Question about Kodak EasyShare C613 Digital Camera
Camera won't turn off and screen is blackTried changing batteries but that does not help. Is there anything else I can do?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 12, 2010
My LCD monitor won't light up to take a picture but it does when I review those I have taken thru the viewfinder
Most screens can be turned off for low battery usage. Check battery with tester or have it tested or replace battery and check menu and see if review screen is turned off. Rich
Apr 02, 2013 | Canon EOS Digital Rebel XS / 1000D IS...
My calculator won't turn on the batteries are fresh plz help
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible. Does it?
Feb 13, 2013 | Office Equipment & Supplies
Canon Rebel flashed busy and now after changing battery, it won't do anything except display date page.
The bottom right screw on the rear board on this model comes out and shorts out parts of the circuit board. This may be the cause of your camera's problem. It is always this screw and it happens to about 50 % of the cameras I see.
Finding and replacing the screw may solve the problem, but it sounds like the screw may have done permanent damage to the rear board.
Feb 04, 2013 | Canon Rebel XT / EOS 350D Digital Camera
CX7300 Digital camera won't turn on. New batteries get hot after being put in the camera after a few minutes.
No. This camera requires service/repairs, the repairs will be more than this model camera is worth !!!!
Nov 12, 2012 | Kodak EasyShare CX7300 Digital Camera
My camera is frozen and won't turn off. Can't video or anything.
Take the batteries out; this should shut it off. It should restart normally after the batteries are put back in.
Jun 08, 2012 | Kodak Playsport Zx5 Video Camera aqua
My Power Shot SX130 IS wont turn on... I dont know why, yesterday was working and all the sudden today I tried to Power On and doesn't do anything. I changed the batteries .... HELP!
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jul 11, 2011 | Canon PowerShot SX130 IS Digital Camera
My Sony CybershotDSC-P200 camera works when it is plugged in, and the screen shows that it's charged. But as soon as I unplug it, it won't even turn on. Is there anything I can do to fix it? Would...
hi you might check battery first. sometime battery goes bad. if not then main pcb is the problem. your local repair shop could charge around $50 depend on what they really want to charge. Thanks...best regard!
May 21, 2011 | Sony Cyber-shot DSC-W130 Digital Camera
CAMERA WON,T TURN ON BATTERY HAS PLENTY OF LIFE LEFT
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Oct 24, 2009 | Kodak Easyshare M753 Digital Camera
Kodak EasyShare C613 Digital Camera Logo
35 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
