Question about HTC HD2 Smartphone
Loudspeakers don't work - HTC HD2 Smartphone
  • 358 Answers
Hi,when a phones loudspeaker doesn't work, it means that the speaker of the phone that makes you hear the ringing tone and talk with speaker on is bad and will need to be replaced.
When you replace the speaker the speaker will work.
Have a nice day.
Posted on Sep 12, 2010
Marantz pm 7200 loudspeakers do not cut off when headphones pugged in
Some amps have a button which you press to mute the speakers when the headphones are plugged in. Sometimes marked "Speakers on off". If it hasn't then a new headphone socket would not be expensive to fit. As long as the amp producers sound I don't see any future problems. The previous owner may have used the headphone socket a lot, and simply wore it out!
Jul 19, 2012 | Marantz Audio Players & Recorders
Tip
Tips & Review on Nokia 5300 XpressMusic
Nokia 5300 is a great music phone,but it can be regrated on that the battery life is so short.So I've come up with this tips and tricks that can help you save some juice out of your phone.Love the loudspeaker but don’t abuse it so much it might become unfunctional.Don’t set the volume to the maximum level when playing through the loudspeaker.I found the radio better and clearer when playing through the loudspeaker than the music player because the loudspeaker omits more treble than the bass.
Camera Tips:
1. Always set the NIGHT MODE option especially on night shots
2. Set the White Balance to Daylight – When outdoors (Day) Fluorescent – When indoors
3. For acceptable shots, set the resolution to 800 x 600.
NOTE: Using the camera will put up a big drain on your battery.
Battery Tip:
- Don’t always use the camera. Only when needed.
- Set Packet Data Connection to When Needed. Setting can be found on Settings>Connectivity>Packet Data
- Always turn on the Power Saver Feature.
- Turn off your Bluetooth when not in use.
- Turn off screensavers (These are only battery wasters)
- Always make sure that the phone has adequate signal. (If the phone is searching for signals, it drains a big part of the battery)
- I know its fun to play games, but it can decrease your battery so fast.
- The best of all,carry an extra battery if you’re a heavy user.
I think this tip can be helpful. Thank you Everyone.
on Sep 22, 2009 | Nokia 5310 Cellular Phone
My nokia n73 radio is not working what can i do for this problem.
There is the possibility that the earpiece of your headset is bad. Try putting the rdaoi on loudspeaker, if it works, then you either listen to the radio on loudspeaker, or get another headset that is in perfect shape.
But if putting it on loudspeaker still does not work, then you have to entirely change your headset to another.
Hope that was helpful?
Thank you for using FixYa.
Aug 30, 2011 | Nokia N73 Cellular Phone
The loud speaker on my g1 doesn't work how do I replace
  1. 1st OF ALL, YOU WILL HAVE TO UNSCREW THE PHONE
  2. THEN YOU WILL REMOVE THE BAD LOUDSPEAKER
  3. THEN YOU WILL HAVE TO GET A NEW LOUDSPEAKER @ ANY PHONE REPAIR SHOP
  4. THEN FIX THE NEW LOUDSPEAKER IN THE PHONE
  5. TEST IT
Jan 10, 2011 | HTC G1
Radio works well in headset mode but has a lot of disturances in loudspeaker mode
Hi Friend,
When u are hearing the Radio or Music Player in your mobile by using the headset its clear but when u are using thro' loudspeaker its not clear because of below reason,
1.There may be problem in the Speaker(LoudSpeaker).The Solution is u may change your speaker by giving to the Service Center.
Regards,
Ayyasam
May 31, 2009 | Nokia 7610
Nokia N81 only works on loudspeaker
hi sir..
please go to tools>setting>phone>setting>factory settings and type the regular passward 12345 or ur security passward . and it will restard ..
it work,s don,t forget to fix. bye sir..
Sep 01, 2008 | Nokia N81 Smartphone
Loudspeaker Nokia N81 - 8 GB
do you have ab luetooth headset connected?
if so try closing the connection..
May 21, 2008 | Nokia N81 Smartphone
Volume
Volume control
• When you have an active call or are listening to a sound, press o) or (o to
increase or decrease the volume level, respectively.
Voice volume icons:
- for earpiece mode,
- for loudspeaker mode.
Loudspeaker
Your phone has a loudspeaker for handsfree use. The loudspeaker allows you to
speak and listen to the phone from a short distance without having to hold the
phone to your ear, for example, having it on a table nearby. The loudspeaker can
be used during a call, with sound and video applications, and when viewing
multimedia messages. Sound and video applications use the loudspeaker by
default. Using the loudspeaker makes it easier to use other applications while in a
call.
Apr 02, 2008 | Nokia 6600
Loudspeaker does not work
What type of phone do you have? and does it have a wide audio headphone connectors ? as same as Nokia phones?
Usually it's a problem with the "headphone" settings...
Good Luck
Nov 02, 2007 | Cell Phones
HTC HD2 Smartphone Logo
166 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
