Question about Pride Value Line Revo Scooter 3 Wheel
I had a clicking noise in my back wheels. Removed wheels and greased the axles. Now the scooter will not move. There seems to be no power to the wheels.
    Scholar:
  • 192 Answers
There is a linkage spring that you might have undone when you removed the wheels. hate to tell you, but you need to remove them again and check to make sure the spring is on..... Guy
Posted on Sep 12, 2010
Greasing the axle
The front wheels don't use axles, instead they use roller bearings similar to auto wheel bearings. Scooter front wheel bearings are usually sealed bearings or shielded. If the bearing is stiff or ruff and a sealed bearing you must replace it. Sometimes you can revive a shielded bearing by soaking in carburetor cleaner rotating soaking rotating soaking until the bearing runs smooth. Then you repack the bearing with grease. To repack a bearing you must place some heavy grease in the palm of your hand. Hold the bearing at a 45 degree angle to your palm. Catch some grease between your palm and the inside of the bearing race. Force the grease between the race and the shield until you see grease coming out the other side. Do this all the way around the bearing The rear wheel are normally mounted to the trans-axle. The manufacturer considers this to be a sealed unit however you can open it. Remove the Allen head screws and split the axle case by move the slender side down the shaft until its open enough to apply grease with a gun. PUT LOTS OF GREASE. When you close the case most of the grease is going to be squeezed right out again. To prevent this i installed a Zerk fitting. WARNING Do not install a Zerk yourself. What i'm trying to do is to pressurize the case with grease in order to get the grease to where its needed. Do not use the scooter inside until you find its not dripping grease. Hope this helps
Jun 02, 2012 | Pride Go Go Elite Traveller Plus HD 4...
Axle makes a noises going forward only sounds like a bad bushing
there is no bushing on my rear wheels axle albeit an older scooter...wheel runs metal to metal on the axle and so...remove wheel and clean an grease the axle an replace the wheel.... probably wouldn't hurt to run a greasy rag back and forth through the wheel a time or two too...Sometime next week. The Maintenance Dude here @ Big Muddy River Apartments will be correcting a dry rear wheel on my old ole Golden Companion II. I had just acquired the thing and almost immediately after I sat on it to take it for a spin. The left rear wheel started acting up. Lucky my power chair guy does scooter repair too, and he told me no bearings in the back wheels. Its metal to metal and removing the wheel an greasing the axle should take care of it, and I havt'a say that was really admirable of him cause he could have clipped me for a service call and a grease job.....the end
Jan 15, 2011 | Golden Technologies Golden CompanioN II -...
Noise on back axle
Is the noise like a stone stuck in the tyre? If so, I think you have a dry axle, a common problem with Pride scooters and easily rectified. Simply remove the rear wheels, apply grease to the axle shafts, and re-fit the wheels. This should solve your problem. If it's a different type of noise, the problem may lie within the transaxle which would unfortunately involve a costly repair or most likely a replacement transaxle.
Sep 27, 2010 | Pride Revo 4 Wheel Scooter
My scooter is making loud clicking sounds as though something has come loose & hitting something in the rear wheels as it goes around. The repair tech rotated the rear tires last week & this helped...
Its quite common for Pride scooters to be assembled using little or no grease on the rear axle. If the noise is like a stone stuck in the tyre, its probably a 'Dry Axle' as mentioned above. Try just removing the rear wheel(s) and greasing the axle. This normally cures the problem. When removing the wheel, be careful not to lose the hub key which slots into the axle and wheel to stop the wheel spinning freely on the axle. Hope this helps.
Jun 29, 2010 | Pride Go Go Elite Traveller Plus HD 4...
Back wheels make a loud clicking noise
Hi. Loud clicking noises from the rear wheels are usually caused by movement of the square steel key that fits into a groove on the axle inside the wheel hub. This is what drives the wheels.
You will probably get a click for each revolution of the wheels.
To fix it, remove the rear wheels and wipe a thin smear of grease on the key and axle, then replace the wheels.
The grease will allow the key to move slightly without making a noise, and help stop it from wearing.
It sometimes helps to also remove the front wheels, and wipe a thin smear of grease onto the front stub axles. There is no key in the front hubs, but the grease helps to prevent the bearings siezing on to the axles.
Good luck. Neil.
Jun 24, 2010 | Pride New Mobility Legend 4 Wheel Scooter
Loud clicking noise coming from rear wheel drive section
Hi. Does it make a click about every revolution of the rear wheels? If so it is probably the square key in the axle that drives the wheels. Raise the rear of the machine on blocks, and remove the rear wheels. Wipe a thin smear of grease on the axle and key. then reassemble and test.
I have done this on many machines because of the noise. Just about all brands have this problem.
Good luck. Neil.
May 31, 2010 | Pride Mobility Products Go-Go Elite...
Wheels- knocking noise in the right wheel
Hi. If the knocking noise happens with each revolution of the wheel, it is probably the square key in the axle that drives the wheel. Remoce the wheel and wipe a light smear of grease on the axle and key where it fits inside the wheel. As the wheel normally rotates, the weight comes on to the key and off again, causing the noise. The grease allows it to move without making the noise. Sometimes also caused by a stone in the tread, but most likely to be a dry key.Good luck. Neil.
May 08, 2010 | Pride Mobility Products Go-Go Elite...
Pride victory 10 clicks while going foward
If the click is coming from one side of the rear of the scooter, I would think you have a dry axle. If this is the case, you will hear a regular clicking noise, just as if there is a stone in the tyre. All you have to do is remove the wheel, apply some grease to the axle and re-fit the wheel again. When removing the wheel, be careful not to loose the hub key (usually a small strip of square metal that fits in a groove in the axle and wheel). This clicking noise is a very common problem with Pride scooters and one we regularly deal with, even on brand new scooters. If this doesnt cure your problem there are a number of other things it could be, but i would need more specific details to try and help you. Hopefully its just the axle! Hope I have been of some help to you.
Mar 22, 2010 | Pride Mobility Products Pride Victory 10 -...
I received my Pride Revo 3 on Friday and noticed a clicking noise to the rear of the scooter (sounds like it's around the right wheel arch). It's a sound which happens in motion and is quite...
Is it a fast clicking or does it sound like a stone in the tyre? If its the latter, it will just be a dry axle. Remove the wheel (be careful not to lose the hub key!), put grease on the axle and replace the wheel again. This should solve the problem. If its the former, it is normal for this noise to occur but its not usually very load and can sometimes be curred by removing the brake from the motor and 'Re-Seating' it. Either way, it should be nothing to be too cercerned about.
Feb 15, 2010 | Pride Value Line Revo Scooter 3 Wheel
Creaking noise coming from back end of scooter
I 'phoned the seller of my machine and they said that the tyre pressure was low.
Aug 18, 2009 | Pride Health & Beauty
Pride Value Line Revo Scooter 3 Wheel Logo
220 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
