Question about Thermador UCV36A 36" Universal Cook 'n' Vent Downdraft Kitchen Hood
I have the same problem with my new Thermador UCV30A 30" Cook 'n' Vent Downdraft as was described in the post on Aug. 11 2010. The vent is stuck in the up position. Did the replacement of the switch work? Though it is an older model I got it NIB and was pre-testing the unit before installing it and the vent went up but won't come down. When I press the switch it hums for a second and then goes quiet. I have to unplug and plug in the unit to get the switch to respond again but the same thing happens again. i have reviewed the unit and there does not seem to be any mechanical obstructions that would cause the vent to seize and trigger the fuse. I took the face cover off and found a wire leading to the switch that had come out of its socket. I plugged it back in and put the cover back on. The problem still remains. Any ideas?
  • 5 Answers
SOURCE: install a Thermador UCV36 cook'n'vent
I have three 90s on my downdraft unit - 90 down from unit into slab, 90 out from slab to outside, then 90 down again. If you are talking a 6" or 8" dia vent it should not make a difference at all.
Posted on Jan 07, 2009
  • 5 Answers
SOURCE: Cook 'n Vent Downdraft Up/Down Mechanism Replacing
just the switch should be replacable. My vent has a screw at each end (philips flatheads - accessible only when vent is up) just under the top cap. Removing the screws and cap should give you access to the switch. Just make sure you cut your breaker off first.
  • 5 Answers
SOURCE: Thermador cook top with down draft ventalation
I would think you can. Most of the cooktops are 240v and the vents are 120v, so the vent may be feeding off of one of the cooktop's hot wires. My vent is fed from it's own receptacle but is harnessed along with the cooktop's 240v.
alicantecoli
  • 22326 Answers
SOURCE: I have a 1989 model
check in the hood pipes for a rubber seal thats come adrift as something isloose or come apart allowing the hood to come too low so it passing the microswitch for the fan ,between teh tubes is a seal and suspect that one of these has collapsed allowing the hood to come down lower ,its a take it apart type job and see ?
Posted on Jan 17, 2011
  • 44045 Answers
SOURCE: Thermador CVS36R Cook'n'vent vent won't go down and fan stopped workin
You probably will find that the vent is clogged with grease. A switch device works with the vent so the fan operates only when the vent is open and does not operate when the vent is closed. Things should get back to normal after a thorough cleaning unless the fan is defective and won't operate at all.
Posted on Sep 03, 2012
The vent downdraft keeps going up and down
This means that one of the limit switches by the motor has failed.
Apr 22, 2011 | Thermador UCV36A 36" Universal Cook 'n'...
Thermador cook n vent stuck in the up position. We have a thermador cook n vent. We had it running for about an hour. We turned the fan off but now it is stuck in the up position and will not go down. ...
replace the switch if the switch is going on and up position and not in down position the you should replace the switch for this part you can order it from thermador if they still stock the piece hope this helps
Aug 11, 2010 | Thermador UCV36A 36" Universal Cook 'n'...
Thermador Downdraft blower Fan Not Working
could have serveral problems / if under counter or in back of range . the last two i had the control buttons w wire harness needed replacement /another required the pc board in connevtion box ( under counter in right cornor. also look for poor connections in the power box .
Dec 07, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
The exhaust hood cannot **** out the smoke
Please check that the filters are clean. If they are old then replace with new ones.
Oct 12, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
My thermador stove fan keeps going up and down cvs45r
no
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Mar 07, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
Nov 15, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Oct 31, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Thermador Cook 'n' Vent Stove with stuck vent (model # SGCS304RS)
I just had a similar problem. The switch knob, and backer for the blower got jambed in the housing. After pulling it all apart I called the parts center at Thermador and ordered a new switch. If you can hear the motor the raises the unit run, then that could be your problem.
Oct 11, 2008 | Cooktops
Kitchen Ranges Logo
62 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
