Question about Koolatron (785169015699)
Coin slot coin does not make contact can does not come down . is there a place i can get it fix
Paid for coins but not received
You will need to contact Facebook support for that. Here is a link to their live chat:
http://www.facebook.com/note.php?note_id=410099297768
Jun 29, 2012 | Mytopia Lucky Slots
How to remove a carousel stuck on a Kodak Carousel projector
No problem! FIRST, make sure the locking ring is in place and tight on the top of the tray. Next, locate the center hub (the hole in the center of the tray fits over it). In the center of the hub you will see either a "coin slot" or a small metal lever. Push the lever in the direction it will move and at the same time lift the tray off the projector. If you have a "coin slot), use a quarter to turn the coin slot until the tray is released. Turn the tray upside down, replace any slides that may have left the tray when it became stuck, and rotate the bottom metal plate until it locks in the locating slot. Turn on the projector and cycle it a few times IN REVERSE without a tray on it. this unlocks the jam in the projector. You should be good to go now!! Good Luck !! Jim
May 05, 2012 | Kodak Carousel 4600 Slide Projector
Cannot open the battery compartment on my suunto x6 without breaking it....any ideas?
  • Turn the Suunto over to view the backside. Insert the quarter in the coin slot located on the battery compartment cover. Turn the coin counterclockwise to the "Open" position marked on the back of the case.
  • Remove the battery compartment cover. Remove the old battery from the battery compartment. Make sure the o-ring and all surfaces are clean, dry and not damaged. Do not stretch the o-ring!
  • Place the new battery into the battery compartment (negative side down, positive side up). Make sure the o-ring is in its place, as to keep the Suunto waterproof. Place the battery compartment cover back onto the backside of the watch.
  • Insert the quarter back into the coin slot and turn the coin clockwise to the "Close" position marked on the back of the case.
  • If this doesnt work take to a jeweler who has tools.
    Jewel
    Aug 31, 2010 | Suunto X6 (black) Wrist Watch
    Change the number of coins to operate
    you need to take the coin slot apart take pictures as you go to put back together the parts to change amount are hidden inside it in hidden compartment if they wheren't removed by some one. your machine didn't come with the coin mech so if you don't have the parts you will need to take it with you to the parts house to get right parts. open the top of the coin mech box there are 2 long rod screws holding it in place usually 5/16 inch wrench fits may need to wiggle the heck out of it to get it out
    Dec 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
    The coin mechanism is hard to push the coin slider, but it works.
    Coin mech is held in place with 4 screw heads in key hole slots.
    Move the mechinisim UPWARDS about 3mm and wiggle it around to disengage the screws.
    The hex bar is only used to stop the mech going upwards.
    Sep 12, 2009 | Whirlpool CAM2752RQ Coin Operated...
    My daughter has put a coin into the wii thru the disc slot an now i cant get it out can u help
    That will be very difficult, the Wii requires a special screw driver to get the face plate off. It is called a Tri-Wing screwdriver, you can google for it if you'd like to attempt to fix it yourself.
    There are two other ways you could try to rectify this. Unplug all cables from the back of the wii, turn it upside down so that the cd-rom slot is facing the floor, and shimmy it around a bit to see if you can get to the point where you are sure the coin is agains the cd drive. Then you could carefully attempt to stick in some small tweezers and try to grab out the coin. Just don't stick the tweezers in more than an inch or so, that way you avoid doing any damage. If you still can't get the coin out you should probably call Nintendo, they can fix it for you, and probably for free. Their number is: 1-800-255-3700
    Jul 07, 2009 | Nintendo Wii Console
    Coins placed in the disc slot of the Wii.
    I would not advise using the drive if there are any loose objects inside. Doing so would void your warranty, cause damage to the wii, and possibly even bodily injury. If the disc should come into contact with the loose object while spinning at high speed, the disc could shatter and the shards may actually break through the drive casing.
    A loose object, if it catches something traveling at high velocity, can easily damage the casing and the wii remember
    The only practical solution is to remove the drive from the wii and obtain a replacement. It would be prohibitive to try to fish out the loose object, since you might damage the internal components in doing so. you will need to call Nintendo ( 1-800-255-3700) and see if they can fix it or guide you through taking the disk drive out
    I don't think they will slide out if you turn the MBP on edge. I would take it to the Apple store and be prepared for a nice bill. I hear kids also do this in the disk player in the car to get it fixed It won't be cheap, I 'm afraid,
    At the very least the drive will need to be removed, I fear. It may actually have to be replaced. A few hundred dollars, I would guess.
    Good luck
    May 06, 2009 | Nintendo Wii Console
    Bally coin slot machine wont let the handle pull
    THIS IS DOCTOR FIX. MY BUSINESS IS GAMING REPAIR. (JUKE BOX=PINBALL= SLOT MACHINES
    BOWLING =POKER, FOR 68 YEARS.) IF YOU HAVE NOT SOLVED YOU PROBLEM, I ASSUME IT IS ELECTRONIC, NOT MECHANICAL. IF MECHANICAL , LET ME KNOW, I WILL TELL YOU WHAT TO DO.
    ON THE ELECTRONIC, OR ELECTRIC (NO COMPUTER)
    THERE IS A BAR MOVES ON TO THE CAM ON TOP OF THE CATCH, ABOUT 3 INCHES ABOVE THE BOLT THAT HOLDS THE ARM IN PLACE, WHEN A COIN IS INSERTED INTO THE COIN SHOOT, THAT METAL BAR ENGAGES THE RATCHET , TO SPIN THE WHEELS. DOES THAT HAPPEN ON YOUR SLOT.? OPEN THE DOOR PULL THE WHITE SWITCH THAT CLOSE WHEN DOOR IS CLOSED (OUT) THESE ARE A THREE POSITION SWITCH.
    IN-HOME JUKE BOX REPAIR
    SEYLEVITT@JUNO.COM
    HOPE IT HELPS.
    May 03, 2009 | Bally Walk In 9 8"" X 19 3"" X 7 6"" high...
    Coin operated machines: slide mechanism is not moving back.
    I had a coin washer and dryer.The slider has little fingers(metal)that slide over the coins.If the coin isn't placed and the slider is pushed hard will jam. Mine had a side cover with a lock. Open that and there is a long rod that has to be unscrewed to remove the lock box,then you should is what went wrong.Hope this helps>
    Jul 04, 2008 | Whirlpool CAM2752RQ Coin Operated...
    Coin operated washer and dryer
    remove the coin slot out remove the slug used to plug the coin slot
    Feb 24, 2008 | Washing Machines
    Koolatron (785169015699) Logo
    48 people viewed this question
    Top Koolatron Refrigerators Experts
    Ilia Bichin
    richie46
    Jerry Kramer
    Jerry Kramer
    Are you a Koolatron Refrigerator Expert? Answer questions, earn points and help others
