Question about Maytag Washing Machines
Maytag LAT9635aae - Washer would fill up with water but not "wash". Previously I was able to lightly tap on the timer and it would engage, but the last time I did it there was a flash of light inside the timer and it completely lost power. I purchased a new timer hooked it up and nothing. Realized the power outlet no longer worked. Plugged in a different outlet and suddenly power again. It filled up and then nothing. The new timer wilkl not engage thru cycles on any setting and I'm not able to manually walk it thru cycles by turning the dial either. It just sits there on and full of water, but nothing. I'm lost.
SOURCE: kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Posted on Aug 11, 2008
  • 132 Answers
SOURCE: maytag washer model mav5920eww
Faulty timer.
Posted on Mar 26, 2009
  • 219 Answers
SOURCE: Maytag MAV6000AWW washer will not run thru cycles consistently
yes it would be the timer but they also stop if it gets off balance if its just off balance u should be able to lift the lid rearrange then start it again if that doesnt work it is the timer
Posted on May 21, 2009
Maytag317
  • 1136 Answers
SOURCE: water won't stop filling washing machine.
Hi, Will the water shut off if you turn the timer off or unplug the washer?
If it shuts off when power is turned off to the washer, you need to look into the water level switch. If turning off power to the washer will not stop the water, you need to change the inlet valve.
Please let me know so I can assist you further.
Thanks
Vic
Posted on May 30, 2009
  • 56 Answers
SOURCE: Washing machine wont work at all
Obviously the first thing to check is that the socket is supplying power by plugging another appliance in such as a lamp. It is less likely to be the socket but you'd be daft not to check it out before calling an engineer as it does occasionally turn out to be a faulty wall socket. This is only necessary though if there are no led indicator lights lit up on your washer as any light that's on shows that the machine is getting a live and neutral supply from the socket.
The second thing to check is the fuse in the plug. Either put the fuse into something else and check the appliance still works or try another fuse that you know to be OK in the washer. Make sure you use a 13 amp fuse and never by-pass a fuse! If both of those are OK, then the most common cause for a washing machine that wont start is the door interlock, particularly if the mains lights on the washing machine has come on, but nothing works. However, the fault could also be in wiring to the door interlock or even the door catch not activating it properly, or the on off switch or the main control module. With some Indesit and Hotpoint washing machines even an open circuit heater or motor can cause the entire washing machine to stop working except the led lights.
You need to know what you are doing to trace this type of fault so if it isn't the wall socket or the plug you'd be better getting an engineer to trace it. Do not work on a live washing machine. Engineers should use a continuity test meter to trace faults with the washing machine unplugged and never test with a live washing machine.
Posted on Mar 19, 2010
Hot water not coming into washing machine
The solenoid valve that lets hot water into unit is not opening. Check out the valve itself and the timer cam that feeds power to the cam.
Jul 04, 2015 | Maytag Washing Machines
My LAT9635AAE washer will only agitate on the delicate cycle. the timer goes thorugh the cycles on the other settings, but the agitatior will not move
You have a problem with the contacts in the timer and it will need to be replaced. Here is the part to order. To replace the timer remove the cover on the back of the console.
The part comes with a 365 day, any part, any reason return policy.
Nov 10, 2012 | Maytag Washing Machines
Have a Maytag washer LAT9635AAE. It fills with water and does not proceed. The timer seems to move the dial around but doesn't engage the washing functions. At first I thought it was simply not...
Remove the timer and get the outer skin off of it. Twist the timer around and hunt for burn marks on the barrel. I suspect it is the timer. To get it off you pop the cap on the knob and under it is a keeper and spring you remove. Then the knob and skirt will come off and you can get to the screws which hold the timer to the consolethemobilian_29.png
If the timer turns out to be ok then the motor is suspect.
Note: This washer is well worth repairing. Anything out there on the market now is trash compared to this machine. Invest in repairing it. You will be glad you did.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 18, 2011 | Maytag Washing Machines
Maytag Washer MAV7000AWW Washer fills as it
Sounds like a bad timer motor.
Try watching the timer motor and see if you can see it moving .
Jun 09, 2009 | Maytag Atlantis MAV7000
Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Mar 14, 2009 | Maytag Washing Machines
Washing Machine will not fill with water
It sounds like the water solenoid has gone bad or stuck closed OR timer/control knob has bad set of contacts which control the solenoid.
Jan 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Won't let cold water in
Take the water supply hose off and clean out the inlet screen located inside the water valve where the hose was attached to the machine. Note: there may be a screened hose washer on one end of the hose also.
Sep 24, 2008 | Maytag LAT3600A Top Load Washer
Will not spin Maytag PAV2300AWW top loader
check your door switch. Many times a faulty door switch can prevent the spin cycle. When you locate the door switch, take a jumper wire across the connection and advance the timer to spin. If it spins with the jumper wire, you will need a new door switch.
Jul 04, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag washer lse7804a won't fill
with the timer in the wash position on any cycle do you have 120 volts on the selenoids that the water hoses are connected to with the temp selector set for warm wash and timer knob pulled out? if you do then the water inlet valve is the issue, if no voltage you could have gotten a defective timer
Apr 10, 2008 | Maytag LSE7806A Top Load Stacked...
Does complete cycle
When would the washer stop?
Is there water in the washer when it stops?
Feb 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
63 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
