Fairly new ink cartridge which is almost full but unused for 90 days. Any way to get the ink flowing again?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 184 Answers
Hi genework1,
Here's a trick I've used with some success. Depending on the cartridge, this is for carriage mount styles like HP, Lexmark, Canon (current models) and others. Remove the cartridge, and soak the print-head portion where the tiny jets are located, in a small shallow dish with clear alcohol. Try swooshing it around a bit, and you may start seeing a discharge of the ink color you're using. Let it soak some more, dry it off and reinstall.
If the old ink is dissolved, then the cartridge may start printing, and it will be a little "weak" until the alcohol is mostly used up. This is not a guarantee to work all the time, but its worth a try. The "tank" style cartridges like Brother uses are another story, since they are reasonably priced containers with no print-head.
They have a tube system feeding ink to the print-head on the carriage. Either the print-head noozles or the tube could become clogged, and require factory service, or a pretty elaborate set of procedures to clear the blockages. I have had mixed results, refilling an empty cartridge with alcohol, and allowing that to try feeding the tubular system, and dissolve the dried ink. If it succeeds, then simply install a new or known good cartridge, and the problem may be solved.
I hope this will give you a chance to get your printer going again.
Regards, Bill
Posted on Sep 29, 2010
Print outs are blank, cartridges are fairly new, indicator shows there is ink almost a full cartridge! why doesn't any think print out?
The ink-jets that s[t]uck ink from the cartridges and spray the ink onto the paper are CLOGGED.
Use the printer-software on your computer to run a few "print-head-cleaning" cycles.
Jan 05, 2011 | Office Equipment & Supplies
HP 7780 suddenly stopped printing in red. I have changed the cartridges several times. I am using brand new HP cartridges. Have cleaned the print heads, aligned several times, nothing has heled. The...
Hi Good day!!!
Maybe your print head is clooged (red)
Then most about 98% are more likely to be an ink clog which just needs to be unclogged using something like print head cleaning solution
Basically, if a print head has been left unused for some time... moisture inside the ink begins to evaporate and instead of liquid ink, a thick inky jelly begins to form inside the print head.
When this occurs white lines appear in prints and most people not realizing the problem, will replace their inks... But when that does not work. Some assume they have an electrical fault, and replace their print head, others will replace their printer !
But provided there is no obvious print head damage? In 98% of cases it simply needs a little patience and print head cleaning solution injecting directly into the print head to dissolve the dried ink trapped inside. This will dissolve the clog and allow your expensive ink to flow once again. Most will then print as new.
Thank you for using fixya
Jan 03, 2011 | HP Office Equipment & Supplies
I bought an Inkjet 2800 on ebay which had almost never been used ,it still had the original ink cartridges in which were full. The printer was idle for 3 years and now I can`t get a decent print, All the...
Inkjet printers do not like being unused, especially for years. The print head nozzles get clogged with dried ink when they are unused and even when you insert new ink cartridges the inks won't flow through the nozzles properly. The solution is to replace the print head.
Oct 28, 2010 | HP Business InkJet 2800 Printer
My dell 720 is printing blank pagesa few days after i got the black cartridge refilled. I tried soaking it in hot water and run in the "clean nozzle application" and still nothing...any suggestions
If you had it professionally refilled,.. take the cartridge back to the place that did it have them do it properly for you. If you did the refill yourself,.. you may not have followed the procedure correctly or may have not filled the cartridge in time for the ink to not have dried inside the end of the cartridge (this happens when someone fills a cartridge that has been empty for a few to several days or more and does not store it correctly when it is pulled from service). When the ink dries inside the nozzles, it is definitely hard to resurrect the cartridge without using isopropyl alcohol (90% Technical for head cleaning and such) not the most common (Drug Store 70%). I have been successful in doing the following procedure on about 40% of the cartridges with the same issue you are having after refilling.
1) obtain a clean, non-metallic cup or container (with a lid) that is wide enough to set the cartridge into and deep enough to allow the cartridge to set all the way inside and be covered with a lid.
2) Pour 1/4" to 1/2" of 90% isopropyl alcohol into the cup.
3) Place the cartridge in the cup with the print head nozzles in the alcohol.
4 Let this sit in the alcohol with a cover on for 10 minutes,.. you will notice the alcohol dissolving the ink. This is good because the alcohol will dissolve the dried ink in the capillary tubes and electrostatic ink valves that are keeping the new ink from flowing.
5) Remove cartridge from cup and set the cartridge print head on a dry cellulose sponge for a few minutes. The sponge will have ink seeping into it,.. that is fine.
6) Place cartridge in printer and do 1-3 test pages. If the ink does not flow yet, repeat the procedure steps 3,4,5,and 6. If after the 4th cycle of repeating steps, the cartridge does not print, then it most likely needs to be tossed and replaced.
I hope this is helpful for you now and in the future
For future reference: Using water to do this,.. especially tap water will plug up the capillary tubes and electrostatic ink valves with mineral deposits and not dissolve the dried ink properly,... not to mention the water will not get up far enough, due to air in the water.
Feb 08, 2010 | Dell Inkjet 720 Printer
Ink tanks are full printer won't print (paper is fed, page comes out blank)
Saw this problem once when the tape under the new cartridge was not removed. Suggest to make sure the cartridges are correctly installed first. If no luck try cleaning the printer heads with the printer software first... (and then physically if it didn't help). Also check if the ink at the head can "flow". (If the printer was sitting a long time unused the ink can gum up.) If these tanks are refilled / reused they might not be good... some tanks cannot be successfully refilled... have purchased printers where manufacturers recommend against this.
Jul 25, 2009 | Canon Pixma MP500 All-In-One InkJet...
50 SERVICE error on my HP laserjet 4MV
Have you tried looking on the hp website for software updates ? maybe could try reinstalling the drivers for the machine . I don't know if ink dries up while being stored away for so long you might wanna check into that aswell . hope that helps later .
Nov 13, 2008 | Office Equipment & Supplies
Ricoh Afficio G700 Black Ink not working
When opening the print dialog, there is a button for performing maintenance. On the maintenance menu, there is a button for clearing the print jets. That did the trick.
Apr 12, 2008 | Ricoh Aficio G700 InkJet Printer
Dissapearing yellow
I run about 100+ canon printers from s800 up to the new ip4500.
I have met and solved almost every problem I find described on the web. Your problem with the disappearing yellow ink can be only one thing. The ink cartridge has not been sealed after you injected the ink. If there is even the smallest avenue for air to get into the cartridge it will allow the ink to flow very rapidly back out of the cartridge and into the waste ink pads in the bottom of the printer. You won't be able to see a puddle of ink under the printer until much later when you have done many cleanings or installed many leaky cartridges.
Dec 23, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
CAnon Pixma IP 90
try waiting for about a day so the ink can flow down to the print head then try again
Oct 14, 2007 | Canon PIXMA iP90 Mobile Printer
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
