Question about Porter Cable C2002 150 Psi 6 Gal Compressor
My compressor is about 2years old, used a few times, I was using it, nail gun, working, and it stopped. Is there a fuse that may have blown? I would say I have used it about 15 times. I used it the day before and forgot let the air out when I stopped. I did turn it off. I started it the next day, it started, I used the nail gun, and then suddenly stopped.
  • 1,358 Answers
Shus don't tell no one.. and ya didn't here it from me.. there is a thermal limmitor inside the back of the motor looks kinda like a chicklet.. you can bypass it and wa-la... they get weak or flat out just go bad.. if this has a capacitor .. have it checked it also may be bad or weak.. look for your local pump motor repair shop with free testing
if'n i was help please tell me..thanks jay
Posted on Sep 12, 2010
When i tried to use the nail gun, it only produce a little pop and no nail came out
Try spraying Carburator cleaner to clean out the air chamber on the gun, and where the nail comes out
Sep 26, 2015 | Air Tools & Compressors
Why might my nail guns not work?
Have you lubricated either nail gun? If not, go to Home Depot and get a bottle of air tool oil. It's in tools by the compressors. Disconnect the air hose from the tool. Pour about a teaspoon of oil into the air inlet of the tool. Reconnect everything and try it 10-20 times with no nails in the tool. Then try it with nails. Good luck.
Sep 14, 2015 | Porter Cable Tools & Hardware - Others
Misfires new gun
If your using refills that have wire holding the nails together.
Check to see if bits of wire, debris is collecting in around the striking hammer. I switched to paper and never looked back. Must have gone through 5k worth of nails and rarely jams. Other things to check,
1. Check the striking hammer, make sure it is not bent or damaged.
2. Check air pressure, Low pressure can cause jamming, misfires.
3. If the tool needs pneumatic oil, 2-3 drops before you start good rule of thumb.
4. Check spring return. Sufficient pressure must be maintained or the nails will not feed properly. Misfires, incorrect feed, jamming etc.
I had a Hitachi brad nailer and it was horrible. Fire 1 brad nail would jam or misfire. Did everything I could think of nothing worked. Put it up, got a Rigid brad nailer and never looked at the Hitachi again. :)
Sometimes you just get a lemon! (PS I understand you have a framing nail gun. Brad nail gun above is used for an example)
Hope this helps
Mar 24, 2014 | Hitachi KNR90AE Round Head Framing Combo...
Paslode framing nailer: compressor powered, hisses but will not shoot nails, appears to be in the sliding mechanizism that touches the wood first before it will shoot, help
I've used paslode for years and whenever there was a "hiss" of air and no fire- it was o-rings- When were the o-rings changed last? And how do you know they are in 'good shape'? You can't tell by just looking at them. If that isn't the problem then I can't help. Just as an aside- do you oil the gun (down the air intake nipple) every time you use it? Lack of oil will wear out o-rings fast. Sorry if this isn't overly helpfull but most gun problems are o-ring or seal related unless you've worn out or damaged a mechanical part.
Feb 10, 2013 | Air Tools & Compressors
My nail gun was working fine and suddenly stopped. I checked to see if a nail had jammed or if the fuse had blown, the fuse was fine and i removed a nail from the shaft. When i tried to use it again it...
if this is a Bostich/Stanley nail gun that is a normal malfunction the best way to prevent this is to get a few drops of pneumatic oil in the upper portion of the nail tray, or some WD-40 and keep it lubricate after and before every use.
Apr 18, 2011 | Tools & Hardware - Others
Is it possible to use a Campbell_Housefield compressor with a Porter Cable BN138 nail gun. Can't figure out how to attach the air hose to the nail gun! Any ideas would be appreciated.
There is nothing brand-specific about connecting air tools to compressors. You just don't have the right fittings. It might help you to know that there are two different styles of quick-connect fittings used. They look similar but don't fit together. Beyond that there are a few screw on fittings used. Do this: Either remove the the fitting from your compressor or take a close-up digital picture of it. Take your nail gun and the hose to a hardware store or Lowe's or Home-depot or Sears - or anyplace that sells tools. They will be able to help you. Good luck
Jan 20, 2011 | Tools & Hardware - Others
PC nail gun does not work all the time. nails do
You have to oil the nailer with pneumatic oil, or you're using the wrong size nail
Nov 10, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
How many tools will operate at same time
I think you'll have to look at your specs on your nail guns and see what the demand is . Whether measured in cfpm or psi, your compressor will tell you the max output of each of those. Then you divide the maximum sustained output of the compressor,, lets say it is 60 psi. Let's say the guns require 10 psi, 60 divided by 10 is 6 = 6 nail guns. This is completely hypothetical as I have no idea what your nail guns require, only you know what kind of guns you have.If you need to run more guns than the compressor can push air for, you'll have to invest in another compressor, maybe even one larger to handle the guns running wide open consistent nailing. Nothing a drywaller hates more is than for all the cursed clip nails not being drove in all the way, lol, and that's what will happen with insufficient air supply.
Matt
Nov 18, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Nail Gun support
Yes, because there is less risk of splitting the wood grain when using a nail gun than when using a hammer, nail guns are especially useful in delicate projects such as the application of indoor trimming. A nail gun sets the nail in one motion, reducing the chance of slips and bumps that can ruin delicate woods. Most models also include a rubber safety nose to protect the wood from friction.
Sep 01, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
How to Install Air Compressor and Nail Gun
Set up the pressure on the air compressor. First plug the air compressor in, then check the pressure. It should be between 90 and 110 pounds per square inch (PSI) for home use. If it is not in this range, turn the knob to the left to decrease the pressure and to the right to increase the pressure. Use the appropriate nail gun for the job. For example, to nail shoe molding to base boards, a standard finishing nail gun would be perfect. It holds any size nail between 5/8 inch and 2 inches. This nail gun could be used for many projects with great results. Check the gauge the nail gun takes before purchasing the nails for the gun. If you get the wrong gauge they will not fit in the gun. You can check this by looking at the information printed on the side of the nail gun next to the model number. You can also open the nail chamber for this information. Attach the nail gun to the air compressor. You can do this before or after you load the nails into the gun. Use the air compressor hose to attach to the bottom of the nail gun. It screws on much like the end of a hose. If you do not have the right size air hose, you can find one at your local hardware store.
Aug 27, 2008 | Mountain Air Blow Gun with Rubber Tip
Porter Cable C2002 150 Psi 6 Gal Compressor Logo
343 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
