Question about Schaerer Siena Espresso Machine
When I turn on the machine it just says flushing and won't go any further.
  • 38 Answers
Machine wants to flush but the boiler may not be up to temp.. with the machine off " Stand By " hold down the on/off and cleaning button at the same time release at the same time. "clear Flag should appear.. check for tripped hi limits on hot water boiler
Posted on Dec 21, 2011
Machine is clogged and water will not drip through to make espresso. the steam frother works sort of
Did your User Manual have a section that tells you how to clean out mineral deposits and hard water scale? Usually, this is done by filling the resevoir with white vinegar and then turning the machine ON for 30 seconds then OFF for 5 minutes. Keep repeating the ON-OFF cleaning cycle until all the vinegar is pumped into the carafe. If the machine needs further cleaning. Repeat the process until the scale and mineral deposits are dissolved. Finally, flush the machine with a full resevoir of clean water and run a normal BREW cycle. Should work like new.
Apr 25, 2015 | Mr. Coffee ECM20 Espresso Machine
2001 VW Beetle 2.0 heater won t heat up
If you flushed the coolant with the thermostat in, chances are you didn't flush the coolant. Regardless, it's easiest to check the controls inside first. Does the blower fan work? Does the air flow change from floor to vent, to dash as it's supposed to? Does the A/C change temps when knob is turned from cold to hot? Post results.
Nov 26, 2013 | Volkswagen Beetle Cars & Trucks
It won't start.
Give the machine a proper service and clean out the carbs. Petrol goes off and a part of it evaporates leaving a nasty sludge behind. This will cause bits to block the jets. It is also worth emptying the fuel tank and flushing it out with a little bit of fresh fuel. Then refill with fresh fuel.
May 10, 2013 | Motorcycles
My dyson dc15 beeter bar won't turn on
I'm sorry to hear you're having difficulties with your DC15. Your machine is equipped with a safety device which shuts off the brushbar if something - for example, a rug fringe or a shoelace - jams it. If the brushbar won't rotate, you may simply need to reset the cleaner.
To do this, please follow the steps shown in the video below - ensure you have the machine reclined into the vacuuming position before testing it, as the brushbar will never rotate when the machine is standing upright.
This should resolve the issue, but for any further assistance or advice, please get in touch with us directly by calling free on 0800 298 0298 (UK), or 1-866-693-9766 (US), so we can help.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Jan 26, 2012 | Vacuums
The toilet flushes but it won't fill. I can turn the water supply off and then back on, then it fills normally.When the tank is full, I can push the float down and no new water enters. when I flush,...
Hi!please kindly check your fill valve if it is working correctly.I thought the problem is in your fill valve.Kindly adjust the floater of your fill valve.
Aug 24, 2011 | Kohler Home
My dyson dc25 all floors vacuum cleaner won't stand up properly to vacuum, flush with the floor.so it doesn't work.any suggestions as to what to do to fix this problem.please and thank...
Sorry to hear of the problem you're experiencing with your DC25. You may find it helpful to visit the Support section of our website and view this video guide to check everything is correct with your machine:
http://www.dyson.co.uk/support/help.asp?article=1983&product=DC25-ALLFLOORS
You should find it's easy to resolve the issue. However, if you're still experiencing difficulties, please get in touch with us free, on 08002980298 (UK), or 1866MYDYSON (US) so we can provide further assistance.
Kind regards,
Jack
Dyson Customer Service
Jun 19, 2011 | Dyson DC25 All Floors Bagless Upright...
My 8 months old battery won't turn on any more. used it for a few minutes and it was alright but it wont turn on with the AC adapter plugged in, and it gives me the message consider replacing battery....
If happens that the machine already detects the battery is already defective it will give that kind of message, the machine will not turn on unless the battery is already been replaced to prevent further failure on the machine, so the only way to fix it is to replace the battery.
May 16, 2011 | HEWLETT-PACKARD HP Mini 2101170NR Notebook
Over filling
Hi
Thanks for using FixYa. Overfilling in your washer occurs mainly due to two things: water inlet valve going bad and/or the water level switch. If the water inlet valve has gone bad it won’t be able to shut off even when the electricity has been turned off. If the issue is with the water level switch then it won’t tell the water to shut off and the machine will overflow as this switch is to sense the water level in the clothes tub. However, with that being said it seems that you’ll need to replace the water inlet valve. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 06, 2010 | Kenmore 24032\24036 Top Load Washer
Schaerer Siena Espresso Machine Logo
76 people viewed this question
Top Schaerer Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Schaerer Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
