Question about Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4t Washer
I have two issues with my washer, one is that I get the SUD error message even when very little soap is added and second the estimated timer shows one minuet when it runs for another 30 minuets? I have a Kenmore He4 front load washer. I washed a rug that released this muddy substance that has clogged the drain in the machine. I am getting F02 and SUD codes. I cleaned out the drain area in the gasket, but how do I clean the rest out it myself?
  • auntieauntie Jun 09, 2008
    i need to stop getting the sud error code, what is causing it and why wont it just finish the cycle?
    Problem Solver:
  • 14 Answers
WE had a person with the same problem with her HE4 front loaded washer. What we discovered was when we opened up the soap resivour was that soap built up around the float valves causing them to stick.
A technician I knew put vinegar down the soap dispensor and ran the cycle, with the washer empty. He put it on in the hot water mode and ran it for four or five complete cycles like washing clothes.
It worked for him. Try it like it did for him to see if it helps. If not, you will need to contact a service technician to see if the SUD error code means something else.
Sometimes the timer boards get a bit of moisture on them and cause a corrosion headache. I have yet to see anyone figure out a way to dry them off, and when condensation builds up, it usually means there is a problem causing the condensation to get that far up. On some versions a foam seal gets worn out from time, often needs to be replaced to prevent moisture built up.
Another thing that sometimes does it is the back of the machine, will be too close to the wall or have debris back behind there causing it not to be able to breath.
Posted on May 20, 2008
I just had this problem and the repair man took botton of machine off and there is a pump that he unscrewed that had 2 socks a broken pen , etc... now it is working fine
Posted on May 22, 2008
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    My Kenmore Elite front loader keeps on showing the same problems
    Cut down on your soap i only use very little soap and it works great.No more SUD code
    Jul 02, 2014 | Kenmore Elite 45986 Front Load Washer
    Sud flashing on kenmore elite he5t washer
    Are you getting the little melody chimes! Mozart? I read that about the Kenmore's. Your adding either too much soap or the wrong kind. Read owners manual for proper amounts of soap! More does Not mean more clean!
    Jan 16, 2014 | Washing Machines
    Error code "SUD"
    SUD error means there is to much soap being added, the washer will shut down, if it cents to much soap
    Jan 12, 2010 | Kenmore Elite 45986 Front Load Washer
    I have a Kenomore Elite HE4t Washer. I am getting an F02 error message. I've tried to rerun washer & get SUDS on and off. Fo2 message appears again and cycle shuts down. Door will not unlock. Any...
    HI. this code represents a Long Drain issue.
    If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
    Press PAUSE/CANCEL twice to clear the display.
    NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
    Potential Causes
    • Check the drain hose and make sure it is not plugged or kinked
    • Check the electrical connections at the pump and make sure the pump is running.
    • Check the drain pump filter for foreign objects
    • If the above does not correct the problem replace the pump
    Oct 14, 2009 | Kenmore Elite HE4 Electric Dryer
    Sud/F35
    if your using more than 2 tbl spoons of HE detergent, you WILL have the same problem with your new washer." sud "stands for TOO MUCH SOAP
    Jul 24, 2009 | Kenmore Elite 45986 Front Load Washer
    F35 & SuD error codes on Kenmore Elite Washer
    F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
    Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
    "F02" and/or "Sud" error are directly related to a common problem in this case. You have something clogging your drain line and/or drain pump. The error will not go away until you clear the problem. The following links explain how:
    http://www.fixya.com/support/r629564-suds_error_whirlpool_kenmore_front
    http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
    In some cases, the drain pump may require replacment. If something has been lodged in the pump reservoir for any period of time, sometimes the pump impeller can become damaged to the point where it does not pump water. Replacment pumps can be found at searspartsdirect.com or repairclinic.com. Just type in your model number inthe search menu. I hope this helps you resolve your problem and that you do not require parts. Let me know if you require additional assistance.
    Jul 18, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
    I believe the SUDS error is in direct relationship to the clogged drain problem. Yes...the error can be generated by the use of too much soap. But, it is also caused by too much air in the drain pump. This is caused by a clog somewhere. A clog in the drain area of the gasket is not going to cause this. The problem is your drain line and/or drain pump. If you click on the link below, I have step-by-step instructions on how to access the drain pump and clean it out.
    http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
    I have experienced on one occasion where the drain hose coming from the bottom of the wash tub was clogged. This, ironically, was from someone washing a rug that had a ton of sand and dirt in it. I had to remove this hose from the bottom of the wash tub and clean it out. I mention this just in case cleaning the drain pump is not enough.
    I hope you find this information helpful. Reply back if you need further assistance.
    May 14, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
    Kenmore Elite HE4 Electric Dryer Logo
    429 people viewed this question
    Top Kenmore Dryers Experts
    Dan Webster
    Dan Webster
    Sal De
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
