Question about Car Audio & Video
Can't get any windows to power windows to work, is there a relay switch that might be bad?
    Sergeant:
    Champion:
  • 324 Answers
Sounds like a fuse,
Posted on Sep 12, 2010
No power to power windows
Have you actually checked for power at the driver's master switch?
I don't think there would be a window relay, there is probably a power window circuit breaker in the instrument panel fuse box.
If no windows work, pull the master switch out and check for one hot wire with key on. If none, check for broken wires in driver's door opening. Your ground for the windows will be in that group of wires too. Both must work for windows to operate. If you have power and good ground at the master switch, and no windows work, probably a bad master switch.
Jan 15, 2014 | 1986 Cadillac Eldorado
Power windows wont work
In the driver side junction box, check the 30A POWER fuse. Power is applied to an integration relay and closes the power relay to apply 12V to the power window master switch. If you have power at the master switch but the windows and locks don't work you may have a bad switch or the motors may be bad. There's not much else that can go wrong
Sep 21, 2012 | 2001 Toyota Tundra
How to determine if a window switch is bad or if the relay is bad. Are there seperate relays for the up and down functions?
There will be three wires to the switch. with a tester, determine which is hot and jump to one lead then the other. If the switch is bad the window will operate. murf427
Aug 01, 2012 | 1990 Lexus LS 400
Air conditioner suddenly not working.. No funny noise, just acts like it is not getting power. compressor kicks on and off checked relays behind glove compartment. Was told ac relay may not located with...
AC COMPRESSOR KICKING OFF AND ON.SOUND LIKE REFRIGERANT LOW.LOW SIDE SHOULD BE 20 - 36 PSI AND HIGH SIDE SHOULD BE 215 - 310 PSI. AC SYSTEM COULD HAVE A LEAK WHILE YOUR COOLING STOPPED. DRIVER SIDE WINDOW MOST TIME SWITCH WILL BE THE PROBLEM.REMOVE SWITCH SEE IF POWER GOING TO POWER WINDOW MOTOR.YOU HEAR WINDOW MOTOR TRYING TO WORK WHILE USING SWITCH.WINDOW REGULATOR COULD BE BINDING DAMAGED OR NEED LUBRICATING.OR MOTOR NEED REPLACED.IF POWER NOT GOING TO POWER WINDOW MOTOR THE CONTROL SWITCH IS BAD IF ITS THE ONLY SWITCH.TO TELL IF WINDOW SWITCH IS BAD SHAKE POWER WINDOW SWITCH WIRES WHILE OPERATING CONTROL SWITCH.IF POWER WINDOW WORKS YOU KNOW SWITCH IS BAD.TAKE CAR TO AC SHOP BECAUSE LET THEM CHECK AC SYSTEM BECAUSE IF YOU BUY 2 CANS OF R134 REFRIGERANT. AND YOU TRY CHARGING AC SYSTEM YOUR SELF AND ALL REFRIGERANT LEAKS OUT. YOU GOING TO BE OUT OF $30.00 STILL NO AC.THAT WHY ITS BEST TO LET SHOP PUMP DOWN AC SYSTEM CHECK FOR LEAKS BEFORE RECHARGING AC SYSTEM.
Jun 26, 2011 | 2000 Acura TL
1998 toyota camry driver side window switch will not run any windows but lock button still works
Check first the power window fuse, located in the fuse box, if blown, replace it with the same amperage. If it still don't work, the problem will be the power window switch module. The switch is electronic and when it doesn't work, you have to replace it.
Better go to your dealer and let them assess that switch, they would try the new one to confirm if the switch is to be replace or not. that switch usually breaks down when caught in the rain or just got dirty.
Hope that solves your problem.
Thanks for using Fixya!
Dec 10, 2010 | 1998 Toyota Camry
Passenger side automatic window switch is not working in my 2004 Chevy Aveo. The window is operational from the driver's side master switch but not the passenger side. Im thinking its a fuse or a relay,...
Make sure the window lockout button is not depressed on the master window switch. This will turn off the other switches and not let them control there respective windows.
Power is supplied to all the windows from one fuse and one relay. So if the master switch operates the window than we know the fuses and relays are o.k. We know the master switch will operate the window so that tells us the window motor and ground side of the passenger window motor circuit are also good.
Which leaves us with a bad switch or no power to the switch. The passenger window switch gets its power to operate independently from the master switch window lockout button. When the button is off power is supplied to the passenger switch and allows the passenger to operate the window themselves.
The only thing you need to do is check for power at the passenger switch on the brown wire with orange stripe. If there is power there then you have a bad switch.
Oct 08, 2010 | Chevrolet Aveo Cars & Trucks
1993 ford explorer window won't go up or down
is it a power window, if it is you motor could have went out, or your window might have came of its track.
Sep 05, 2010 | 1993 Ford Explorer Limited
What would be wrong if my windows wouldnt let down on my car
All of the Windows? Check the Power Window Relay and the Power Fuse for the Windows.
Jul 20, 2010 | 2000 Mitsubishi Galant
Power window does not work
your window power relay is either bad,or the switch is not supplying power to the relay to energize the contacts that feed the window motor power,if you can find the relay, push switch and you should hear a click from relay that switch is supplying power to the relay
Sep 12, 2009 | 2003 Honda CR-V
Honda Passport 2000 - none of the windows rolling
Sounds to me like you have a bad power window relay. Start by checking the power supply to the relay. Should the relay be bad replace and the window movement should be restored. If this doesn't take care of the problem you may need to replace the master switch in the driver door. The master switch allows all the other switches to do their job. If it malfunctions none of the windows will work. Hope this info helps, good luck!!!
May 11, 2009 | 2000 Honda Passport
Car Audio & Video Logo
19 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
