Question about Polaris 280 In - Ground Pool Cleaner with Booster Pump
My polaris only runs a short time and then just stops
  • 640 Answers
With these pool cleaners, make sure that you check the filter screen in the filter and clean it if necessary. Clean the skimmer basket, pump basket, and pool filter. Check all of the hoses, connections, and swivels for leaks that could cause loss of water pressure. Make sure that your wheel RPM is correct.
Posted on Oct 28, 2010
2003 Polaris SCRAMBLER 50 runs for short time then stops. Is there a choke?
Hi,there is a choke on all engines of some kind otherwise it would not run when cold.
Mar 21, 2015 | MotoBatt 2003 polaris scrambler 50 cc...
2007 polaris ranger 700 xp stop running all at once will not crank
sounds like a problem with the charging system on the battery. take a volt meter and check the voltage on the battery. If its lower than what the nameplate voltage is, it wont produce enough power to crank the engine. also check the wire connections.
Sep 19, 2012 | Polaris ATV
Polaris 700
This sounds like the thermal sensor on the head/block is faulty or in some cases the wires have shorted to the chassis somewhere causing the fan relay to stay on, clould be a faulty relay also.
Nov 25, 2011 | Polaris ATV
Have spark. have fuel. No start. was running well with intermittent choke use to correct bogging. wassup? I.m confused.
there is a chance that your computer needs to be ' Re-Flashed ',, this is now the most common problem with the Polaris snowmobiles -- they just can't seem to get this all right. I have the 900RMK ( the first one ) and after going round and round with Polaris ( in and out of the shop over 20 times ) it is now running good. lots of times the dealer will re-flash the unit with no charge to you and it only takes a few minutes.
sorry to hear that you are having troubles with your Polaris --- I work and live out in the middle of nowhere Alaska and I see many sleds come through here and it is always a Polaris sled that brakes down out here and needs to be towed out ( with a very sad rider steering it )..and after all my trouble that I had with mine and lack of help from Polaris I will never buy Polaris ever again. but stop by the dealer and get the re-flash,, it will work great after that,, ( until the next problem :-) ).
Happy NewYear !!
c...
Jan 02, 2011 | Polaris New Genuine Polaris Snowmobile...
I have a 2002 polaris sportman it runs great when i first start it and drive it for 2-3 min. then it bogs down and i have to stop and let it rest for a min. then i can proceed for a couple of min and the...
did you check to see if the choke is stuck on??when is the last time air filter has been replaced?? could be clogged.then it will be like the choke is on and running too rich, getting too much fuel.
Dec 22, 2010 | Polaris ATV
I have a 2009 POLARIS RANGER 500 with 64 hours it
if its a black smoke its running rich. check your air filter and air tube for clogs. something may have made a nest in there.
Nov 21, 2017 | Polaris ATV
4 cycle Polaris snowmobile 2006. the engine runs fine but bogs down after some running time. Short wait and restart, the engine runs fine and then bogs down again
Sounds like the coil is getting hot and stops... I have seen this on many 4 strokes. Check first to see if it has a resistor coil or a built in one. May be just the resistor..........
Dec 29, 2009 | Polaris New Genuine Polaris Snowmobile...
Polaris 280 In - Ground Pool Cleaner with Booster Pump Logo
183 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
