Question about Sony ICD-B200 Digital Voice Recorder
It dies really fast even if there are new batteries in it . i can only have it on for a sec before it dies .
  • 3 more comments
  • fuluck13 Sep 12, 2010
    its the unit itsself i tried miultiple batteries brand new batteries it drains the batteries life out real fast but it turns on to the point of wanting to kisten to a filed recording then it dies on me
    can i at least some how plug it into my computer to receive the files off of it that i already saved
    can i plug my recorder into my computer and recieve the saved files i already have saved on it
    is there an internal batterie besides the AAA batt. that it takes ?
  • 3,083 Answers
This could possibly be a slightly oxidized battery or switch terminal, but it could also be a cracked solder trace or cold solder joint. First thing to try is to make sure the battery contacts inside are clean (clean them with a qtip and at least 90% isopropyl alcohol, or a pencil eraser). If that doesn't help, you can try spraying some electrical contact cleaner on the on/off switch, to try to clean it off.
Other than that, the unit will have to troubleshot, since it could also be a jammed tape or oxide build up on the tape transport. In that case, the tape drive has to be cleaned. You can buy tape cleaners, or have someone clean it. If you google Handheld Digital Voice Recorder Cleaning you will find some sites and info about it.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 12, 2010
  • 10,515 Answers
This seems to be a problem with circuitry. This usually happens when more energy is taken out of the battery within few seconds. You might have observed the battery to be quite hot after exhaustion. The recorder needs to be repaired for the same.Unfortunately, this is not a DIY and needs you to send the unit for repair.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    taran_2005 Sep 12, 2010
    Thanks for your response!!
    For you to transfer the file ( without damaging or taking apart the recorder ) is not possible as you need to get the device working before you could synchronize the device. As you would change the battery, within seconds it will dissipate and the synchronization would not take place. I know it's hard and i wish i could have a better solution.
    Hope i helped you.
  • taran_2005
    There is no such option in this model. If there would have been an alternate solution, i would be the first one to inform you. I understand the concern, however i am better being honest rather than telling you different tricks which i know would not work.
    Hope i helped you.
    President:
  • 2,777 Answers
It just shuts itself off, is that correct? ANd you have tried multiple batteries? If so then the actual unit itself is having issues. How long have you owned this unit? It may still be under warranty.
Let me know and I will continue to help.
Thanks Tim
  • Tim Grayson
    Tim Grayson Sep 12, 2010
    I would be able to help you more but you even rated my service as "unhelpful" so I can no longer continue.
    Thanks
    Tim
Brand new batteries will die really fast and we can't figure out why
in some digital cameras when you use lcd screen to take a picture battery consumption is very high, try using the optical veiw finder, also you can use litium batteries which is more expensive than normal alkaline.
there is a new alkaline battery just for digital cameras available in good stores , from energiser
regards
Dec 29, 2010 | Olympus SP-320 Digital Camera
1997 jetta will not start. the battery has been disconnected and charged. Is it true that when the power has been disconnected that there are some security steps to go through before the car can be...
all vw MUST be reset after battery dies/changed.put key in door,unlock/hold key over 30 secs(windows go down)then lock/hold key over 30 secs(windows go up/sunroof closes)then press unlock button on remote for 30 secs......RESET DONE......(try this for fun....sit in car after turning off engine/remove key,drivers door keypad is still live(until you open door)ALSO when engine is running lower any window and then raise up with fingers in top of door,the window will rollback.(if you do it once it hurts..twice it really hurts..three times it traps your hand in.)ALL THIS is NOT in the handbook.......
Nov 06, 2010 | 1997 Volkswagen Jetta
Ipod touch
Your battery is draining too fast . There is some problem with the internal battery .Since it is brand new I will prefer you to go to apple service center to get your itouch repaired . Some products will be having these kind of problem . Apple will replace it .
Hope this helps .
Thanks for using Fixya.
Feb 27, 2010 | Apple iPod touch
Dare dies FAST
If there is a sd card in the phone try taking it out and see if it dies really fast.
Jan 05, 2010 | LG Dare VX9700 Cell Phone
1999 Pontiac Sunfire won't even turn over, but the
The radio will work even with a dying or discharged battery.
First, be sure to check all of your fuses in the engine compartment.
A full battery will keep the headlights bright with the engine off. With a dying or discharged battery, the headlights will be noticeably dim.
When you turn the key to crank the engine, does the starter try to turn or make a fast clicking? If so, the battery if low or dying. If it makes a slow click then stops, then it's REALLY dying.
If you don't have a battery charger, go to Walmart and get some jumper cables. Hook up a friend's car to yours. If it starts, then the battery was low, either from a bad battery or a bad alternator.
If it doesn't, you have electrical problems, possibly a bad starter or starter solenoid.
Jun 30, 2009 | 2005 Pontiac Sunfire
Replace the fuel pump, car start idle fasts for 10 sec. then die
did you replace the line filter,it may be cloged.
Jun 19, 2009 | 1999 Saturn SL
Battery dies really fast
change power setting or get a new battery
May 29, 2009 | LG Vu CU920 Cellular Phone
Since it's a new phone, I would suggest checking the outlet the charger is plugged into. The outlet may not actually be charger your phone. If you try another one and the battery still drains quick, I'd definately see if I could return it.
Apr 02, 2009 | LG Vu CU920 Cellular Phone
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
