Question about Acer Computers & Internet
Power connector is loose at laptop - Acer Computers & Internet
    Sergeant:
    Champion:
  • 305 Answers
This is because the power lead has been tugged on it to left or right and the power pin has been worked loose. just be very carefull with it because it will cost £100 approximatly to repair. you can not do it yourself sorry.
hope this helps
Posted on Sep 12, 2010
My power cord is plugged in but the power meter
yes, this could be the connector on your motherboard issue. ask for replacement or repair from your manufacturer if unit is still under warranty.
Mar 27, 2010 | ASUS G1S-A1 Notebook
Loose power connection on sony vaio PCG 7V1M
I'm assuming the laptop is out of warrantee.
It sounds like the power adapter jack is broken. To replace this you have to take the laptop apart down to the motherboard, unsolder the jack, solder on the replacement and reassemble the laptop. This is not something a novice should attempt.
Check with your laptop repair shops. The replacement/repair should be under $100.
Mar 02, 2010 | Sony VAIO Notebook
Loose power connector
look on the toshib website theyshould have a manual
Jan 06, 2010 | Toshiba Satellite A105 Notebook
My power cord is loose. It plugs in and charges,
Hello !
If I'm understanding you correctly, the wiggle is from the laptop. Sounds like a problem is about to happen. Your Presario has a loose power jack (connector inside the laptop). It is a part that can be replaced.
If you need further info, let us know.
Hope this helps.
Oct 23, 2009 | Compaq Presario CQ60-220US PC Laptop
Dell Inspiron 1505; Battery does not charge; DC jack is loose..
You have either a faulty connector plug on the power adapter which connects into the laptop or the loose power input socket on the laptop is faulty. This is because you need to press the connector upwards to make electrical contact.
Test the connectot plug on the power adapter with a multi-meter, wriggle the connector to see if your get the voltage to fluctuate, if it does not then the connector is OK anf the fault is in the laptop power input socket.
If the fault is in the power adapter plug or the laptop's power input socket, this can be repaired, a techo would have no trouble in repairing these faults.
May 22, 2009 | Dell Inspiron E1505 Notebook
Loose power cord input, the power cord receiver in the laptop is so loose it must be hand held to make the power connection.
The power connector on your laptop should be resoiled or replaced (if broken).
That means the laptop should be disassembled (almost complete) to get close to the connector.
I am not sure if you can do that yourself. It should be done by a QUALIFIED SERVICER.
Trying to do this by yourself may make your laptop unusable any more.
Also, you should do this as soon as possible, because next time you might not get power, even hand-held like you do now!
When you'll solve the problem, be more careful with the connector, easy plug/unplug.
Regards.
Mar 26, 2009 | Computers & Internet
My latitude d600 will not start.
Is the connection on the Laptop loose? Most power connectors are soldered onto the motherboard and are notorious for becoming loose. If the connector is loose you it may be shorting out the adapter. I would have a professional look at it before plugging the adapter back into it. If you are shorting out the adapter it could present a fire hazard. Most laptop repair companies will resolder the connector for around a $100.
Jan 27, 2009 | Dell Latitude D600 Notebook
Loose power connector, how do I take laptop apart to access it?
http://www.irisvista.com/tech/ Be very careful and make sure you have a good working surface. NO STATIC. The power connections on the Toshiba is the only flaw on the Toshiba systems. You can get the new piece from Ebay for around $5. Just be very careful on working with the solder. Do not apply too much heat. The power connector is located near other intergrated components that are sensitive. Good Luck.
Dec 24, 2008 | Toshiba Satellite M35X-S111 Notebook
Balance #CN6555 note book
A local PC store should be able to supply at least the power connector that is within the laptop. A lot of laptops only have solder points holding the power connector in place. Over time and putting pressure on the power cord will loosen those points. The power connector itself should cost about 50 bucks. Having it installed depends on labor charges.
G'luck
Oct 23, 2008 | Balance CN6555 Notebook
Power problems
Hi, it seems there is some loose connection in the power supply section. open and find any power connector loose/ fix all connectors gently.
thank you
Aug 16, 2008 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
