Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
It fills with water then shut off. So if we hit the lid a few times and turn the dial our selfs it will kick back on.
  • Whirlpool Master
  • 3,740 Answers
The most likely failure is the lid switch. It can be found as item 11 here:
for model LSQ9564J (Q0)
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=257590
UNIT UN-PLUGGED
To gain access to the lid switch you lift the top by releasing the spring lips with a putty knife. The are about 4 inches in from the front corners. Press in and lift the top from the center front of the tub access. You have to release both clips to lift the top. Then
lift it straight up pivoting from rear.
Then it is a matter of removing the lid switch mounting screws, disconnecting the connector and replacing the switch.
Closer view of replacement switch:
http://www.appliancepartspros.com/part_details.aspx?part_id=3100003
This should get things back to normal. I would use a meter and check for continuity on the old switch before ordering a replacement. The old switch could just have been loose or the lid switch actuation tab bent down too far. (Lift it up and test lid)
Thanks for choosing FixYa
Kelly
Posted on Sep 12, 2010
Washing machine
possible bad or burned contacts inside timer assembly
Dec 27, 2007 | Washing Machines
How to use mr coffee tea appliance
First clean the pitcher, lid, steeping basket and steeping basket before you use it the first time. Run a brewing cycle without any tea the first time and discard the water.
With the unit unplugged, fill the pitcher with water to the top water level mark on the pitcher and then pour the water into the reservoir. Do not overfill. Place the steeping basket and lid on top of the machine. Place a tray of ice cubes into the pitcher. Turn the steeping dial to open. Put the lid with the spout open on the pitcher and slide it, spout first, under the machine. Plug in the unit and turn it on. Wait until it turns off automatically.
For brewing, fill the pitcher with water to the line for the desired amount of tea. Pour this water into the reservoir (with the steeping basket and lid removed). Place a Mr Coffee filter into the steeping basket and add the desired amount of tea bags or loose tea. You can add sugar or lemon over the top of the tea if desired. Slide the steeping basket into the unit and put on the lid with the steeping dial set to closed. Fill the pitcher with ice to the desired ice level or with cold water to the same volume as poured into the reservoir. (If you are using water, put the pitcher in the refrigerator to chill.) Slide the pitcher with the lid on under the brewer and make sure the lid is open over the spout. Plug in and turn on the brewer. When the brewing cycle is done, it will turn off. Turn the steeping dial to open to drain the remaining tea from the steeping basket. (Let the remaining tea sit longer before opening the dial if you want stronger tea.)
You can get the manual from http://www.mrcoffee.com/Products.aspx?cid=43 . Click on the link for the TM3 (all the models in a series work the same way).
I hope this helps.
Jan 16, 2011 | Sunbeam Mr. Coffee Iced Tea Maker, TM3PS...
Oven Stuck on Self-Clean/Locked cannot undo
you can press the clear off button for 3-5 seconds this should turn off the oven. if not turn off the circuit breaker for a few minutes then turn it back on and hit the clear off button again
Feb 27, 2010 | Ovens
Washer stopped at the drain cycle Model LSR8233JQ1
Could be either a bad lid switch or a bad water valve.
Set the timer dial to SPIN and turn the machine on.
If it spins the lid switch is OK. If it does not spin the lid switch must be replaced.
Next,set the timer dial on a wash cycle and set the water temperature knob to COLD water. If it fills,the lid switch is bad. If it does not fill the water valve is bad or the cold screen filter is clogged.
If the COLD does not fill,turn off the cold water faucet. Remove the cold water hose from the machine water valve and check for a clooged screen.
If it does not fill with COLD water and the screen is clear,replace the water valve.
Oct 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washes but dosen't drain
you having an issue withthe lid switch not activating, either a bad lid switch, or the "arm that hits it simply not making connection and needs adjusting.. chances are you cant hear a "clicking" noise when the lid is lifted and lowered... if this is the case its a lid switch issue... for safety reasons, the machine is not recognising the door closed so wont enter a spin cycle. will hawever wash and fill
Jan 03, 2009 | Estate TAWS800JQ Top Load Washer
My whirlpool thin twin filled with water and stopped!:(
Well if it fills then it needs the lid shut to work. So if the lid is shut it hits a lidswitch and if that lid switch is broken then nothing will work washer wise right? As far as the dryer that may be a blown fuse but nothing on the washer could stop it from running cept maybe a bad cord or breaker.
Dec 28, 2008 | Whirlpool LTE5243D Top Load Stacked...
LF Error Code
How is the water filling? Slower than it should?LF (long fill) Start by removing the hot & cold hoses off the back of washer ,now look inside the valve for clogged screens,if they are clogged ,clean them.If problem continues replace the water valve.
May 26, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Cycle never finishes.
we have an issue with one of three things
on the sides of the lid the hinges are bolted to the lid with 2 screws on each side
ferify that the secres are tight
if so then you have a lid switch that needs to be replaced or the water pressure switch in the console is bad
Apr 26, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
