How do i set up my router to the computer and then wirelessly to my wii console
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 144 Answers
Start off by turning on your Wii and access the main menu.
2.Click “Wii Shop Channel” and press “Start”.
3.Next, it will prompt you to configure internet settings. Press “Enter Settings”. (or you can just click the button on the bottom left corner and click system settings)
Posted on Sep 13, 2010
I keep getting a code 52030
If you are trying to connect with a wireless router, This indicates a problem with your Wii communicating with your wireless router.
There are a couple things you can try/check to help fix this problem.
1 - Try using a different channel on your router and update your Wii to take to the router on that channel.
2 - If your router is using WEP (encryption), make sure your Wii is set to the same encryption.
3 - Make sure the MTU values on your router match those entered on your Wii.
Also note that if you make changes to your wireless router and you have a computer that uses that router too, you'll need to update your computer to match the new settings on your router.
Jun 07, 2015 | Nintendo Wii Video Game Consoles & Games
What is error code 51031
Error Code: 51031
The only wireless network within range of your Wii console is not configured or is not compatible with the Wii.
  • Check for interference that may be preventing a successful connection:
Various factors affect connecting a Wii to the internet with a WiFi connection as well, including signal strength, distance from the wireless router to the console and obstacles such as walls and ceilings that interfere with the signal. If you're using a G router and you have your Wii is too far away or, has obstacles in the way, it will not connect. You should use an N-Router if there is a significant distance between the console and the router or if there are obstacles. Here is everything you need to know about connecting your Wii to the Internet.
Make sure other wireless devices such as cordless phones or wireless speakers are turned off, and that the Wii console is an open area without objects or electronics blocking the signal. (For instance, if the Wii is placed in a crowded entertainment center, try moving the Wii somewhere with more room.)
Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker.
  • Check to see if the router you are using is a known to be incompatible. Click here to view the list. If your router is known to be incompatible, you'll need to use a different router if possible.
  • Make sure that the SSID (network name) matches exactly to what you have entered in the Wii console's settings. To verify:
  1. Login to your router's settings (click here and select your router, if available, for information).
  2. Look for the section for SSID (typically in the "wireless settings" area).
  3. After you find the SSID (network name), verify in the manual settings of the Wii console that the SSID appears exactly as listed in the consumer's router. This includes making sure capitalization, spaces, or special characters match exactly.
  • Look up your router, if available, in the list of wireless routers, and check for any special notes that may be necessary to get the connection to work properly.
  • The router may not be assigning an IP address to the Wii console, and a connection using the "Manual Settings" may be necessary.
  • Your router may require a firmware update to work properly with the Wii console. Firmware updates can usually be found on the router manufacturer's website; consult the manufacturer for more information.
May 10, 2011 | Nintendo Wii Console
I have an error code 52130 and my Wii will not connect to Netflix. My wireless network is working and can connect to my phone and computer. I have tried to reset my password. I need and answer please.
This error is caused by a wireless router firewall issue.
To solve this error, try to manually setup the Wii console using your network IP settings.
To do a manual setup of the Wii console using your network IP settings :
  • On a PC, click Start > Run > type CMD and press Enter > type IPCONFIG/ALL and press Enter. On Windows Vista, click Start > type CMD in the Start Search box > click on CMD icon > type IPCONFIG/ALL and press Enter.
  • Locate IP settings and use them to manually set the Wii console.
  • Restart your wireless router by unpluging the power from the wall and plugging it back in. Try to connect the Wii console to the internet.
You may also try to disable the wireless router security or firewall. Try again to connect the Wii console to the internet.
May 08, 2011 | Nintendo Wii Console
I put Internet on the wii system and when I went to use it, it said error code:52230
Error 52230 is a problem with your router's firewall.
If you are using America Online (AOL) broadboad, you may experience problems connecting the Wii console to the internet. Contact AOL for more assistance.
If you are using wireless routers with Comcast firmware, you may experience problems connecting the Wii console to the internet because of incompatibilities with the Wii console. If this is your problem, then you likely need to get a new router or switch ISPs.
If you are using a Netgear wireless router, disable the SPI firewall setting which is usually found under the WAN Settings of your wireless router. To get to the WAN settings, on your computer, type in 192.168.0.1 in your address bar.
Apr 16, 2011 | Nintendo Wii Console
My wii will not update gives me eror 32002
If you get an error code of 32002 or 52030 on you Wii console, this indicates a problem with your Wii communicating with your wireless router. There are a couple things you can try/check to help fix this problem.
