Fairly new ink cartridge (HP Inkjet) which is almost full but unused for 90 days. Any way to get the ink flowing again?
  • genework1 Sep 12, 2010
    I got the ink to flow by using both methods. Not perfect yet, but at least it is printing. Time and use will perhaps improve it.
  • 10,515 Answers
There are certain tricks you could try :-
1 Run the printer's print-head cleaning utility. The location of this will vary depending on the printer, but it can usually be found on your computer under "Contol Panel" and "Printers," or in the case of printers with LED screens, on the printer's menu itself.
2 Remove the cartridge from the printer if the print-head cleaner doesn't cause ink to flow. Soak it in a bowl or sink filled with enough warm water to immerse the print head nozzles, long enough to see ink beginning to dissolve and flow into the water. Alternately, you can soak a cloth in warm water and use it to clean the nozzles until you see ink begin to flow.
3 Thoroughly dry the nozzles with a soft, lint-free cloth once the cleaning process is complete.
4 Replace the cartridge into the printer and run the printer's print-head cleaning utility.
5 Repeat the cleaning procedure if the cartridge still doesn't print. Reinstall and once again run the print-head cleaning utility.
More often than not, there is still some usable ink inside the printer cartridge for you to use to print out text documents and images. Here are some ways for you to revive your seemingly dried up ink cartridges.
* Print Cartridge Kits. There are a number of print cartridge cleaning kits that would allow you to remove the dried ink clogging your ink printer cartridge so that you can use them again. Just like ink refill kits, make sure that you read and follow the instructions listed carefully.
* Warm water baths. If your printer cartridge has not yet been used, but has already passed the expiration date, you can loosen up the ink by soaking the bottom portion for a minute or two in warm water. This can only be done on printer cartridges that have a copper portion on the bottom part of the printer cartridge.
If the above options do not work, unfortunately you need to buy a new in cartridge.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 12, 2010
Black ink says (8004) replace when 90% full
usual problem - down to the cartridge info chiplocated at the back of the cartridge ( inserted side)- sometimes just cleaning the contact plates is enough- if it still wont work aftervthat - return your ink cartridge to your supplier if they a reputable they will replace and claim back from HP
Dec 18, 2013 | HP Designjet 5500 InkJet Printer
I bought an Inkjet 2800 on ebay which had almost never been used ,it still had the original ink cartridges in which were full. The printer was idle for 3 years and now I can`t get a decent print, All the...
Inkjet printers do not like being unused, especially for years. The print head nozzles get clogged with dried ink when they are unused and even when you insert new ink cartridges the inks won't flow through the nozzles properly. The solution is to replace the print head.
Oct 28, 2010 | HP Business InkJet 2800 Printer
Fairly new ink cartridge which is almost full but unused for 90 days. Any way to get the ink flowing again?
Hi genework1,
Here's a trick I've used with some success. Depending on the cartridge, this is for carriage mount styles like HP, Lexmark, Canon (current models) and others. Remove the cartridge, and soak the print-head portion where the tiny jets are located, in a small shallow dish with clear alcohol. Try swooshing it around a bit, and you may start seeing a discharge of the ink color you're using. Let it soak some more, dry it off and reinstall.
If the old ink is dissolved, then the cartridge may start printing, and it will be a little "weak" until the alcohol is mostly used up. This is not a guarantee to work all the time, but its worth a try. The "tank" style cartridges like Brother uses are another story, since they are reasonably priced containers with no print-head.
They have a tube system feeding ink to the print-head on the carriage. Either the print-head noozles or the tube could become clogged, and require factory service, or a pretty elaborate set of procedures to clear the blockages. I have had mixed results, refilling an empty cartridge with alcohol, and allowing that to try feeding the tubular system, and dissolve the dried ink. If it succeeds, then simply install a new or known good cartridge, and the problem may be solved.
I hope this will give you a chance to get your printer going again.
Regards, Bill
Sep 12, 2010 | Computers & Internet
A new ink cartridge that was working now shows the red light warning and will not print
The problem with inkjet printers is that they needed to keep the print head moist all the time in order to prevent blockage. Try wiping the printhead on the ink with moist tissues untill ink flow freely. You might have left the printer unused for a long time. The ink might have expired too. Check the ink packaging for the date.
Sep 01, 2009 | HP DeskJet F380 All-In-One Printer
Ink tanks are full printer won't print (paper is fed, page comes out blank)
Saw this problem once when the tape under the new cartridge was not removed. Suggest to make sure the cartridges are correctly installed first. If no luck try cleaning the printer heads with the printer software first... (and then physically if it didn't help). Also check if the ink at the head can "flow". (If the printer was sitting a long time unused the ink can gum up.) If these tanks are refilled / reused they might not be good... some tanks cannot be successfully refilled... have purchased printers where manufacturers recommend against this.
Jul 25, 2009 | Canon Pixma MP500 All-In-One InkJet...
Ink level didn't change
s.gif Deskjet 5100 series
  1. Click Start or c01319360.gif , click All Programs , click Hewlett-Packard , and then click Printer Assistant .
  2. Click Utilities .
  3. Click View ink levels .
    • If a cartridge is low on ink, discontinue these steps, replace the cartridge, and then try printing again.
    • If the cartridges contain a sufficient amount of ink, continue to the next step.
  4. Click Printer Maintenance .
  5. Click Clean Cartridges .
  6. Follow the on-screen instructions.
ISSUE: After installing a new HP Inkjet print cartridge, the ink level indicator remains at the previous level. SOLUTION: Continue to print and ignore the ink level indicator. The print cartridge is full of ink, it just is not being measured accurately.
May 29, 2009 | HP Photosmart D5160 InkJet Printer
Indicator light remains lit even though it is a full cartridge
It seems there are "new" chips & "old" chips in these ink cartridges for the HP 1200 inkjet printer. I have a cartridge with a "new" chip in and it is working fine. The printer doesn't read the "old" chips. Something to watch for when using refilled ink cartridges.
Apr 17, 2009 | HP Office Equipment & Supplies
HP 6310 printer ink Level doesen't indicate any ink in printer
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Mar 07, 2009 | HP Officejet 6310 All-In-One InkJet...
Computers & Internet Logo
197 people viewed this question
David Payne
David Payne
