Question about RTO Bodyguard T300 Commercial Treadmill
I have a Reebok ACD2 treadmill. When I insert the key, all the lights go on and the incline works fine. However, when I press start to move the belt, it does not move, but the readout says that I am moving at a certain speed - whatever it was set to (1mph, 2mph, etc) Any thoughts about what might be wrong. I just moved and it was working before the move. Could something have been broken in the move? Thanks.
5 Suggested Answers
SOURCE: bodyguard t300 treadmill. belt will not turn
Smashed harness created short.
Posted on Jan 27, 2009
bwinton
  • 83 Answers
SOURCE: Treadmill Incline Works, belt does not move
Check the drive belt. It may be loose or broken. If the belt is loose, then to tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down.
Posted on Apr 30, 2010
SOURCE: Brand new Sole F85 incline shows e2 and stops
Same thing happens to me. Any solutions?
Posted on Dec 04, 2010
  • 33 Answers
SOURCE: New F80 treadmill. Belt doesn't move after hitting
hi, check the 12pin communication cable
Posted on Oct 11, 2011
Incline not working on Reebok ZR9
If you wish get some details about treadmill repair check the link below
www.electro-medical.blogspot.com
Jun 30, 2016 | Reebok Exercise & Fitness
How do you shut this thing off . the lights on the display stay on. reebok 8700es
Hols the stop button and the speed decrease button down while inserting or attatching the key (magnet). There should be a "d" on the screen, press the incline down button and it should go away. As soon as it disappears, your done. Just pull the key off and your display will shut off.
Hope this helps
Nov 06, 2010 | Reebok 8700 ES Treadmill - Silver Service...
Treadmill kph to mph
No need to take console apart, power up the treadmill, take the safety key out then hold down the start button and the incline down button at the same time then insert the safety key. You'll now be able to toggle between KPH and MPH by using start button
Mar 21, 2010 | Reebok Exercise & Fitness
The belt won't move and the incline is stuck. display isn't working properly either
reebok 8000es incline keeps going up and down and will not stop or go into any other mode
Mar 01, 2010 | Reebok 8050 ES Treadmill
Ifit treadmill will not incline but everything else works, how do I fix the incline
You may need to calibrate the incline. Do this with the following procedure.
Safety key out
press the stop and speed up buttons at the same time while inserting the safety key. (you are now in diagnostics)
press the stop button one time only.
now press the incline up button (incline motor should start moving up)
incline will go up to the top and then all the way to the bottom. when it gets done you can remove the key. Reinsert the key and you should be operating normally.
Good luck Tim
Nov 23, 2009 | Proform Quick Burn Pro Treadmill with 12...
Where can i get a reebok TR3 treadmill user manual
Updated linkhttp://www.iconservice.com/CustomerService/manualsProductManuals.do?model=RETL1600&modelName=REEBOK+RT1000+TREADMILL&version=1&company=11&language=
Oct 25, 2009 | Reebok Rt1000 Treadmill Walking Belt
Treadmill wont incline all the way
With the key in the console, press one of the incline buttons. While the incline is changing, remove the key. After a few seconds reinsert the key. The treadmill will automatically rise to the maximum incline level and then return to the minimum level. Thi will recalibrate the incline system.
Sep 30, 2009 | Reebok 8050 ES Treadmill
Reebok ACD2 need manual
Icon manufactures the units for Reebok; go here and pick your year (the last 2 numbers). You may need to look at the image in the manual if you don't know your unit's year:
http://www.iconservice.com/cgi-bin/ncommerce3/ExecMacro/manuals.d2w/report?man=REEBOK&name=acd2&lan
Mar 11, 2009 | Reebok Exercise & Fitness
I have a Reebok Fusion Treadmill, an Oil Can Icon has appeared
I have the same problem. I phoned Reebok Tech Support 01908 512244. It is a timed icon to advise the deck should be lubricated. If you have done so / do this regularly you can ignore it. To remove the icon follow the instructions they emailed me. Hope this works Cheers John Please follow procedure below:
1. Keep power on and remove the safety key
2. Press and hold incline down and speed down, at the same time insert the safety key
3. You can release the “Down” buttons. (you will now hear a beep)
4. Press Speed up
6. Press stop. You will now hear a beep and the icon will disappear
Dec 02, 2008 | Exercise & Fitness
RTO Bodyguard T300 Commercial Treadmill Logo
148 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