Mar 16, 2011 | Video Game Consoles & Games
I am trying to update my wii so i can get netflix. i keep getting an error code of 32002. how can i fix this?
If you get an error code of 32002 on you Wii console, this indicates a problem with your Wii communicating with your wireless router.
There are a couple things you can try/check to help fix this problem:
1.Try using a different channel on your router and update your Wii to take to the router on that channel.
2.If your router is using WEP (encryption), make sure your Wii is set to the same encryption.
3.Make sure the MTU values on your router match those entered on your Wii.
Feb 03, 2011 | Nintendo Wii Console
Error code 52030
Unable to connect to your wireless network
Likely cause: It appears that the security settings entered into the Wii console are not the same as what your wireless router is set to allow, or your router is not able to assign the Wii an IP address.
How to fix: Make sure the security key and security type are entered into the Wii exactly as they appear in your router's settings; manually assign an IP address to the Wii.
Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again.
Jan 23, 2011 | Nintendo Wii Console
How to set up nintendo wii internet
  • 1 In order to set up your Nintendo Wii internet connection, you need to have high speed internet service, such as DSL, cable, or fiber optic.
    If you want to use a wired connection for your Wii, you will need to purchase the Nintendo Wii Lan Adapter and a long ethernet cable to reach your router or modem. The Wii Lan adapter is available from many sources for about $30 and the cable will cost you around $10 or more. If you want to plug in your computer and Wii at the same time, you will need a router. You do not need a router if you are planning on unplugging your computer when you use Wii over the internet. Honestly, wireless routers cost about $35 and don't require a cable, so I purchased a wireless router instead. Plus, I don't want an ugly cable running across the room.
    If you still want to use the Wii Lan adapter to connect to the internet, here are the steps to connect your Wii Lan adapter to your Wii game system:
    Make sure your Wii game system is turned off.
    Attach the Wii Lan adapter to the USB port on the back of your console.
    Connect the other end to an ethernet cable that goes to your router or modem.
    Turn your console back on.
  • 2
    If you are using the Nintendo Wii Lan Adapter to connect to the internet, follow this step. If you are connecting to the internet via a wireless router, skip this step and go to step 3.
    To connect your Wii via a wired connection:
    Go to the Wii Menu.
    Click on the round Wii button on the lower left corner.
    Click Wii Settings.
    Click the right arrow to go to page 2.
    Click on the Internet button.
    Click Connection Settings.
    Click Connection 3.
    Click Wired Connection.
    Your Wii will do a connection test and hopefully everything will be all set. You are now finished.
  • 3
    To connect your Wii via a wireless connection:
    Go to the Wii Menu.
    Click Wii Settings.
    Click Connection 3.
    Click Wireless Connection.
    Select Search for Access Point. Click OK.
    Select the access point you want to use. Click Save and OK.
    You may be prompted to enter your password.
    Your Wii should now be all connected.
  • Nov 28, 2010 | Nintendo Wii Console
    Cannot get Netflix instant streaming to work on my Wii console. Wii repeats error code 503. My router is Belkin_N_Wireless_227015 which is the SAME connection shown in the Wii console test. What's wrong?
    Error Code: 227015 Specific Error Code Not Found - General Troubleshooting
    • Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available).
    • Check your router's broadcast settings to find out if it is set to "G", "B", or "Mixed." Mixed typically works best, but try all three to see if it improves the network connection to the Wii console.
    • Make sure that any other interfering devices, such as microwaves and cordless phones, are turned off. Wireless keyboards and mice may also cause interference.
    Aug 26, 2010 | Nintendo Wii Console
    Error code #51031
    Error Code: 51031
    • Check for interference that may be preventing a successful connection. Click here for tips.
    • Check to see if the router you are using is a known to be incompatible. Click here to view our list. If your router is known to be incompatible, we recommend using a different router if possible.
    • Look up your router, if available, in our list of wireless routers, and check for any special notes that may be necesary to get the connection to work properly.
    • The router may not be assigning an IP address to the Wii console, and a connection using the "Manual Settings" may be necessary. Click here for help.
    • Your router may require a firmware update to work properly with the Wii console. Firmware updates can usually be found on the router manufactruer's website; consult the manufacturer for more information.
    Dec 05, 2009 | Nintendo Wii Console
    Computers & Internet Logo
    David Payne
    David Payne
