Question about LG LRTBC1825T Top Freezer Refrigerator
There is water in the freezer comining in from the back right hand corner. It then freezes all along the bottom of the freezer compartment.
    President:
  • 3,773 Answers
Clean out the drain and check temp.
Posted on Sep 12, 2010
GE refrigerator chilled water has mildew taste
change the water filter usually located in the upper right hand corner of the refrigerator compartment on side x sides,if top mount freezer it can be about anywhere inside the unit except freezer compartment
May 11, 2012 | GE Refrigerators
Refrigerator model GR-B247WV Bottom of freezer compartment has frozen water recently. Could it be the heating element or the computer chip is faulty? Is there a number I could call for repair? Thank...
You may have a blocked drain. Therefore when your fridge goes into a defrost cycle, the melted water usually travels down a drain hole and collects in a container above your compressor, which eventually evaporates.
If the drain gets blocked, the water collects at the bottom of freezer and freezes.
If the defrost mechanism fails you will have ice and frost building up all along the back plate of the freezer, not just the bottom.
You can place calls to expert help on this site.
Ash
Sep 13, 2011 | LG Refrigerators
It's a Kenmore Coldspot that was manufactured in 1998. There's a tube that gets plugged, water freezes underneath the shelf in the freezer and water starts dripping down into the main chamber. I cannot...
The tube is located in the bottom of the freezer compartment under the coils. To access it, remove the back panel and then the floor of the freezer. Remove all of the ice. Melt the ice that is clogging your drain tube. You should see the drain tube somewhere along the bottom of the back wall. I use my wife's hair dryer or hot water when I do this to my refrigerator.
Feb 05, 2010 | Kenmore Refrigerators
The bottom freezer portion of my gladiator freezerator forms ice
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Nov 09, 2009 | Gladiator Freezerator Top Freezer...
My freezer on my Frigidaire is not fully freezing?
Take the back panel off inside your freezer compartment and check to see if the defrost coils are frozen over. If they are, you can use a hair dryer to defrost them or just let it sit for a day with a fan blowing on them.
Sep 21, 2009 | Refrigerators
Water leaking from small tube in back
It could be the defroster working and the water run off.?
Jun 09, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 09, 2009 | Refrigerators
Kenmore Elite Bottom Freezer Mod. #795 75544401
The unit was built bt LG. It is a computer controled unit and the timer is built into the main control board on back of the unit. However, the most likely cause of the broblem is the defrost terminator located on the evap on the upper right hand corner. Also, try unpugging the unit it will reset the computer board. You will also have to defrost the unit.
Aug 28, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Sep 05, 2007 | GE GSS25JEMWW Side by Side
LG LRTBC1825T Top Freezer Refrigerator Logo
42 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
