Question about Orbit Pump Start Relay
Sprinkler timer will not start pump. i need wiring help
Have the same problem,, but the small button on the bottom of the start relay works to run the pump or if i put the two start 24 vt wires to the timer 24 vt spaces,, but can not get the timer to turn on the pump when it turns on the water, even tried the orbit help center, and they said it was faulty timer, so i replaced it ( another wasted 2 hrs to return the old and hook up the new one) only to find out it too was exactly the same results. Next round,, i look for a diferent brand timer and pump relay switch,,, hope this will solve my problem
Posted on Mar 05, 2011
How to connect my well pump to timer
T8845PV has 120 volt input.... but 24Volt output,
You can use 24 volt to control contactor that can be used to switch 120-240 volt pump
Wiring on following link:
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
Gene
Water Heater Timers Save Money
Dec 02, 2013 | Intermatic T8845PV - Sprinkler-Irrigation...
Circuitry from fuse box (220v) to timer and to sprinkler pump 220v
Copy following link:
240Volt requires 2 hot wires, but not additional neutral wire. Just cap the neutral.
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-12.jpg
http://waterheatertimer.org/See-inside-main-breaker-box.html
The rain sensor should have it's own power source (for example plug into outlet, or use 1 Hot and 1 Neutral to supply power to rain sensor), and then wires from rain sensor connect to two rain-sensor terminals located on timer.
Do not connect power directly the the rain sensor terminals.
Add a comment for followup.
Jun 29, 2013 | Hardware & Accessories
How to install t8805p101c
T8805p101 is 120Volt timer with 14-day skipper wheel that is made for sprinkler systems or pumps up to 1/2Hp.
Copy following links for wiring diagram, manual, and general instructions for setting and repairing T8805p101.
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html#T8805
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
Jul 23, 2012 | Intermatic & Indoor/Outdoor Rain Tight...
Can I connect a rain guage to a intermatic T8805P101C sprinkler clock?
1) Not directly to timer, because the T8805P101C 125Volt sprinkler/irrigation timer does not have additional wiring terminals for rain sensor.
2) Buy R8815P101 125Volt timer has additional terminals for sensor.
3) If you are good at wiring projects: Then you can wire rain sensor to 24Volt 8-pin relay, and have relay open and close power to pump or sprinkler head.
http://www.grainger.com/Grainger/DAYTON-Relay-1EGY5?Pid=search
http://waterheatertimer.org/images/Connect-relay-to-timer.jpg
4) Open following link for sprinkler timer resources:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 16, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I have a intrermatic r8816p101c that some one removed need to put new one back dont know how i have 2 red wires coming from pump and to red wires coming of the wall witch has a on and off switch how do i...
You have Intermatic 240Volt sprinkler timer.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/r8816p101c%20-%20english.ashx
Timer relay has 4 wiring terminals: from left to right 1 2 3 4
Red wires from switch connect to terminals 1 and 3
Red wires to pump connect to terminals 2 and 4
Since circuit is 240Volt, red wires from switch can be connected in either order. Same with pump.
Rain sensor terminals don't have any wires, unless you but separate rain sensor.
Parts:
Aug 10, 2011 | Intermatic Hardware & Accessories
Have a intermatic sprinkler timer that is has been reconnected to the pump. it works in the manual mode but the timer does not work looking for help on the wiring (video for dummies preferred)
No video.
If manual override works, look to see if dial rotates on time for full 24 hours. If dial keeps good time, then timer clock motor is wired correctly. If dial stops rotating after tripper passes, then wiring is wrong. If trippers are absent or worn down then timer will not turn Load on-and-off.
How to set timer, and troubleshoot timer:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
How to wire timer:
You posted under R8806P101C 240Volt timer without rain sensor connections.
http://waterheatertimer.org/pdf/Intermatic-r8806p101c-manual.pdf
If this is not your timer, then add a comment with model number that appears on door panel.
The wiring block has 4 screw terminals. From left to right: 1 2 3 4
240Volts cable has two hot leads from breaker box. Hot leads from breaker box connect to screw terminals 1 and 3.
Timer operates 240Volt pump load. Cable to pump load has 2 wires. Connect Load wires to terminals 2 and 4.
Open following link for resources:
Jun 28, 2011 | Intermatic R8806P101C -...
How do you wire, wires from sprinkler to unit and wire from power
You posted under R8806 Intermatic sprinkler timer:
http://www.intermatic.com/products/timers/mechanical%20time%20switches/sprinkler%20irrigation%20timers.aspx
To see image of timer:
http://www.drillspot.com/products/85291/Intermatic_R8806R101C_Irrigation_Sprinkler_Timer
If this is not your product, then add a comment
You did not say if timer is 120Volt or 240Volt.
This information is on the door.
R8806P101 is 240Volt timer has 4 terminals from left to right. 1-2-3-4
240V Hot wires from breaker connect to terminals 1 and 3
Wires going to pump connect to terminals 2 and 4
R88 series 120Volt timer has same terminals as above.
120V Black hot wire from breaker connect to terminal 1
White neutral wire from breaker box connects to terminal 3
Black wire going to pump connects to terminal 2
White wire going to pump connects to terminal 4
Fixya also offers live phone support for a price.
Fixya phone expert can answer your questions by asking which timer you have and what circuit you are trying to control.
Dec 18, 2010 | Intermatic R8806P101C -...
Bought a Intermatic sprinkler timer. need help.
reading the specs i should say its a timer for only one zone. you can use it for one zone switching or for the pump. sorry.
May 09, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Orbit Pump Start Relay Logo
453 people viewed this question
Top Orbit Garden Experts
richie46
woodzowl307
Are you an Orbit Garden Expert? Answer questions, earn points and help others
