Question about Ovens
I am looking for a fuse in my antique stove 1948 moffat
I have a Moffat of about this vintage. Are you saying you can't find where the fuses are? Mine are underneath the left-hand drawer - the drawer under the warming oven. I just pull the drawer out and I can see them.
Posted on Feb 07, 2013
Where is the fuses located on a moffat stove
There are none. It is wired into the buildings electrical panel. You have to know where the circuit breaker panel is to find a tripped breaker
Aug 10, 2016 | Moffat E32 Full Size Electric Convection...
How can I remove door?
Hi Tammy:
Many of the older stoves used a similar door hinge system.
When the door is fully opened it can be removed in the following way.
It's much easier with two people.
With one person on each side, lift near the hinge (closest to the stove) then pull away from the stove and at the same time, lift the handle end of the door.
There is a tab and a notch on the hinge arm that has to slide past the retainer.
To re-install, the hinge has to be set for the "door open position".
Slide the hinge arms into the slot so that the tab and slot engage in the correct positions.
Hope this helps.
Cheerfuls. .
Apr 02, 2016 | Moffat Ovens
Mofat stove manual needed modal #mrml3400s1
Go to www.manualsonline and see if they have your model. It's free.
Paul
Sep 29, 2014 | Ovens
Oven won't turn on because someone played with timer
Try turning the mains supply off and it will probably reset everything.
Feb 01, 2018 | Moffat Ovens
Moffat Stove with a self-cleaning oven. I would like to know how to clean the oven using the "self cleaning" feature
hi there! I have a moffat stove and hopefully these instructions help you.
First clear out the racks in your oven. Take them out and remove any excess chunks at the bottom.
Then close your oven door and lock it by pulling the lock latch.
Now looking at your oven knobs [not your burner knobs] turn both of them so they are both on the arrow knob [your oven knobs should have small pictures on them and both should have arrows]
Now you need to set the time so in the middle of your oven their should be a timer and one start and stop timer on top of each other. Both timers go in increments of half an hour. So if you are starting your self cleaner at 3 move the dial to 3 or if you are starting at 3:30 move the dial to one tick after 3. Once you set your start timer, you need to set your stop timer.
Setting your stop timer, it is recommended to set it for 3-5 hours. I set mine for 4 hours. So then set stop timer to time you want the cleaning to be. If you set your start timer at 3:30 put your stop timer at 7:30.
The oven will start cleaning according to the time you set. The oven will get very hot. I recommend to not used the burners as the temperature goes to 500 degrees! You will smell an odor and that is your oven cleaning.... Hope this helps...
Sep 13, 2010 | Ovens
Broil element just warm, bake element not working
Hey -have ya tried checking the power block on the back of the stove? This is the first thing I check when power appears to be uneven. Connections may be loose enough to disrupt power flow to the elements. If wires look good, the next step is to find out if the bake element has failed. From the back you can see the wires that attach to the element. Disconnect and check resistance.  should be around 17-19ohms. If not replace with new.  Please acknowledge this post if the info was helpful. Have more if needed  Thanks-- Ed
Mar 20, 2010 | Moffat Ovens
I need a operations manuel for and E32 moffat
Try this site. http://www.moffat.co.nz/Catalogue/SalesPDF/E25.pdf
If this isn't it let me know and I will keep searching. Hope this helps.
Aug 27, 2009 | Moffat E32 Full Size Electric Convection...
Oven Door
I have spilt water inside the glass of my Fridgaire stove and wondering how to take the glass off the front so I can clean inside it.
Jun 02, 2008 | Ovens
Ovens Logo
196 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
