Question about Danby Dehumidifier
The displays indicates E2. None of the buttons, except the on/off, can change the display. The dehumidifier does not start.
  • 1 more comment
  • Christian Pluta Sep 12, 2010
    I unplugged for 10 minutes and the E2 is still there. How much should this type of service repair cost?
    and where do I call for service? The 1-800 number or the store where I purchased the product.
    Okay. Thanks.
    Genius:
  • 1,035 Answers
Hi. Error E2 means Temperature sensor error. Try to unplug the unit for 10 mins and plug it back in. If error repeats, call for service. Sensor need to be replaced.
Posted on Sep 12, 2010
  • Angelito Rabago
    Angelito Rabago Sep 12, 2010
    you need to call the manufacturer's 1-800 number since unit is still under warranty.
Is there a special code to direct water to pump, dump bucket or drain
That would be the "Pump" button on the control panel. When you press it, your dehumidifier display should indicate "PUMP", and the unit should start pumping water out that little port at the center rear of the dehumidifier.
Alternatively, you could stand the dehumidifier on a counter and direct your waste water out the larger hose connection into a sink.
I personally carry it (more than five gallons per day) upstairs to the laundry, because it's distilled water - the softest water you can get. Works GREAT in the washing machine. 8) 8) 8)
Jul 30, 2014 | DeLonghi DD50P Dehumidifier
My frigidaire dehumidifier fad704dud does not turn on when plugged in
Good Morning Robert,
I understand your Frigidaire dehumidifier, model# FAD704DUD, does not turn on when it is plugged in. I also see that the display lights up briefly and there are no error codes. Your appliance is designed to operate between 41 degrees F (5 degrees C), and 96 degrees F (35 degrees C). It will not work properly if the temperature is out of this temperature range, or the performance of the unit will fall greatly. The "Compressor" circuit has an automatic 3 minute time delayed start if your dehumidifier is turned off and on quickly. This prevents overheating of the compressor and possible circuit breaker tripping. Make sure the tank is fitted correctly otherwise your appliance will not turn on. If you are still having trouble, you can contact your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Frigidaire Dehumidifiers
I HAVE A RIVA COLD UNIT IT IS WORKING FINE NUT DISPLAYS E2 ERROR COMPRESSOR MODEL CAJ95132
Reset the system read your owner manual section troubleshooting or download from www.retrevo.com or www. manualslib.com
God bless you
Oct 29, 2013 | Haier 45-Pint Dehumidifier
Quit running and displays E2 in the F/C window.
E2 error indicates that the air intake filter needs to be removed and cleaned. Turn the Master ON/OFF Switch to OFF and unplug the unit, before removing the filter. If you wash the filter, it must be completely dry, before reinstalling it. DO NOT run the dehumidifier without the clean filter installed.
Hope this helped you to solve the problem. Please let me know. Thanks.
Jun 19, 2011 | Haier 45-Pint Dehumidifier
Haier dehumidifier Model DE45EK-T--just bought. Displays E2. Power button not working--had to unplug to turn off.
It takes a couple if tries. Have to press it twice to get down low and have to have at high or low speed.
Jun 05, 2011 | Haier 45-Pint Dehumidifier
Haier dehumidifier model de45ej-t What does code e2 mean? Unit does not run.
Dehumidifier (DE45EJ-L) shows only E2 on the display -- no "buttons" work. Had been working perfectly -- we turned it off a few days ago. Any suggestions??
Jan 09, 2011 | Haier DE45EAL Dehumidifier
What does an E2 code mean? I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and...
I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and error code E2 keeps comming on
Jun 30, 2010 | Haier HD451E Dehumidifier
Danby  Dehumidifier Logo
522 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
