Question about GE Monogram Side by Side Refrigerator
I installed a GE Monogram built in 48" refrigerator approximately two years ago. The unit is working. The problem I have is that about 2-3 months ago the temperature in the freezer started swinging plus and minus 3 degrees from my setting of -2 degrees. The refrigerator seems to hold its setting. This happens even when the doors have not been opened. I never noticed that before. I had a GE Technician look at it and he said it was normal. He had no answer about why I never noticed it earlier. Is there anything tha tI can do?
  • GE Master
  • 1,711 Answers
No this is not normal. Maybe is not a big problem since the temperature in th freezer is finaly withing acceptable limits which mean that your products will not be spoiled and freezer will consume extreme energy by going below 0.
However the temperature should be stable between -2 to 0 not -3 not 1.
The problem is either the thermostat probe or the electronic thermostat or the elctronic control board.
The first two is not so expensive so in this case you can replace them. The electronic board it is cost about $200 so in this case maybe you should leave it if and only the problem get worst.
Finaly I sugest to keep an eye on it and only if the proble get worst then you should proceed to find which is the acual problem from three above and fix it. Also you should know that 0 degrees is the normal setting for the freezer.
Posted on Sep 12, 2010
GE Monogram built-in loses gas within 2 days
You need to find out where the leak is located to repair otherwise if you continue to charge with Freon the fridge is going to get moisture inside the sealed system. A lot of times the evaporator will leak causing moisture to be pulled in. The leak could also be in the condenser coils or the yoder loop.Can you charge it again and use soapy water to help you to locate the leak? Are you equipped to repair the refrigerator? Thanks John Tripp Sea Breeze
Feb 11, 2014 | GE Refrigerators
I have a Monogram 48"
http://www.acmehowto.com/howto/appliance/icemaker/check/inletvalve.php
Nov 11, 2010 | GE Monogram Side by Side Refrigerator
My built in side by side is making a noise about every 30 minutes or so that sounds like a woodpecker pecking on it...about 10 times. It is driving me crazy! Have any idea what this might be?
I have the exact problem with my built0in side-by-side Monogram. 1 yr 3 months old, and it sounds m=like a woodpecker for 3 seconds approximately 1ce/hr. Does not appear related to ice maker. You can create the sound by changing the temp setting on the drawer at the bottom. As you command a lower temp, the sound happens a couple seconds. Actually sounds like a solenoid opening and closing at 60Hz frequency, as though a control board were feeding AC to a DC coil. Any ideas? Fortunately, this fridge has a 2 year warranty, but this should not happen to a $6K dual condenser fridge in just over a year!!
Jan 09, 2010 | GE Monogram® ZISS420DMSS Side by Side...
My GE monogram built in refrigerator is not staying cold
GE Mono frig are built with shut off senser on the compressor. Wipe the condenser coil with damp cloth. This will resolve the problem. This lession cost me $160.00 from GE frig tech guy. Not to mentioned using my clean cloth and wiped for just 5 minutes.
Nov 07, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sfjfg
Aug 16, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
My GE 48 inch built in fridge began making a strange noise.
fan motor problem ge has the solucion replacement fan motor around $350 plus mine still makes the noise
Jun 19, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Jul 17, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
GE Monogram Side by Side Refrigerator Logo
95 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
