Question about Walkera Toys
Walkera lama 400 just spins round - Walkera Toys
  • 3 Answers
The walkera Lama has a bad gear setup,there are two tiny screws on the top
gear which powers your bottom blades one on each side of the outer shaft
if these two screws were not properly tighened at the factory or you ran yourLama
400 into the ground even if it was at a slow rotation when the bottom impacts
the ground the bolts shear off the outer shaft and you no longer have 100%
power to those blades,if your helicopter spins clockwise and you tried every
thing,this is the problem,replacement is required or you can tear it all down
and drill and tap two new holes with new screws,these are machine screws
and are less than 4/40 which is very small.To check hold top gear with two
fingers left and right side of gear and turn the bottom blades only,if the blades
turn your shaft to gear screws are sheared off
good luck
SK Florida
Posted on Sep 30, 2011
Tail blade won't rotate. Why? Everything else is OK
Hi Gilmour,
It's possible that either the tail rotor is seized up or the drive linkage is bust/ come undone. Hope it's just undone!! However I have no experience in repairing this type of machine.
Jul 24, 2015 | Walkera Dragonfly FPV 400 4CH Coaxial RC...
I have a new walkera uflys (rx-2435) when i get it up off the ground it spinnes round and round how do i fix this problem
sir jeremydylan2
you have a problem with your rear rotor assembly.
if your rear rotor shaft is broken or the gear is the copter will spin around and around.
or, if these parts are not broken then your trim needs adjustment or, you need to learn to fly and control the rear tail rotor so it does not spin around. Thats your answer. thundermounts@gustywinds.com
Feb 18, 2011 | Walkera Toys
Just bought the Walkera 38 Chinook. First flight I got an inch off the ground and landed it. Next attempt the top rotors spun initially then stops causing them to come in contact with the bottom ones. ...
Sorry for late reply, youve probably sorted this by now. This is common problen, some thing to do with the gyro. If you want to spin the rotors without takeing off the trick is to put full right turn then the gyro tries to compensate keeping the rotors turning at speed. To lift of the trick is to get airborn quickly without raising rotor speed slowly then the gyro will keep compensating and keep the rotors running. Had same problem myself, although saved the gears fortunately.
Hope this helps
Matt
Sep 02, 2010 | Walkera New 38 CH47 Chinook RTF 24GHz RC...
Replace tail rudder blade on walkera cb 180d
yea cut it off longways down the shaft with large parrot nose plyers finish with little ones back up shaft and drive on rotor with small deep well socket simple!,
Apr 01, 2010 | Walkera #35C: Main Rotor Blade (Fiber...
I bought my sons Walker Lama 2 Copters and we need
Is the lower shaft blade not rotating.. and making flimsy noise....and olnly the upper rotor blades rotate and it does not fly even at full throttle...
If above is the problem, then check the corresponding motor gear, if you could see, white shades over the black, plastic body, then the chances of that gear, might have been worn out.. if it is the same, then replace the gear, it should work......
Mar 20, 2009 | Walkera HM5#10 RC Helicopter
Walkera 37 remote heli
Swap over the two wires that go from the motor to the speed controller. NB. don't swap over the wires at the battery this will destroy the speed controller.
Feb 25, 2009 | Walkera Dragonfly #68 7 Channel 3D...
Lama v3. going in circles
looking from the above top roters should rotate anticlockwise bottom roters should rotate clockwise also check blades are fitted right way round. I only sugest this because you have replaced the 4 in 1 and could have put on connections wrong wa round easy mistake good luck
Nov 12, 2008 | Esky Honey Bee King 2 RC Helicopter
Toys Logo
247 people viewed this question
Top Walkera Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Walkera Toy Expert? Answer questions, earn points and help others
