this question
Seeker5211
Seeker5211
