Question about RCA HD52W59 HDTV Projection Television
My mute will not turn off,i have no vol,help - RCA HD52W59 HDTV Projection Television
  • RCA Master
  • 8,617 Answers
The small signal board is most likely defective and need replacement. You can get replacement boards from www.tvrepairworld.com
Posted on Sep 12, 2010
Unmute handset
Mute Microphone
With the handset
You can temporarily turn Off the microphone so that the person you are talking with cannot hear you.
1)Press menu/del during talk mode (while phone is in use).
2)Press ring/vol/? or ring/vol/? to move the pointer to Mute and then select/
Mute On and appear in the display. To cancel muting, repeat above step again when Mute
is set to on, Mute Off appears.
With the base
While using the base speakerphone, press mute on the base to turn Off the microphone.
Press mute again or press (speaker) to cancel muting.
Jan 01, 2015 | Uniden Lands Phones
How do I turn up the volume on my ASUS laptop?
One way is to click on the Sounds Icon in the Tray Notification Area, adjust volume. OR , F10(mute),F11(vol down),F12(vol up)
Feb 26, 2013 | ASUS Eee Computers & Internet
I don't know how to turn up the volume on my asus laptop?
F10(mute),F11(vol down),F12(vol up) OR, click on the Sound Icon in the Tray Notification Area, adjust volume.
Feb 26, 2013 | ASUS Computers & Internet
Thompson dvd player unlock code dv2137
Just bought THOMSON DV2137 in Australia (region 4) It plays Aus but not US. A small slip in the user's manual gave these (verbatim) instructions. UNFORTUNATELY it isn't working on my player."This unit has been set to play region 4 DVD discs. If you wish to use this unit outside of region 4 territory you can change the region setting by following the instructions below.1) Turn on the unit.2) Remove disc and press SETUP to enter SETUP menu.3) Press VOL+.VOL-,VOL+,VOL-, by order, then press MUTE to enter Region Code setting. [stays in SETUP menu]4) Press LEFT / RIGHT to choose between 1-4 or ALL region."
Perhaps this will work for someone else or will trigger a clue.
Nov 22, 2011 | Televison & Video
Volume on G E model 21028GE3-4
To adjust the speaker volume, press up/down on the base unit.
To change the ringer volume:
Make sure your phone is OFF (not in talk mode).
Press the MUTE/PROG button to go to the main menu.
Press CID/VOL (up or down) button to scroll to "HANDSET SETUP".
Press MUTE/PROG button to confirm.
Press CID/VOL (up or down) button to scroll to "RINGER VOLUME".
Press MUTE/PROG button to enter the menu. "SET RINGER 1HI 2LOW 3OFF" shows in the display.
Use the touch tone pad on the handset to select 1, 2 or 3, or use the CID/VOL (up or down) button to scroll to your selection. HI is the default setting.
Press the MUTE/PROG button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
To change the receiver volume: When the handset is ON (in talk mode) you may adjust the receiver volume by pressing the CID/VOL (up or down) button.
If you need a manual, you can download one here.
Oct 06, 2011 | GE 21028GE3 Cordless Phone
My acer travelmate 2350 laptop has no sound checked all the vol and mute settings still no sound can yo help
my acer travelmate 2350 laptop has no sound checked all the vol and mute settings still no sound can yo help
Jan 30, 2010 | Acer TravelMate 2300 Notebook
I need help with removing captions
This information was found on the Magnavox website http://www.m4c.magnavox.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=TV_CONVENTIONAL_CA&sct=TV_LARGE_25_29_SU&grp=TV_GR&session=20090602222010_68.190.209.25&ctn=27MS343S&mid=Link_UserManuals&hlt=Link_UserManuals in the owners manual on page 20. If this information does not solve your problem. Try calling Magnavox customer support at this telephone number 1-800-705-2000. Give them the model number of your television and tell them about the problem you are having with not being able to turn of the closed caption feature. I hope this helps you solve your problem. 1Press MENU to show the on-screen
menu.
2 Press VOL+ or VOL- until SET is highlighted.
3 Press CH+ or CH- repeatedly to
highlight CLOSED CAPTION.
4 Press VOL+ or VOL- to display the
CLOSED CAPTION menu.
5 Press CH+ or CH- to select the
closed caption you want (OFF, CC-1,
CC-2, or CC-MUTE). CC-MUTE sets
the TV to show closed captions when
you press MUTE. The TV volume will be
disabled until you press MUTE again to
restore the sound.
6 Press VOL+ or VOL- to confirm your
selection.
7 Press TV/AV/EXIT to remove the
menu.
Apr 23, 2009 | Philips Magnavox 27MS343S 27" TV
Volumn is too loud
Hey Bosie Mike 3,
If you missed something in the manual so did I.
I was just pouring over the instructions and I don't see anything for a vol lock or anything of that nature. I can only assume 17-18 is the "standard" vol for the unit, and defaults to it when you turn it on.
Wish I could help more.
Jon
Go Ahead. Use Us.
May 07, 2008 | GPX KCL8807DT TV/DVD Combo
Close caption turns on and off by itself problem
Check the cable box to make sure the captions aren't truned on in the cable box.
If not -if it really is the Magnavox caption service- then -
This is assuming you have the original remote:
1 Press MENU to show the on-screen
menu.
to display the
CC-2, or CC-MUTE).
CC-MUTE sets
restore the sound.
to confirm your
selection.
menu.
Feb 25, 2008 | Philips Magnavox 27MS343S 27" TV
RCA HD52W59 HDTV Projection Television Logo
19 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
