Question about SI-TEX Nautilus NT GPS Receiver
Nautilus problems Hi, I have a sitex nautilus dgps unit i purchased new in 2000. it has been a couple of years since i used it for navagation and i have run into a couple of problems. the antenna is a dgps antennia, and i am receiving a good signal to the unit. i have always had a problem with the screen refreshment rate. it refreshes slowly all of the time (constantly) and makes it impossible to navagate using the unit. i see my position on the map for a second or two, and then the screen refreshes for 30 - 40 seconds (at any speed, slow or fast). i usually use it in the headup mode, but have tried switching it to the north up mode, and it made no difference. is this the way the older units work because of "weak" processing power? i also have a problem trying to follow a route. the route is reversed, and i can not get it to switch back to the original direction the route was made in. pushing the reverse route button does not change it back to the normal direction.
I also have the Nautilus & the processor just isn't as fast as the newer units. You can adjust the track up mode to only refresh when the rotation of the map is over a cert amount, degrees, (resloution angle) if you have it set to a low value it will continually keep the route dead up & constantly refresh.
See section 4.3 Map orientation in the manual.
On the route reversal are you getting the pop up screen that alerts you that the route has been reversed?
I assume you have a manual?
I am actually contemplating selling my unit as I have a Garmin 478 from work & the screen is much easier to read in the bright sunlight. I had my Sitex on my Grady which had a bimini, but my Mako CC does not & the sunlight washes it out.
I'm thinking $375 for the whole unit with a wide area chart of MA.
Posted on Jun 22, 2008
My Nextar GPS M3-07 I purchased in June of this year at Zellers, Prospect St. Fredericton, New Brunswick, when I turn it on the screen shows "Navagation System" underneath where the red line is suppos
It seems that a software udate is necessary with your Nexstar GPS. Just go to the Nexstar website, and udate the device with latest software update.
for details.
Nov 03, 2011 | Nextar M3 Car GPS Receiver
Frequently switches from dgps to gps fix .Why is this?
DGPS only works in areas where there is a DGPS beacon, and they're simply not that commonplace. Unlike orbiting GPS satellites, DGPS beacons are fixed land based devices.
When there's no DGPS beacon, the unit automatically reverts to the regular and slightly less accurate GPS.
May 19, 2010 | Northstar Explorer 550 GPS Receiver
Hi,I need a replacement battery pack for my Sitex handheld VHF HH-250.Thanks Original 8N-600
What you need is at the VERY least is a Ni-Cd battery pack with 600mA/hr rating. We have an HH-300, with a configuration of 4AAx2.
Interstate Batteries has the BEST price I could find, although when we bought the HH-300, I sent it to SiTex for a new battery AND a tune-up which cost around $100.
Here's the link to the Interstate battery website.
<a href=""></a>
Hope this helps.
Do NOT forget that these radios are wired center pin negative! (Don't ask how I found this out...)
Sep 22, 2009 | SITEX Boating
The start timer control cycles but nothing happens. The motor seems to gurgle while attempting to fill with water - but no water comes through. We have had this problem before and the repair person...
I bought a new one and installed it myself. hardest part of installing was taking the old unit out. I compared the cost of a second repair of a 10 year old dishwasher vs. purchasing a new one. We also checked the pump and solenoid to find problems that caused the water not to enter the unit. The new one we purchased is much better, quieter, and Energy Star.
Aug 27, 2009 | GE Nautilus 24" Built-in Dishwasher
Alternative to Leica Laser Locator
Leica locator with DGPS capabilities? Leica still manufactor advanced military systems under the Swiss brand name of Vectronix which is part of the Leica group. Are you after a laser locator or a rangefinder such as the discontinued 7x42 Geovid. The Geovid is still available but no longer has the electronic compass. The original never did connect to a DGPS PC only the Leica Vectronix Vector could. None of these models will locate a laser only use a laser to calculate distance. Current Geovids range to 1200 meters and the Vectronix 21 will range to 12 Kilometers. Unless you are a certified government customer the Vectronix 21 you will not be able to purchase. Newcon have models that allegedy exceed 2000 meters that are made in Russia and depending on the model can be had for a few thousand dollars. The Leica Geovid 8, 10 or 15 power can be had for around 2.5 thousand to 3 thousand dollars and is an excellent robust unit. It will not connect to a PC for GPS sync though.
Mar 12, 2009 | Leica Laser Locator Binocular
Problem draining became problem with filling
Hi I would look at the water valve. Located left front . Remove the front panel , the bottom panel. check the water valve
Dec 23, 2008 | GE Nautilus 24" Built-in Dishwasher
Magellan model MAESTRO3100
if you need the power port for your gps, i have them for 2000 2200t 2500 3100 3140 4000 4040 and 4050 magellan maestro and roadmate
Oct 25, 2008 | Magellan SITEX 236/120ST TM 120KHZ -...
Using a DGPS on a 76csx
there is no possibility to use DGPS with 76csx... due to the fact that 76csx receivers use chipset the 'sirf star III' series and this chipsets don't allow use any RTCM data.
frankie, poland.
Feb 02, 2008 | Garmin GPSMAP 76Cx GPS Receiver
you have to purchase a separate unit and im pretty sure that you can get it on e bay
Jan 27, 2008 | Pioneer AVH-P5700DVD Car DVD Player
SI-TEX Nautilus NT GPS Receiver Logo
202 people viewed this question
Top SI-TEX GPS Experts
Will Halftowaite
Are you a SI-TEX GPS Expert? Answer questions, earn points and help others
