Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Cast iron grates-scratched form kids scraping pots across burner. Scratch area are are white. It is strictly a cosmetic problem. Now when I clean them it is even more noticeable. It may have been from me scrubbing them --even thou I uses nonabrasive pads and cleaner. They did this the 1st 5-6months I had the stove. When I called customer service they were going to send out more grates but never did and that was over 2 years ago. I gave up. Hope you can help
5 Suggested Answers
SOURCE: Cleaning cast iron burner racks on gas spectra?
Try putting them in the oven when it self cleans.
Posted on Oct 03, 2007
  • 115 Answers
SOURCE: CAN I USE ENAMELED CAST IRON POT ON MY NEW GE GLASS TOP RANGE
yes they can just cant slide them around cause of scratching but as far as performance they are fine
Posted on Dec 30, 2008
aborcass
  • 2651 Answers
SOURCE: CAN YOU USE CAST IRON SKILLETS ON RADIANT GLASS COOK TOPS?
you CAN use the skillet, but not with great results id assume, it holds too much heat, and problaby a bit too rough underneath and would probably scratch the glass top, in a family business for over 20 yrs. now and thats my recomendation, my brother also in the same feild swears his wife uses it with no issues!!!
Posted on Jan 10, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: My stove is not yet a year old and it has two
Sorry to read about your problem, I hope this helps you out.
Use oven cleaner spray
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 24, 2010
Can I use Cast Iron Pots and Skillets on my new Frigidaire Gallery Stove Top?
Hello friend, thanks for your post!
It is not recommended to use any cast iron pots or skillets on a Frigidaire smooth top. In your manual it provides the best type of cookware material and cast iron is a poor heat conductor. Due to the weight of the cast iron it can cause scratches or damage the cooktop. I hope this information has been helpful. -Matt
Oct 09, 2014 | Kitchen Ranges
IM ROUGHING IN PLUMBING FOR A SHOWER TOILET AND SINK. 8 BY6 BATHROOM FROM SCRATCH CAST IRON STACK ALREADY CUT AROUND REMOVE CEMENT SHOULD THE WHOLE INCLUDING CLEAN OUT , REPLACE IT WITH PVC OR JUST CUT IN...
always replace cast iron if its not a problem to do so, especially if it looks rough or is leaking or rusting. there are simple special black neoprene boots used to connect cast iron to pvc and do not require anything but a screwdriver, no slovents or sealers are required. always check for leaks if you make an underground connection before you cement the spot back up. its better to use gravel to fill this area in if your particular situation will allow.
Jun 04, 2010 | Kohler Plumbing
Ironed on synthetic fabric by mistake and fabric melted on the iron soleplate. How can we clean it off? Please Help! Thank you
You could turn the iron on again - set to cotton or highest setting and allow it to completely burn off. Do this outdoors or well ventilated area indoors (no smoke detectors on!)
Or, you could warm the iron and use a plastic putty knife to scrape as much material from the iron as possible. A metal knife will scratch and mar the surface. When cool, use a scotchbrite pad to buff away remaining deposits on the iron.
Mar 12, 2010 | Kenmore ProSteam 62888 Iron
Scratches on New Wolf Gas Cooktop
The good news is you have a great product! You just need technique and the "Green" cleaner DeBruce Polish. Use DeBruce Polish and a cloth for clean ups. DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. We buy Debruce Polish at debrucepolish.com
  • Firstly clean with DeBruce Polish to clarify area.
  • you may have to "re-grain" those finely scratched areas.
  • Blend or "scratch out" the misdirection scratch's with new "controlled" scratching, useing a 3M scotch brite #7447 you get at auto parts store (Nappa). Use medium very firm pressure.
  • -Re-clean with DeBruce Polish. Touch ups are now a breeze.
Feb 13, 2010 | Wolf Range 18 in. SPR-100 Gas Cooktop
I have a Kitchenaid electric range Architect Series II. Seems every time I use the large burner on the right side there is some sort of residue left that is very hard to get off. I have already made a...
What are you using to clean the stove? Only cleaners made for ceran type tops should be used according to directions. Do not use enamel coated pans or glass pans on your cooktop.If you have a boil over, turn off the burner and change to a different burner immediately. Clean up the spill completely before cooking on that burner again. Use a flat edge razor to clean tough residue. Your cooktop will look new for years to come, even with heavy use.
As far as the scratch, don't use abrasive cleaners on the top and only use pots and pans with flat bottoms. If you do use cast iron pans, never scoot them around on the top.
Nov 30, 2009 | KitchenAid KESC307 Electric Kitchen Range
Which is best porcelain or cast iron grates? I am
Cast Iron by far, ceramic grates chip and are VERY difficult to clean!!!
Nov 14, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Cleaning the cast iron grates and griddle
Take the grates off and slide them on your dishwasher rack and run them thru a cycle... pull them out before dry if you want..
May 31, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
How to clean the cast iron grates and stove top of a gas range
glass cleaner WITH ammonia, and a small toothbrush works well. mop up with an old washcloth, rinsing often. for pieces which have gummy residue, and which can be removed to the sink for soap and water finsing afterwards, try GooGone.
Mar 12, 2009 | Viking VGSC306-4B Gas Kitchen Range
Dec 30, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
107 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
